Vinyl Cutting Tables?
Old 09-08-2007, 02:54 AM   #1
WhyNotFab's Avatar
Trade: Framing
Anyone have pics of their table they cut siding on?
Ours is basic.. maybe 8-10' long, 12" wide, 2x2 along the front and back with 1x4 guide set up across the 2x2 for the saw to run through.
Just made from scrap since we mostly do framing, but I know someone who does full-time siding has to have some pictures of theirs that's built lighter/to last longer.
WhyNotFab is offline
Old 09-08-2007, 01:00 PM   #2
Patrick's Avatar
Re: Vinyl Cutting Tables?
I use one of these. You permanently mount an old circular saw to it with the blade guard ripped off. I then took the whole set up and mounted it on an old wooden ladder and then covered it with plywood which gets sacrificed and has to be replaced every couple years
Patrick is offline
Old 09-08-2007, 01:01 PM   #3
Patrick's Avatar
Oops trouble getting the pic up, i posted it in the siding photo gallery
Patrick is offline
Old 09-08-2007, 11:32 PM   #4
Expert Roofer
theroofinggod's Avatar
Trade: ROOFING/HOME IMPROVEMENTS-WINDOWS/SIDING/GUTTERING/COPPER WORK,ETC
Send a message via MSN to theroofinggod Send a message via Yahoo to theroofinggod
I have a tapco w/the dial an angle feature,very nice,if Iget a chance I`ll take pics
theroofinggod is offline
Old 09-09-2007, 04:57 PM   #5
Home Serve's Avatar
Trade: siding windows soffit fascia
Patrick, went to look at the photo but could not find. Do you cut siding and soffit with the saw? We cut siding with our Klenks snips and soffit on saw but we just use a big miter saw, be better with table.
Know where photo is?
Thanks,
Home Serve is offline
Old 09-09-2007, 05:56 PM   #6
Patrick's Avatar
http://www.contractortalk.com/galler...00&ppuser=6257
Thats the link to the picture out of the catalog. I took that whole setup and mounted it on an old wood ladder. I think it cost like $70 from my siding supplier. We use it for cutting soffit and siding where there are no seams and you have 4 or more pieces that are going to be the same length. when you get up to the gables you just make a template line it up on the saw put a nail on the table and then you have your angle mark. The problem with a large miter saw is that it wont cut the shallow roof angles. This saw will let you cut the most shallow roof angle. The saw that I attached to it was a old cheapo craftsman circular saw with a plywood blade in it. The saw does everything the $800 dollar table does for a small fraction of the price
Patrick is offline
Old 09-09-2007, 11:41 PM   #7
Expert Roofer
I usually do my angles w/ a square and snips
Old 09-10-2007, 08:48 AM   #8
Home Serve's Avatar
I'd be interested for some information on that saw Patrick if you could post it. Sounds very reasonable and a time saver.
Thanks,
Old 09-10-2007, 06:41 PM   #9
Patrick's Avatar
Go to that link and it is the last item on the page
http://images.google.com/imgres?imgu...icial%26sa%3DN
Patrick is offline
Old 09-10-2007, 08:34 PM   #10
Professional Remodeler
firemike's Avatar
I use the Tapco EZ-Angle, it is the second from the bottom in Patrick's link above. I think it is being replaced by a newer model, I see them every so often on eBay and various other auction sites, as well as the local trading times papers. I like it, does a great job and is accurate.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 09-10-2007, 10:00 PM   #11
Home Serve's Avatar
Thanks for the info and the link guys, I did not know these things existed, bit money saver over a normal cut saw but still I can see makes cutting a lot easier.
Take care,
Old 09-21-2007, 12:56 AM   #12
WhyNotFab's Avatar
Trade: Framing
definitely something to look into.. thanks guys!
Old 05-18-2008, 01:47 AM   #13
home improvement contract
mci2980's Avatar
Trade: home improvement contractor
i use the ryobi 8 1/4 radial inserted into a aluminum insulated 3 1/2" piece of the patio room wall board. saw slides in and gets clamped off. i wrapped all four edges with the aluminum extrusion and a 1"x 1" L extrusion as a fence. ill take pics and post em. every vinyl guy who has seen it loves it. it can get trickey doing the gable cuts but it work well once you figure it out. light weight and breaks down easy. i used to use the tapco ez cut or whatever its called but this thing i use now takes the cake .
mci2980 is offline
Old 05-18-2008, 10:10 AM   #14
jethro66's Avatar
Trade: siding soffit fasia trough
I have a mark one trim a table thats 25 years old and still going strong! Got it from the old man who has 30+ years expierience.With vinyl I just use snips for angles
jethro66 is offline
Fiber Cement almost same cost as Vinyl? MKECONTRACTOR Windows, Siding and Doors 17 12-20-2008 06:34 PM
Scalloped Vinyl Shamrock Windows, Siding and Doors 1 09-18-2006 04:20 PM
proper way of loading of brush from a cutting pail Zeebo Painting & Finish Work 7 08-11-2006 11:58 PM
vinyl decking with hot tub nriddock Decks & Fencing 2 06-16-2006 02:10 PM
Determining Manhours for rolling vs. cutting - your suggestions would be helpful Zeebo Painting & Finish Work 9 06-02-2006 06:12 PM
