Vertical Router For Windows
Old 07-23-2006, 10:15 AM   #1
ATHC's Avatar
Trade: General Construction
I'm looking for info on a vertical router setup (if that's the correct name) for window sashes.
Anyone happen to see one of the This Old House show that featured an tall older gentleman/window contractor that had a vertical router setup in his trailer that he can put a window sash into and route out the old glazing to remove the glass then route again slightly deeper for thicker window pane? Kind of looks like a panel saw, yet smaller. This is a manual units that routes in X,Y,Z axis.
I want to know if this unit is available or was it custom made and where can I find detailed info about it. I can't find the show info and haven't received an email reply from TOH as to the show or contractor.
Thanks in advance for any help/info.
ATHC is offline
Old 07-23-2006, 03:29 PM   #2
Moderator
Double-A's Avatar
Re: Vertical Router For Windows
http://www.sawtrax.com/
I'm not sure this is the set-up he used, but you might ask them.
New York Times, July 20, 2006
Double-A is offline
Help with - Inside corner trim for vertical cedar siding wallmaxx Framing 3 07-22-2007 06:47 PM
Vertical Cedar Channel Rustic.. RISENRUN Carpentry 2 06-20-2007 12:46 PM
Mortising doors, hinges - router template? MHMConstruction Finish Carpentry 11 06-07-2007 11:16 AM
In the market for a new router jensenconstruction Tools & Equipment 7 09-05-2006 07:34 AM
Thou Shalt Not Laugh - Anyone Own A Model 691 Porter Cable Router CGofMP Tools & Equipment 5 04-19-2005 08:40 PM
