TYVEK Vs Felt Paper--which Is Better???
Old 02-27-2012, 03:47 PM   #101
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
Re: TYVEK Vs Felt Paper--which Is Better???
from what?
Tom Struble is offline
MJW (02-27-2012)
Old 03-21-2012, 01:51 AM   #102
KZQ's Avatar
Trade: Fenestration
Rewards Points: 29
Originally Posted by alecifel View Post
I suppose in New Jersey and other nothern climates where the sun is a stranger, you can get away with it. If you try to side a house with vinyl over asphalt in the southwest, you're going to have a wrinkled mess although it usually doesn't come up until the warranty period's over.
Vinyl doesn't work in the high desert of Oregon although it doesn't have anything to do the the tar paper that might be beneath it.
Bill
Accredited Instructor for the Installation Master's Institute. http://www.installationmastersusa.com/
KZQ is offline
Old 03-21-2012, 02:56 AM   #103
I eat sawdust.
Winchester's Avatar
Trade: Deck Design/Build
Rewards Points: 2,000
Okay, the eternal argument lives on.
Just use both.
Problem solved
Winchester is offline
Old 03-21-2012, 12:30 PM   #104
hammer 689's Avatar
Trade: general contractor
Rewards Points: 83
i have always been a 30# felt guy.i would not ever use tyvek here on the oregon coast.i tore apart a six year old siding job that you could put your hand thru the wall.sheeting,tyvek and lots of the framing were shot.it was behind cedar 105 pattern channel siding that was primed on the back.not just blaming the wrap and it may work with a rain screen but when you have wind driven rain of up to 100 mph water is going to get back there especially with channel siding that laps 5/8 of an inch.i have now started using hydrotex because of the rain screen code here.i think 30# still passes drain test here but the code seems iffy on it.so to me it depends on the climate and type of siding.tyvek may work great in some applications but i wouldnt use it where i live.im even having a hard time switching from felt to hydrotex.
hammer 689 is offline
Old 03-21-2012, 07:27 PM   #105
Trade: siding
Rewards Points: 4
one day they will tell you what you can use and if it can't be taped as an airbarrier i bet you will not be able to use it
Old 04-15-2012, 04:19 AM   #106
ultimatedecks's Avatar
Trade: deks & siding
most repairs I've done the ty-vek almost always has mold and mildew behind it,(I know bad installation) felt paper works better, I've just seen a new spray on product looked impressive
ultimatedecks is offline
Old 04-15-2012, 09:50 AM   #107
Trade: siding
Rewards Points: 4
and you don't think there is mold on the felt?
Old 08-11-2012, 11:33 PM   #108
Eaglei's Avatar
Trade: carpenter & Masonry
Rewards Points: 1,510
Anyone use zipwall, i think its air and weather resistent. I used it up in the catskills in the dead of winter knowing the siding wouldnt go up untill spring.Up on top of this mountain it is extreamly windy ,didnt have to worry about it blowing off,as you would with tyvek or felt. Sealing the joints with zipwall tape is a bit pricey and needs to be put on with a heat gun if its very cold, which it was.The owner took to the idea and loved the results.
Eaglei is offline
Old 08-16-2012, 07:36 AM   #109
Brian Peters's Avatar
Trade: remodeling and some new construction
Rewards Points: 972
I've used it and like it. Doesn't seem to swell around windows and door cut-outs like standard OSB does either.
Brian Peters is offline
Old 11-03-2013, 04:52 AM   #110
zmusashi's Avatar
Trade: carpentry, remodeling
Rewards Points: 41
Its been over a year but this is a fantastic thread, thanks everyone involved. Going into a job with full replacement windows and clapboard here in CT on one entire wall. No house wrap at all on this 1983 home- actually roofing felt was installed in strips only behind the window trim and at corner boards, so far as I have seen. A tricky question is posed by the full plastic/ poly sheeting used as a vapor barrier on the interior of the home, over the framing and batt insulation which in some places has kraft paper facing and in other places does not. The house has many issues and was built poorly, the worst construction I have ever seen. Anyone have any ideas about*felt paper vs. Tyvek or other house wrap, given the full plastic interior vapor barrier? Here in the Northeast we're supposed to allow moisture to dry to the inside, but how can it? It'd get stuck in the walls or wait to evaporate to the exterior. PS I like to stick with felt paper too but knowing the real science of why is important. Also I've generally seen felt paper in great condition doing renovations, even on old houses, occasionally decrepit where water damage was occurring.
zmusashi is offline
Old 11-03-2013, 06:35 AM   #111
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
I've only seen a few homes done with poly on the inside and they all had issues. I think the problem lies with the change of seasons we are subject to here.
