#21 |
Trade: carpentry
Re: Uneven Ground Siding Questionthe oversized starter that i have used is steel. very rigid. sorry sidingpro-don't see how homemade starter can be cheaper or better.
#22 |
Thats what we do on rainy days. or if i run out. I have been running L bend on the bottom of a lot our walls to cover all the crap under the siding.
#23 | |
Re: Uneven Ground Siding QuestionQuote:
Sounds like a good alternative to using J-channel at the bottom of any panel.There's nothing I hate more than seeing the overuse of J to remedy the use of a shortened course of siding or around overhangs or ornamental details that are left for aesthetic purposes. There's a technique I use sometimes for the bottom courses that seems to work well when wide starter can't be used.It's a little labor intensive,but the results look good: I'll run regular starter and then the bottom half of a panel with nail slots punched in the top for movement,and proceed with another starter at the line I need above it,making sure it covers the nail slots.The width of the bottom panel needs to be adjusted so that the nailing the second starter doesn't go through the bottom panel. This way you can control the amount of drop below the existing foundation or in cantilevered walls.It comes in handy over protruding stone foundations and when using vinyl shakes or claps in a stepped foundation. The less J used ,the better the job will look!
https://www.facebook.com/pages/John-...94183374011504 |
#24 | |
Sophisticated Siding Guy.
Trade: Siding and Trim Specialist
I have at all times atleast 20 open half used rolls of coil. We use up left overs in random colors we don't need since the starter gets covered up. So really it's free if think about. I like bending it because every house is different. Sometimes a 4" piece of starter works fine. Sometimes you need a 10" piece and a ramset to drop lower on the concrete. It takes no time break down starter and even the new guy can do it. Last edited by thesidingpro; 04-11-2008 at 10:59 AM. |
#25 |
Siding Windows Doors
Trade: Exteriors
Maybe you could bury the bottom of the siding and eliminate the starter all together on this one.
#26 | |
#27 |
Pigs In Pearls!
Trade: home improvements
Re: Uneven Ground Siding Question |
#28 |
Trade: carpentry
Re: Uneven Ground Siding Questionyou are right sidingpro--siding is not what i do full time. We do side our own houses and do quite a bit of replacement windows jobs. I am just trying to learn any improved method that I can to help in our installation. We usually use white coil when wrapping windows, so I guess that is where we use our leftover coil.
Had a question though--why bend a 10" starter if you are going to ramset it to the concrete anyway? |
#29 |
Well your right you don't have to....
If I'm dropping it 6" below the plywood onto the concrete I still like to grab some wood so I make my starter bigger. It's a lot easier to line it out while nailing into the wood. Once Have it where i want I can then just pop a couple ramsets into it and not worry about it moving.... I mainly use pvc coated trim coil. Not the cheap smooth stuff that has white on the back. The good stuff normally just gray on the back....So it's only one color. |
#30 |
Trade: carpentry
Re: Uneven Ground Siding Questionthat makes sense now on bending tall starter. good idea.
We use the pvc coil also on occasion. We were always under the impression that is was so expensive, but our supplier has it for only $5 more per roll. I suppose if you use a large quantity that would make a difference, but we do not use that many rolls. That stuff sure is nice to wrap with though!! |
#31 | |
But this the roofing and siding business so Im not all that surprised.
| hanging certainteed cement siding | PROJECT MAN | Windows, Siding and Doors | 46 | 09-27-2010 10:46 PM |
| Paint on cedar siding peeling. | gideond | Painting & Finish Work | 19 | 05-03-2008 08:53 AM |
| unique siding job - HELP | tool junkie | Windows, Siding and Doors | 28 | 02-01-2008 12:09 AM |
| Well, THAT'S a different ground wire! | rhinoguy | Electrical | 5 | 04-01-2007 01:21 AM |
| Question About Hardi Lap Siding Installation | slbrown | Windows, Siding and Doors | 19 | 05-08-2006 02:18 PM |
