#41 | |
Trade: General Contractor, Roofing, siding, windows
Re: TYVEK Vs Felt Paper--which Is Better???Quote:
Weather, direction, materials, EVERYthing plays a factor..........Although we had one inspector say, "well you don't have to go overboard...you can apply some common sense" Common sense!!!! That left the building when we decided to let people make building codes that sit at a desk all day. Some of this stuff, I tell ya.....
#42 |
Trade: general contractor
wont the felt paper get too hot and warp vinyl siding. vinyl is what most people around here use.
also we are told not to tape/flash the bottom of the window so any moisture can get out from behind the tyvek. we mostly use typar on our jobs, but alot of builders use tyvek. i havent seen any one use felt paper on walls in a long time |
#43 | |
KemoSabe
__________________________________ "Walking the fine line between production and perfection" __________________________________ Last edited by loneframer; 08-15-2009 at 06:53 AM. |
#44 |
KemoSabe
few more
#45 |
Trade: siding
that was just a way for the supplies to push house wraps,they also said that about reflective layers on foam
Tom |
#46 |
thats good to know about the felt
just wonder what the manufactures of housewrap say? and if they have us around their little finger |
#47 |
Trade: siding
i can agree with that ************
Tom |
| The Following User Says Thank You to Tom Struble For This Useful Post: | Sidingmaster (07-25-2009) |
#48 |
Trade: Pretty much anything with wood
As felt gets wet its permeability gets better. I'm still not sure what I prefer using. I think if your are going to wrap a house and have it sit for awhile before sididng, then your best bet is house wrap. It just holds up better. But, if you are going gang busters than I'd use 30# felt. All air sealing should be done at the sheathing anyway, not house wrap. I try to install rain screen on any siding I do, and I'm slow so I usually end up using house wrap. I don't do vinyl or aluminum siding.
#49 |
Trade: renovations
Does felt not tear extremely easy, making it an inferior product by having penetrations.
#50 |
Trade: siding
installation is the key,what type is less important
Tom |
#51 |
Trade: framing/roofing
I use felt 90% of the time. Never had a problime.
(exept with my spelling )
#52 |
Trade: General Contractor, Woodworker
Felt can take and release moisture- meaning if (when) moisture gets behind it, that moisture can escape.
Felt is organic- it will deteriorate, but mostly if it gets a cycle of wetting and drying. That's a good way to tell where leaks are. 60 minute paper is not the same thing as felt (asphalt impregnated felt). 60 minute paper is asphalt impregnated paper, and has a tested rating for water hold-out. Tyvek and the like have gotten much better over the years. They are primarily better as air barriers. Most of the building papers are still more subject to surfectants than felt. If water gets behind them, they don't do as well at allowing it to escape before the sheathing is damaged. Adding an air space, either a drainage plane or a (much more difficult) rain screen increases performance of any of the materials. I believe the space reduces vapor drive through the WRB and reduces water pressure when water gets through the siding. All require flashing. All flashing has to be done in a weatherboard manner. |
| The Following User Says Thank You to lavrans For This Useful Post: | Tom Struble (10-09-2010) |
#53 |
hurtlocker
Trade: homebuilder remodeler carpenter
When using tarpaper with vinyl
Has anyone had any problems with staining |
#54 |
Trade: siding
here's something that happened to felt that ive never seen happen to tyvek,second two pics are on a job i was helping a buddy set pole up
i couldn't believe my good eye ![]() dam camera sorry about the crummy pics,camera was set to macro
Tom Last edited by Tom Struble; 10-09-2010 at 08:51 AM. |
#55 |
Trade: siding
i have seen almost like a tar ''vapor'' trail coming from the bottom weeps on vinyl over felt
nice to see the great Lav offering his opinions on this ![]()
Tom Last edited by Tinstaafl; 10-09-2010 at 12:43 PM. Reason: Merged two posts. Practicing. |
#56 |
Ok I'm gonna use a layer of each
#57 |
Trade: siding
don't laugh,double wrb is something ive thought about,and that's a great question
having an extra layer,like they do with masonry work,would be a better choice with reservoir cladding if your not going to use a rainscreen,not saying it would replace it,but sometimes a rainscreen ain't in the cards and this i think is a better alternative to using just 1 layer maybe with felts variable permeability,its not much of an issue i think i would go with the synthetic as the outer wrb because of its greater uv and tear resistance but the thing with felt is when its exposed to moisture it ''wrinkles''and these wrinkles are what gives the air space that you like to see behind any siding so maybe that should be first....what ya think?
Tom |
#58 |
For that reason and the fact felt is so stiff I would do the opposite.
| The Following User Says Thank You to Tom M For This Useful Post: | Tom Struble (10-24-2010) |
#59 |
Trade: Windows Doors Siding
Drain wrap , furring strips? Air gap ?
WWW.EXTERIORMOTIVESCONSTRUCTION.COM |
| The Following User Says Thank You to EMDC For This Useful Post: | Tom Struble (10-24-2010) |
#60 |
Trade: siding
yup drain wrap yup
Tom |
| Tyvek under 1/4in foam for Vinyl siding? | PittTrack | Windows, Siding and Doors | 65 | 03-06-2011 10:16 AM |
| New Tyvek over old Tyvek? | Jer | Windows, Siding and Doors | 36 | 08-27-2009 10:11 PM |
| Rosin paper or roofing felt? | Mike Finley | Flooring | 35 | 01-06-2009 03:06 PM |
| Leveling with roofing felt and leveling compound | DIA-jp | Flooring | 18 | 12-15-2008 01:09 AM |
| Felt paper used as insulation??? | Age | General Discussion | 9 | 06-10-2006 04:25 PM |