We can dip well into the single digits in the winter and have had days over 100 in the summer. We also experience a wide range of relative humidity here.
We are currently working on a building that is about 8 years old. The buyer wanted about 50 squares of wire and stucco removed to make way for fiber cement siding.
There were strips of Tyvek around the windows, but the building was papered with 1 layer of #30 felt. The house sits on a pond, just inland of one of the Jersey Shore barrier islands.
There were 3 locations of plywood damage, all under windows and all where there was a reverse lap at the felt/Tyvek under the windows. It was very minor, but there was plywood rot.
I personally believe that if any of the synthetic wraps that depend on water vaporizing before it can pass through it were used, the damage would've been much worse.
TYVEK vs Felt paper--which is better???-img_20130903_122402_442.jpg   TYVEK vs Felt paper--which is better???-img_20130903_122500_006.jpg
loneframer is offline
The Following User Says Thank You to loneframer For This Useful Post:
zmusashi (11-03-2013)
Old 11-03-2013, 07:56 AM   #112
Dirtywhiteboy's Avatar
Rewards Points: 7,584
felt paper
Dirtywhiteboy is offline
Old 11-03-2013, 09:29 AM   #113
Trade: siding
Rewards Points: 4
check out Hydrogap http://www.benjaminobdyke.com/visito...t/key/hydrogap
where I think the market is headed is to a fully adhered or fluid applied systems,at least as far as new construction is concerned
http://henry.com/airandvapor/vaporpermeable/blueskinvp
Brian Peters (11-03-2013)
Old 11-03-2013, 12:08 PM   #114
zmusashi's Avatar
Rewards Points: 41
Thanks Tom and others,
I am looking at these links now, appreciate it.
zmusashi is offline
Old 11-04-2013, 06:17 PM   #115
Smithanator's Avatar
Trade: General contractor
Rewards Points: 274
Tom have you use this hydro gap stuff? What is its air sealing abilities ?
Smithanator is offline
Old 11-04-2013, 07:29 PM   #116
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,426
Hey everyone thanks...this is a good educational thread...
Shoot, I had no idea there was any performance characteristics between Tyvek and Typar etc. ... and I assumed they were both superior to felt......
(I thoght the only advantage to felt was that I couldn't put it on upside down )
Best
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
Old 11-04-2013, 08:29 PM   #117
Trade: siding
Rewards Points: 4
comparable to other drainwraps,air sealing a building does not begin or end at the wrap,it's just part of an overall air sealing strategy that has to start from the bottom plate to the top plate.
I am on the Benjamin Obdyke innovation council to help develop their wrb/flashing products,they have been working on a pre taped version that takes the tape out of the drainage plane
EricBrancard (11-04-2013)
Old 11-04-2013, 08:40 PM   #118
KemoSabe
loneframer's Avatar
Best
Felt is the ONLY wrap that I'm aware of that is capable of "variable permeability". In other words, as the moisture level rises, it becomes more permeable, allowing for faster, more efficient drying.
MTN REMODEL LLC (11-04-2013)
Old 11-04-2013, 08:46 PM   #119
You mean pre-taped on the wrap...... interesting but seems not to practical.... but maybe there is more to it....
has there been any empirical evidence of external tape (tape not in the drainage plane) failing....???
Old 11-04-2013, 08:58 PM   #120
Rewards Points: 274
How does it compare with tyvex protecting from air infiltration ?
The Following User Says Thank You to Smithanator For This Useful Post:
Irishslave (02-20-2016)
Leveling with roofing felt and leveling compound DIA-jp Flooring 29 01-22-2013 09:19 PM
Tyvek under 1/4in foam for Vinyl siding? PittTrack Windows, Siding and Doors 66 06-22-2012 01:56 PM
New Tyvek over old Tyvek? Jer Windows, Siding and Doors 36 08-27-2009 10:11 PM
Rosin paper or roofing felt? Mike Finley Flooring 35 01-06-2009 03:06 PM
Felt paper used as insulation??? Age General Discussion 9 06-10-2006 04:25 PM
