Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Old 07-03-2009, 02:56 PM   #1
Trade: painting
warehouse rollup doors
I have a 12x12 rollup door in my warehouse that has a spring inside the rollup portion of the door. The door has gotten progressively more difficult to rollup or down as if the spring has lost tension. Does this sound like my problem or could it be something else? How do you adjust the tension on the spring if this is my problem?
rwsmith0004 is offline   Reply With Quote
Old 07-03-2009, 03:31 PM   #2
LRG WoodCrafting
Leo G's Avatar
Trade: Professional Sawdust Producer
YOU don't adjust it. It is under tremendous tension. Have someone who is familiar (Overhead Door Co) look at it and adjust the spring.
Check all the rollers, could be one is stuck or seizing. Check to see the the track isn't squeezing the door, it can be moved outward if it is.
Measure Twice Cut Once -- It's a lot easier to cut more off then it is to cut MORON.
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now   Reply With Quote
rwsmith0004 (07-03-2009)
Old 07-03-2009, 04:39 PM   #3
Trade: Remodeling / Carpentry
Agree completely.
Check the ends of the shaft there may be grease fittings that you can lube.
Lube the track with some thick grease like wheel bearing grease, brush it on.
I think these are band - aid fixes however. I'd start thinking who's going to be around when the music stops at 6 o'clock one night !
Like Leo said call a pro.
We Fix Houses is offline   Reply With Quote
The Following User Says Thank You to We Fix Houses For This Useful Post:
Old 07-03-2009, 09:22 PM   #4
Trade: painting
thanks for the reply as it sounds like I need an experienced pro to handle this.
Old 07-03-2009, 09:40 PM   #5
Chief hand holder
bert0168's Avatar
Trade: Residential Remodeling
See, occasionally they see the light
bert0168 is offline   Reply With Quote
24" exterior doors - where to buy? Panzer5 Carpentry 11 05-07-2009 07:43 AM
Selling exterior doors......rant tom m Windows, Siding and Doors 21 03-28-2009 09:02 PM
Hurricane Resistant Sliding Glass Doors gallerytungsten General Discussion 1 03-10-2009 12:00 PM
What to use on sandblasted security doors? Dorman Painting Painting & Finish Work 3 08-07-2007 05:24 AM
