#21 | |
member
Trade: Siding, windows, Aluminum crown
Re: Vinyl Siding Nightmare
Thats Tomstruble...I dont know if you were being a smart arse or if it was an honest mistake but either way you might wanna be more careful.
| The Following User Says Thank You to Jer For This Useful Post: | Tom Struble (09-07-2009) |
#22 |
Trade: roofing
if you guys go over esisting siding do you use tyvek over the new insulation board or over the existing shingles before the insulation boards?
#23 |
Trade: siding
My city code official would rather I use one or the other, but if I really want both on he insists on the tyvek over foam. I personally dont use housewrap with foam. The subject just came up because I had a homeowner who wanted it.
It's better to die on your feet than to be living on your knees. |
#24 |
In case you guys are wondering, when you wrap the house up all nice and pretty with your Tyvek, and then spend another day covering all your seams with tape.
When you go to hang your siding, your putting a million nail holes in the stuff which IS going to let the water right through. FWIW we have gone over asbestos several times and the install technique all depends on the type of asbestos siding that is up there and how it was installed.
| The Following User Says Thank You to Patrick For This Useful Post: | Tom Struble (09-07-2009) |
#25 | |
Trade: siding
Re: Vinyl Siding NightmareQuote:
#26 |
We never tape, Im just going by what ive seen. Actually around here the only people I see using tape are DIYERS
#27 |
Trade: siding
i feel the same way about taping tyvek
i try to never tape horizontal seams even tho i understand moisture could be wind driven up through the seam i feel better knowing if water does get in it can get out if i don't tape the horizontal seams all this being said,ive gone over cement shingles many times most of the time without a problem like was mentioned depends on how it was installed,alot of times its very solid,in Davin's case im doubtful its as soild as it needs to be thanks jer i have one of those kinds of names
Tom Last edited by Tom Struble; 09-07-2009 at 07:49 PM. |
#28 | |
Trade: Remodeling / Carpentry
Curious to know what kind of nails were used ? AL too soft ? |
#29 |
Trade: siding
usually 2'' roofers
the lap is the hardest part otherwise it nails pretty easily as long as the cement panel is on solid sheathing there's not too much breakage were it becomes a problem I've seen those shingles furred out that makes for a harder reside
Tom |
#30 |
In that case the old exposure was usually 10" so we try to use double 5" Siding so we can nail close to the furring
#31 |
Trade: windows and siding
i don't know how someone could side over asbestos if there is no plywood sheathing under it. the stuff will crack and the nails will come out. alot of older homes don't have plywood so you need to remove and nail directly into the studs. also need to put up some backing over the studs such as foam board.
#32 |
Trade: siding
ill say it
you cant do a decent vinyl siding job just nailing to the studs you have a window 20'' from a corner how many nails you going to beable to get in the panels inbetween?1?maybe 2 if you angle the nail enough
Tom Last edited by Tom Struble; 09-07-2009 at 11:33 PM. |
#33 |
I used to think so.......
In 2003, some Clarksville, TN framers down the street were burning their scrap wood for warmth.
I wonder when they figured out that the fire was too hot. Too funny. |
| The Following User Says Thank You to wallmaxx For This Useful Post: | knucklehead (09-08-2009) |
#34 | |
Trade: roofing
#35 |
Pompass Ass
Re: Vinyl Siding Nightmare |
#36 | |
Trade: siding
If we are going over the existing siding, we still have to have a pre-inspection to make sure it's in good shape.
#37 | |
Pompass Ass
#38 |
WOW we would be lucky if the inspectors even looked at the house at any point during the job
#39 |
DavidC
We wouldn't need a permit or any inspections here for a reside.
I've never seen the issue described in the OP either. Any house around here old enough to have asbestos siding will most likely have solid wood sheathing. The insulation board (we call it beaver board) sheathing is found under some vinyl, or more so aluminum siding. What about strapping the wall first? I would think locating the studs with a sensor should be easy enough, install diagonal strapping 16"oc and go. Of course you'd have to fur out the windows and doors as well as compete with the guys that would slap it up with nothing. Good Luck Dave
www.CookContractingLLC.com |
| Siding: Aluminum vs. Vinyl | Grumpy | Windows, Siding and Doors | 21 | 03-30-2010 08:02 PM |
| vinyl siding cutting table | platinumLLC | Windows, Siding and Doors | 16 | 08-15-2009 11:54 AM |
| Liquid Vinyl Siding | Mitch M | Painting & Finish Work | 3 | 04-15-2009 09:19 PM |
| Painting vinyl siding | workpot | Painting & Finish Work | 18 | 11-06-2008 07:04 AM |
| log cabin vinyl siding | Home Serve | Windows, Siding and Doors | 6 | 04-28-2008 08:16 AM |
