Vinyl Siding Nightmare
Old 09-08-2009, 08:10 PM   #41
Tom Struble's Avatar
Trade: siding
Re: Vinyl Siding Nightmare
i tape the vertical seams only usually
I'm not a big fan of vinyl siding just nailed to strapping
unless you foam in between it
Tom Struble is online now
Old 09-08-2009, 09:30 PM   #42
DavidC
DavidC's Avatar
But why not Tom?
I've never installed vinyl that wasn't new construction or at least over fanfold on a reside. I'm not averse to being wrong. There was that one time last year......
Good luck
www.CookContractingLLC.com
DavidC is offline
Old 09-08-2009, 09:40 PM   #43
Remodeling Professionals
buildenterprise's Avatar
I've seen quite a few of these asbestos over Homasote installs. We're usually called in when the vinyl siding they nailed to the asbestos starts to loosen and fall off, since the Homasote doesn't hold it at all.
http://en.wikipedia.org/wiki/Homasote
buildenterprise is offline
Old 09-08-2009, 09:42 PM   #44
Patrick's Avatar
Most of you are opposed to field nailing into the homasote, and toms opposed to nailing the studs.
WHAT WE DO is nail the STUDS & the SHEATHING!!
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
The Following User Says Thank You to Patrick For This Useful Post:
Tom Struble (09-08-2009)
Old 09-08-2009, 09:45 PM   #45
In the few houses where I've had to repair loose siding there is no sheathing, only homasote stapled to the studs with the asbestos hung directly on that. Don't ask me how that works for lateral stability. So if you can find a stud and they're on 16s you're good, otherwise good luck.
Old 09-08-2009, 10:27 PM   #46
Trade: siding
Dave i think vinyl should be installed on a smooth continuous surface,not directly to open studs or furring
Patrick im not oppose to nailing to the studs,just that usually by the time you put on your corners and window trim and j channel some times there are not many studs to hit for a good secure install
DavidC (09-09-2009)
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 21 03-30-2010 08:02 PM
vinyl siding cutting table platinumLLC Windows, Siding and Doors 16 08-15-2009 11:54 AM
Liquid Vinyl Siding Mitch M Painting & Finish Work 3 04-15-2009 09:19 PM
Painting vinyl siding workpot Painting & Finish Work 18 11-06-2008 07:04 AM
log cabin vinyl siding Home Serve Windows, Siding and Doors 6 04-28-2008 08:16 AM
