#21 | |
Professional Instigator
Re: TYVEK Vs Felt Paper--which Is Better???Quote:
#22 |
Trade: Exterior Finishing
I might not be driving the felt paper bus but I'm on it!
Felt doesn't mean anything over here though... Tar paper if any of you plan on moving... Or switching citizenship! |
#23 |
Ps. Any one call it 30minute paper? Or 30min paper?
#24 |
Trade: roofing
HOWEVER, WILL 30 LB FELT PAPER ALLOW MOSITURE TO ESCAPE LIKE TYVEK WOULD? I think we would want that for mold prevention?
#25 |
KemoSabe
Tar paper actually allows moisture to escape better than Tyvek. Tyvek traps moisture until it evaporates, then it will pass through. Felt paper will expand and wick moisture through in liquid form.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
#26 |
Trade: roofing
felt paper has tiny holes for moisture to escape like tyvek does?
#27 | |
KemoSabe
There has been much testing done and asphalt saturated felt paper has been proven to transfer moisture between the sheathing and housewrap better than Tyvek. Felt paper will actually expand in the presence of moisture and become more permeable, allowing for better drying. This is known as hygroexpansion.
#28 |
Sometimes the wood tannins dissolve the tyvek too, like cedar. Can't even use it with cedar.
Josh Jaros www.jarosbros.com Remodeling in The Woodlands, Texas |
#29 |
Trade: Exteriors
Paper all the way............
#30 |
Nuf said. Settled.
#31 |
Trade: siding
most of my jobs are speced for tyvek,and i like the idea of felt and i do understand its advantages but ease of use and tear resistance make it the first wrb i reach for
#32 | |
KemoSabe
#33 |
Trade: siding
Re: TYVEK Vs Felt Paper--which Is Better??? thanks buddy |
#34 | |
Trade: General Contractor, Roofing, siding, windows
http://www.fortifiber.com/pdf/fortif...sk_vs_felt.pdf Last edited by MJW; 05-30-2009 at 09:57 PM. |
#35 |
The lack of flashing causes most problems. I'm surprised loneframer doesn't flash his openings.
Frank Slate Roof Repairs, Richmond, Va. |
#36 | |
KemoSabe
#37 |
Just standard flashing. I even detailed some of it on my site for newbies and homeowners.
http://www.albertsroofing.com/Window%20Flashing.htm
#38 | |
KemoSabe
I've seen what happens when siding trim isn't tabbed with flashing onto nailing hem, I go the rest of the way and flash the entire bottom flange of the window. As far as I have personally seen in 25 years, I'm one of two people who flash their windows, corners and soffit/siding intersections. I don't claim to be a professional sider, but I know I do a more thorough job than most of the "pros" in this neck of the woods. The fact that you made a claim that I don't flash my windows is insulting. As a framer, I offer dry-in as an option to the builder. It includes papering and some flashing details at deck and roof intersections. Upon window installation, I ask the GC what detail to leave at the sill location. Most prefer to leave the bottom flange unfastened so that the sider can incorporate his flashing detail as he sees fit. As for me personally, when the decision is mine to make, I always flash behind the bottom flange, 4" past each side and lap the flashing out onto the siding lock. Same detail happens where a fascia line meets a wall, flashing behind step flashing 18" out and lapped onto nailing hem on siding.
| The Following 2 Users Say Thank You to loneframer For This Useful Post: | bigbaby (03-15-2011), Tom Struble (06-04-2009) |
#39 |
It tyvek all the way over here.
From what i read about moisture problems with tyvek, and some great articles on felt, learned quite a bit about felt paper, thanks guys. This is why we strap our houses prior to putting the siding on. Not everybody down her does it, but about 85% of the builders do. If you give that barrier from your siding to your wall, you eliminate a lot of the water and moisture that can get at your house. I'm not saying you eliminate 100% of that moisture. It will always get in. Everything i hear about felt paper here, sorta turns my perspective on it. I personally thought it was the "Old Way" and was out-dated, and didn't offer the same quality's of tyvek. Boy was i wrong! -Bill
You laugh because I'm different........... I laugh cause I just farted! |
#40 |
Glad to hear you put metal under there. Word from the building department here is that they're going to adopt all my reccomendations soon. Not sure what that means, because they went overboard in Va. with my Ice and Storm specs a few years back. Now, they seem to want it everywhere..
Kinda scary what committees come up with.
| The Following User Says Thank You to tinner666 For This Useful Post: | Tom Struble (06-04-2009) |
| Tyvek under 1/4in foam for Vinyl siding? | PittTrack | Windows, Siding and Doors | 65 | 03-06-2011 10:16 AM |
| New Tyvek over old Tyvek? | Jer | Windows, Siding and Doors | 36 | 08-27-2009 10:11 PM |
| Rosin paper or roofing felt? | Mike Finley | Flooring | 35 | 01-06-2009 03:06 PM |
| Leveling with roofing felt and leveling compound | DIA-jp | Flooring | 18 | 12-15-2008 01:09 AM |
| Felt paper used as insulation??? | Age | General Discussion | 9 | 06-10-2006 04:25 PM |
