Vinyl Soffits - Falling
Lately, a portion of vinyl soffit has been falling beyond the wall 'L' channel at its endl.
It was installed as a long run ~ 5-6 ft., from gutter to wall, over the garage section. This vented vinyl material doesn't seem to be attached to truss chord and only rests on the retainer at inner fascia and wall. Is this to help account for expansion/contraction of vinyl or only 'ease of installation'? Wondering best way to correct this; and how to attach at underside. Seems like any form of attachment is going to show glaringly from below and it will not have that elongated bow from fascia to wall as the whole area now does. note: bldg is 10+ yrs old and has done so only couple times in past, now is happening weekly. Any winds have been around normal, not much. Guess it has lost its rigidity over the years. Last edited by artinall; 04-21-2008 at 05:24 PM. |
Re: Vinyl Soffits - Falling
Am I reading this right? You have vinyl soffit that is 5-6' lengths and they are only held in place by the channels at each end? If so, I'm surprised they aren't all laying on the ground by now. You couldn't have 5-6' length plywood soffits nailed only at each end and not expect them to bow. Take it all down and add nailers 12-16" OC then nail it back up.
#3 | |
Trade: Exterior Finishing
Re: Vinyl Soffits - FallingQuote:
#4 | |
Siding Windows Doors
Trade: Exteriors
#5 | |
Problem I'll have now is that the ridges aren't going to line up on center. And the vinyl is probably discontinued/weathered to match remainder of soffit on the house. Will have to nail through the sheer sections and this, will make it obvious. What would you use for nails? Will the vinyl expand/contract similarly with the nailers? As a sidenote - the entire porch was done the same way. There is a large bow on this ceiling - roughly 6' in depth. Building is a duplex. |
Handle It!
I do not see the problem. It is an improper install and now you are there, many years after, to fix it. BILL ACCORDINGLY! And then some!
#7 | |
The BEST soffit screw up is the idiots that try to run soffits parallel to the porch, and will seam soffit together! OR who run parallel to joists without strapping.
#8 | |
If going parallel to joists, why not screw centermost through the mounting slot, leaving unsnug, so the vinyl can slide if necessary for movement? |
Al Smith
if I am reading this right. Your truss lower chord runs in the same direction as the panels? and your nailing hem has no backer to nail to? why cant you just dismantle the ceiling and provide 1/2 inch plywood and reinstall all the old material using the nailing hem? Will this additional half inch lower the ceiling below the facia "L" bend and the soffit "J" or "F" channel on the wall?
A W,
Thank you for the response. Yes, the truss chords run parallel to panels. Might end up blocking nailers off at a right angle to chords. Did not want to nail plywood since this will mean losing ventilation, and these areas connect with others that would be 1/2" higher, and would loose L channel. Probably will have to crawl attic at the far end of a very slim pitch roof to view this from above. |
| Siding: Aluminum vs. Vinyl | Grumpy | Windows, Siding and Doors | 21 | 03-30-2010 08:02 PM |
| Fiber Cement almost same cost as Vinyl? | MKECONTRACTOR | Windows, Siding and Doors | 17 | 12-20-2008 06:34 PM |
| Scalloped Vinyl | Shamrock | Windows, Siding and Doors | 1 | 09-18-2006 04:20 PM |
| soffits and facia | newguy123 | Windows, Siding and Doors | 8 | 07-30-2006 02:30 AM |
| vinyl decking with hot tub | nriddock | Decks & Fencing | 2 | 06-16-2006 02:10 PM |
