Vinyl Replacements In Older Andersen DH
First time for this situation.
Have any of the window installers faced this yet? I have to install new vinyl repalcement units in 20yr old Andersen DH W/vinyl exteriors frames. There are no visible stops,just the old vinyl tracks in the Andersens. Is it just a mater of adding the stops,and what's the best way to get accurate measurements? And then there is the matter ofwrapping on the exterior with the old vinyl exterior still in place. The Ho wants to match to other vinyl replacements already done so new inserts are out of the question.
https://www.facebook.com/pages/John-...94183374011504 |
Re: Vinyl Replacements In Older Andersen DH
Anybody?
Patrick?
Yea we've done it, not exactly the best situation. just make ABSOLUTELY SURE that the old frame is NOT rotted under the permashield cladding
measure from inside jamb to inside jamb and sill to top jamb Cut the cords, and there are three screws on each side remove all the crap, install the window like normal You gotta make stops for the inside (VERY SMALL ONES) OR measure your windows close enough and caulk the gap. Take a look at the inside of all the windows and MAKE SURE that none of the interior casing hangs over the jamb preventing you from sliding the new window in Wrap the outside and just bust your nails right through the cladding. If it is vinyl sided I suggest wrapping your trim around the J so that you have a wider trim cause the Andersen frames are very narrow and hard to wrap. Overall, I would prefer to use new construction windows in this situation. I just looked at some today and recommended we do just that. However we have done plenty of replacements. Just be careful because I bet some of them are rotted under the vinyl clad PS Not sure what you are using for replacement windows, but we are now distributing vinyl windows, and we are VERY competitive with who I am pretty sure you are using and can give you a lot more window for a lot less $$
| The Following User Says Thank You to Patrick For This Useful Post: | oldfrt (10-05-2009) |
I'll check for the rot.
Trimming may be put off,as I'll be doing the siding in the spring,so I'll definately go with the new construction units if there is rot. The HO has already picked the Harveys since they match other units they have done alreeady,but I'll keep your units in mind. Send me some info.
#5 | |
Re: Vinyl Replacements In Older Andersen DHQuote:
President
Trade: Installing windows, siding, roofing, doors, patio rooms, gutters and shutters.
I smell gravy. We do tons of Andersen replacements. We find them the easiest windows that we do. On the inside we use a 1/2" cove molding and on the outside if they want new trim we use a filler on the side of the window frame to make the narrow line wider, add another board on top of that and cover with coil. That way the board that we put on covers the old J-channel and gives the whole job a clean new look.
| The Following User Says Thank You to Jake Stevens For This Useful Post: | oldfrt (10-07-2009) |
Quality before quantity
Trade: exterior remodelling
Yup "gravy"
Funny how all my guys complain they don't get enough for steel casements(even though I pay more)but never say they're making too much for Anderson DH removal. "Good with the bad." At least that's what I used to tell myself. |
#8 | |
A lot of times the interior trim hangs over the jambs for whatever reason and you cant get the windows in from the inside. The other problem is the 200 series are notorious for rotting inside because the edges are missing cladding so often they are soaking wet inside, and you just installed a really nice window into a piece of **** frame
| The Following User Says Thank You to Patrick For This Useful Post: | Tom Struble (10-21-2009) |
Gravy Huh!
Glad to hear that. All I need to do now is get the sighnature on the dotted line before the specilal rates for the free inserts goes away.
lol You better hurry up before I come in and sell the job Jakes in Maine, Im just around the corner!
#11 | |
Ok Ok I kid...sorta.I've seen worse. |
Trade: Windows and Doors
I LOVE replacing old Andersen Permashield DHs. I order my replacements only 3/8" smaller than the opening because of the smaller outside stops. 1/2 " thickness on the inside stops. If it's in brick its an easy L bend picture frame cap. 10 mins. Like Jake said.......GRAVY.
![]() ![]() ![]() On a goood day we can set and cap and stop about 25 of these. BOO YA |
| Andersen vinyl window: adjust sash tension? | Tinstaafl | Windows, Siding and Doors | 14 | 05-14-2009 06:29 PM |
| Tile over vinyl pros and cons | tileguy7 | Ceramic & Stone Tile | 23 | 01-17-2009 09:53 PM |
| Replacing Andersen Casements | Jaketoo | Windows, Siding and Doors | 21 | 12-31-2008 02:44 PM |
| Painting vinyl siding | workpot | Painting & Finish Work | 18 | 11-06-2008 07:04 AM |
| Sash to small for frame (new vinyl replacements) | mattp | Windows, Siding and Doors | 11 | 07-08-2008 07:34 PM |
