Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Old 05-27-2009, 04:47 PM   #1
Trade: windows-siding
Vinyl siding question here
i see a few companies now offering 25 foot panels;is there any downside to using a panel that long? durability ect... forget about labor side,i am concerned about the strength and durability of such a long panel.i am looking at Alcoa/mastic and alside..
also,anyone know of any potential problems with insulated siding>?? i am wondering why the double 4 never comes in a 16 foot length but the double 6 and single 7 does???
enforcer is offline   Reply With Quote
Old 05-27-2009, 08:22 PM   #2
Trade: Handyman Services and Home Improvements
Seems to me the biggest problem w/ a 25' panel would be transportation and handling it up a few feet in the air. I can't see there being a difference w/ durability or performance on these. Just my guess though.
Favorite Jobsite Quote: "I cut it twice and it's still too short!"
HandyHails is offline   Reply With Quote
Old 05-27-2009, 08:27 PM   #3
MetalBender's Avatar
Trade: Siding,S&F,Windows
You need two guys to install one 25' panel. Brands mentioned are good stuff. D4 probably isn't offered in other lengths cause nobody wants it at all, atleast not here. I have had varying results with insulated siding, buckling on south walls where temps vary quickly with the backer glued to the panel. Never had any trouble with Alside Fullback system, foam is seperate and must be installed properly but it looks great and holds up very well.
MetalBender is offline   Reply With Quote
Old 05-27-2009, 10:38 PM   #4
are you saying no one askd for D4 and thats why its not made in a 16'? mastic/alcoa does'nt have a 16 foot panel yet..too bad,its a nice product. not sure if a 16' is that important for insulated siding due to the seams being so tight?
Old 05-28-2009, 12:03 AM   #5
Patrick's Avatar
HUH???
Alcoa/Mastic currently produces
Quest D4 D5 D4.5 Dutch in 12's AND 16's
Grand Sierra D4 in 12's 16's and 25's
Structure EPS Insulated
D4 & D4.5 Dutch Single 7 and double 6
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline   Reply With Quote
The Following User Says Thank You to Patrick For This Useful Post:
tomstruble (06-17-2009)
Old 05-28-2009, 06:58 AM   #6
Alcoa's insulated (structure) does NOT come in 16' lengths; only quest and grand sierra.
The Following User Says Thank You to enforcer For This Useful Post:
Old 06-17-2009, 05:08 PM   #7
Trade: Supply
expansion and contraction is the big issue. Deep DEEP Js and corners are needed. We also use a clip system that helps with the panel movment. Transport is no fun, we have a 45ft trailer to lug our 40ft siding around.
kylemfk is offline   Reply With Quote
Old 06-17-2009, 05:26 PM   #8
Trade: exterior cladding
Alcoa mastic does not require deep j-channels with their product. The 40 ft panels do though. Installed over 50 jobs with the 25 foot panel with great success. Just pin it in the middle of the panel.
Sidingmaster is offline   Reply With Quote
The Following User Says Thank You to Sidingmaster For This Useful Post:
Old 06-17-2009, 10:07 PM   #9
tomstruble's Avatar
Trade: siding
its possible to install the longer lengths solo, just have to orientate everything right
tomstruble is offline   Reply With Quote
Old 06-24-2009, 10:34 PM   #10
Siding Windows Doors
easy sider's Avatar
Trade: Exteriors
We liked Royal Woodland because it came in 16' lenghts. Grand Siera 16' and Cetainteed Monogram 16' are great. Napco 25' is too costly on the freight and requires a 160 sq. purchase. ABC Portland OR. had Amcraft 25' by the job but Royal stoped making it for them.
25' panels need to be center panel nailed for expansion.
Wolverine used to make the HP panel in 40' lenghts but getting this to a jobsite was problematic.
easy sider is offline   Reply With Quote
Old 06-25-2009, 06:44 AM   #11
tomstruble's Avatar
Trade: siding
actually back in the day wolverine was the first to introduce a 40' panel.They were the leaders in vinyl innovation,after c/t brought them i think the innovation stopped for them
Old 06-25-2009, 08:48 AM   #12
THE PANEL WAS ACTUALLY A GREAT IDEA(WOLVERINE) A 40 FOOT PANEL WITH FIBERGLASS REINFORCEMENT.. problem was,the installer had to manually insert the fiberglass which was no big deal; however,most were too friggin lazt to do it and it voided the warranty. so they stopped making it..alside has reinforcement in their panel but its a bit too glossy and grainy.
Old 06-25-2009, 05:40 PM   #13
easy sider's Avatar
Trade: Exteriors
The Wolverine HP was .054 had a bigger nail bar but no rod. The Wolverine Benchmark .044 had a fiberglass rod that required a little strenght to cut with snips.
Old 06-25-2009, 08:32 PM   #14
tomstruble's Avatar
Trade: siding
thats it benchmarki always thought that reinforcing rod would be a great idea in a heavy duty soffit panel
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 15 12-23-2008 11:46 PM
Siding Question Paramount Contr Windows, Siding and Doors 11 12-10-2008 10:20 PM
How to cut vinyl cedar shake siding for addition? RomZes13 Windows, Siding and Doors 6 06-18-2008 09:13 PM
removing egg from vinyl siding Zeebo Painting & Finish Work 9 11-20-2007 12:08 PM
