Vinyl Soffit Round Porch
Old 06-06-2008, 11:42 PM   #1
BABuilders's Avatar
Trade: Siding - Windows - Doors
hello i have a situation at hand that im not sure how to handle. The situation i have is im doing a siding job and the house has a porch that has rounded corners. (not square) now my question is how and whats the best method to install soffit and fascia on this,
thanks a million!
A Touch Of Excellence in Every Home!
St joseph Siding Windows Doors and Decks
BABuilders is offline
Old 06-06-2008, 11:48 PM   #2
Patrick's Avatar
Re: Vinyl Soffit Round Porch
cut your soffit to fit the curve, and then make your L shaped facia and cut slices in the leg that holds the soffit, so that you can bend it around the curve. This may or may not look good depending on the curve. May look better with azek instead
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 06-06-2008, 11:55 PM   #3
brutis's Avatar
Trade: siding soffit hardie Tampa Fl
is it possible to post a pic. ?
you could square it off with j then run j back to back on the and 45 it on back to the round part till the rounded part gets small enough to use one pc of soffit, around here i can get 16 in. wide soffit but you could get small enough to use 12 in.
Kind of hard to exsplain , wish i could traw pic of what i mean
brutis is offline
Old 06-08-2008, 06:56 PM   #4
BABuilders's Avatar
thanks for the input so far! ill try and get a pic of it posted asap as to better illustrate the situation.
i have done a lot of different work but never had to take on a situation like this.
Round porch..? ecooke21 Framing 32 09-27-2010 07:49 PM
Fiber Cement almost same cost as Vinyl? MKECONTRACTOR Windows, Siding and Doors 17 12-20-2008 06:34 PM
Question with quarter round haskl33 Carpentry 14 05-31-2008 07:49 AM
log cabin vinyl siding Home Serve Windows, Siding and Doors 6 04-28-2008 08:16 AM
Scalloped Vinyl Shamrock Windows, Siding and Doors 1 09-18-2006 04:20 PM
