Trade: windows-siding
TYVEK Vs Felt Paper--which Is Better???
i saw a new house with felt paper under the siding rather than Tyvek.. what are some of the negatives of using black paper opposed to tyvek under vinyl siding?
thanks guys |
KemoSabe
Re: TYVEK Vs Felt Paper--which Is Better???
I see no negatives to using felt paper, we use #30 all the time. Many builders in coastal New Jersey have gone back to it. I have seen some problems with Tyvek deteriorating. Tar paper on my own house and almost every one I've built in the last 15 years.
__________________________________ "Walking the fine line between production and perfection" __________________________________ Last edited by loneframer; 08-15-2009 at 06:55 AM. |
Trade: framing/remodeling
Might be a regional thing. Nobody here uses felt for anything other than roofing and even that is getting rare. Most roofs we use a product called Titanium UDL. No more rips and we have yet to have a piece come off the roof under any weather. Tyvek needs to be installed correctly in order to work properly.
KemoSabe
That would be one of the major causes for problems, noone takes the time to flash and counterflash properly, either Tyvek or felt paper. I have opened up walls with both products on them, I prefer what I saw with tar paper.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
We use tyvek too, and i agree no one flashes. But today i went out to help side a 20x30 garage and they had visqueen... supposed to be a well known builder too :/
solar guy
Trade: solar contracting
Re: TYVEK Vs Felt Paper--which Is Better??? |
I like Green things
I use tar paper as well.
The stuff never deteriorates. Its visqueen here too. |
what are the advantages of using 30 lbs felt over 15 lbs?
when would using 30 lb be more approriate than using 15 lbs? why is felt preferref over Tyvek? thank you |
The nice thing about the felt is the variable perm that allows the moisture to escape if it does get trapped behind the wall.
Josh Jaros www.jarosbros.com Remodeling in The Woodlands, Texas |
Trade: Residential remodel
Tyvek allows moisture out, but prevents it from coming in...felt is the old way.
I found this interesting in regard to the thread. http://bct.nrc.umass.edu/index.php/p...ky-housewraps/
#13 | |
KemoSabe
Re: TYVEK Vs Felt Paper--which Is Better???Quote:
KemoSabe
Great point. I have seen literally hundreds of houses stripped of Asbestos siding that had 15# felt under it. They were built in the 1950s and 60s, the felt was in perfect condition. I've opened up houses built less than 5 years previous and the Tyvek was shreaded like old newspaper. I'll stick with tried and true felt paper.
| The Following 10 Users Say Thank You to loneframer For This Useful Post: | dprimc (10-30-2010), GDRj1mro (03-08-2011), joasis (07-24-2009), lavrans (10-09-2010), Metro M & L (05-10-2011), rbsremodeling (05-22-2009), rojigga (05-22-2009), rustyjames (05-22-2009), skipdow (10-24-2010), Tom Struble (05-22-2009) |
Professional Instigator
Real men use felt paper.
KemoSabe
That is all that needs to be said.
#17 | |
KemoSabe
#18 |
Yep. I don't care what they say you 're alright with me
#19 |
Lack Of All Trades
Trade: Professional handyman services
I think the largest difference between Tyvek and felt paper is that Tyvek is much faster to wrap a house with.
I prefer felt paper. Just a tried and true material. |
#20 |
KemoSabe
Much of what they say is true, exept for the surgical procedure that Gus Dering eluded too.
BTW, you my favorite pimp.
| Tyvek under 1/4in foam for Vinyl siding? | PittTrack | Windows, Siding and Doors | 65 | 03-06-2011 10:16 AM |
| New Tyvek over old Tyvek? | Jer | Windows, Siding and Doors | 36 | 08-27-2009 10:11 PM |
| Rosin paper or roofing felt? | Mike Finley | Flooring | 35 | 01-06-2009 03:06 PM |
| Leveling with roofing felt and leveling compound | DIA-jp | Flooring | 18 | 12-15-2008 01:09 AM |
| Felt paper used as insulation??? | Age | General Discussion | 9 | 06-10-2006 04:25 PM |
