Trade: roofing
Unusual Vinyl Siding Request----opinions
we are installing cedar boards by certainteed on a home; the siding with the insulation attatched like the crane. anyway,its 3/4 inch insulation and the homeowner still wants us to put up insulation board. no matter how thin the extra insulation board is,it will cause much more labor because we would have to build out corners and everything else. i already told the guy that he has toi draw a line in the sand somewhere because you only need so much insulation.
Re: Unusual Vinyl Siding Request----opinions
doesn't sound like a big deal to me. if your using vinyl corners they will just go over the foam and use longer nails. If you are making your own corners out of aluminum you just gotta use some 2x3 or 4 not really a big deal.
Location: Down a dirt road through the trees, away from the mysteria !
I would offer to check and fill the walls with blow-in insulation.(thick exteriors make me nervous)
Is this for a green issue 'cause if the guy is just going for energy cost. I'm guessing it would take 30+ yrs.to recover the L&M cost of the extra insulation. Just my thoughts |
Siding Windows Doors
Trade: Exteriors
We use foam underlayment with all vinyl and polymer sidings including Crane Board, Cedar Boards and Structure to flatten the wall for the new siding. We dont use foam underlayment on new construction.
Windows Plus
Trade: Replacement of windows,siding and doors
insulated boards where the insulation is attached ot the panel is a good choice
#6 | |
Trade: Exteriors
Re: Unusual Vinyl Siding Request----opinionsQuote:
de-laminate giving it an appearance of oil canning. Alcoa Structure with the Dow Styrofoam was probably the best of this type of siding but is now made the same as all the others. |
Cant look any worse than all the houses done with lake forest. I got a notebook full of those that im saving in case i get slow.
Trade: Exteriors
Your so right about Lake Forest. We tried to steer people away from Lake Forest back in day because the Kynar had problems and the 7 hunter units of fade warranty meant that the panel had to fade to base layer. I have seen many Lake Forest jobs that are now just base layer or a totally different color on each wall in 12 years instead of lifetime.
Trade: vinyl decking railing fenceing siding windows
since the 80's technology has really made a difference in the lamination process and in the fadeing or lack of technology!
#10 | |
Trade: Exteriors
Alcoa only pays $125.00 a sq to remove and replace plus a disposal fee in my area. Its hardly worth our time to pursue. We only do warranty work for our customers as a service as we really don't make any money at $125.00.
If you complain enough, they will pay your normal labor rate.
Trade: Exteriors
Gentek has droped the labor to $85.00 per sq. for remove and replace. You can get $125.00 by complaining. If you order an extra box thats another $250.00 labor plus a box of siding that you may not want.
Gentek denied one of my customers waranty, which most manufactures do, so the home owner called and talk to Glen Isom who OKed 8 sq. of siding when the home owner agreed to install it himself. This put us in a position of "look I got the siding for free and I need you to install it for free". This home is in a very nice area and to avoid problems we scheduled it in. Now all the Alcoa, Mastic, Napco and Veriform waranties will be subject to Gentek replacement policies. |
| condensation behind vinyl siding | fieldsj | Windows, Siding and Doors | 8 | 12-27-2011 08:18 AM |
| Siding: Aluminum vs. Vinyl | Grumpy | Windows, Siding and Doors | 21 | 03-30-2010 08:02 PM |
| removing egg from vinyl siding | Zeebo | Painting & Finish Work | 14 | 03-23-2010 11:19 AM |
| vinyl siding replacement | Rick26 | Windows, Siding and Doors | 117 | 03-21-2010 11:27 PM |
| Vinyl Siding Price | joyh23 | Windows, Siding and Doors | 28 | 09-04-2009 07:54 PM |
