#41 |
Trade: Pretty much anything with wood
Re: Tyvek Under 1/4in Foam For Vinyl Siding?
I wouldn't do any of your options. I would pull old paper off. Put 3/4" or thicker EPS foam treated with borate for bugs over sheathing. Then I would either tyvek or 30# felt the house, then run 1/2"-3/4" vertical pt strapping over house. Install windows on strapping, then apply siding. Your screwed on a air barrier at this point anyway. And trying to use tyvek as an air barrier by taping the joints is useless. If the house is sheathed in ply you could use Grace WB primer on all ply joints and cover them with 4" vycor. Have to remove corner boards too, but you'll still have air leaks at rafter tails, sheathing to wall plates, mud sill, rim joists, etc.
#42 |
Trade: siding
ive pulled off vinyl on alot of houses and haven't found issues in the field, any problems i saw was the result of missing flashing or reverse lap wrb, i understand the advantages of a rainscreen but you can be just as successful with out one
Tom |
#43 | |
Trade: siding
Re: Tyvek Under 1/4in Foam For Vinyl Siding?Quote:
why would you put your windows on top of the strapping?The nail fin should be integrated with the wrb not sticking out from it imo
Tom |
#44 |
If you are using aluminum clad or vinyl windows, they will look like ****e if the casing is technically sticking past them 1 1/2". It is fine to install them on the strapping just have to put drip cap on the house before the strapping. Takes some planning, but can be done.
| The Following User Says Thank You to Morning Wood For This Useful Post: | Tom Struble (06-11-2009) |
#45 |
Trade: siding
i personally dont like my window frame to stick out or be flush with my casing,i prefer my casing to be proud of the window
My understanding is vinyl siding should not be applied directly to furring/studs unless foam or ridged sheathing is applied over or in between them,a continuous smooth surface is what vsi says
Tom Last edited by Tom Struble; 06-12-2009 at 07:57 AM. |
#46 |
Trade: General Contractor, Roofing, siding, windows
We are doing a job right now with these practices. Fanfold over the Tyvek with a cheap vinyl on top of it. A "master craft" sman.......company did the job. It was terrible and I'll have pics up later.
Anyways, we tore all of it off and are replacing with greenguard paper and re-siding with .046 Revere vinyl. Inpspector said no to the fanfold over the Tyvek, so make your own conclusions from that. I agree the fanfold is almost useless as far as insulating. Especially being on the outside of your felt or wrap. |
#47 | |
Trade: new construction and remodling
I am sure you have heard of this test - take a cup of McDonalds coffee - its 160+ degrees. Hold it in your hand. Notice your hand is not on fire. That is a thermal break. Wrapping your house with fanfold gives you that benefit throughout. |
#48 | |
Trade: siding
huh?
Tom |
#49 | |
KemoSabe
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
#50 | |
For instance I replaced our 80% furnace and gas water heater with a 95% externally vented furnace and tankless water heater. The air that used to sneak in past cracks and go up the flue with internal moisture and "ick" now does not occur. My house needs artificially induced leakage. |
#51 |
Smart phone? Scan me!
Trade: Painting/Framing/Drywall
that is what my refrence was to the steam coming out one way, and not the other from the tyvek reps back in the 90's was all about. did they come out to your job site doing the same?
#52 |
Trade: windows-siding
Crane's insulated siding is very permeable and treated with boron(for bugs).. why does'nt anyone employ this sort of siting,at least the insulation is able to breath and pass water vapor..would'nt this solve the problerm..
remove the old tar paper,install tyvek,then install insulated siding where the insulation is permeable. |
#53 |
Trade: green building
I've always used tried and proven tar paper; that said, I don't think anyone has mentioned "surfacants" in this thread. I've got an article in my files somewhere that says Tyvek will fail if it gets contaminated with "surfacants". Of the various possible sources I only remember two (1) mud splatter and (2) tannins, but there were others mentioned.
If the conditions at the site are within design specs, the products I looked at (a few years ago anyway) said in the instructions that it's fanfold under Tyvek. Of course, that's according to the engineers who made the products. If the conditions at the site are not within design specs, then better do something else. In that case, one option is to second-guess the engineers by reversing the products, sure. I know a lot of you have done that without any apparent problems showing up (yet anyway). I'm of a different mind. Seems to me that the products should be installed as the engineers intended, and if there's beyond-design spec moisture from inside a house it needs better HVAC design, or from outside the house it needs better flashing, site drainage, gutters, and maybe a rainscreen (or get relocated under a superdome). But as I said, I still use tar paper & careful flashing, sometimes over foam. My wife says I'm a Luddite. Steve |
#54 |
agree on the insulated siding.
#55 |
Trade: siding
lol try to get 2 engineers to agree on anything
Tom |
#56 | |
Steve, If you are building with a single layer protection scheme there is probably no real difference where you put the single wrap layer but I think Tyvek says differently that what you may remember having read. Here is a Tyvek document - www2.dupont.com/Tyvek_Construction/en_US/assets/downloads/InstallGuideWRB_K16282.pdf From the "Facade Considerations" area ( bottom of document ) Stucco: Rigid foam board, when installed over DuPont™ TyvekŪ water-resistive barrier as an intervening layer, will provide enhanced structural support to the DuPont™ TyvekŪ layer.... Stone: When two layers are required by code and DuPont™ TyvekŪ water-resistive barriers are used behind stucco, they should be separated from the stone and mortar by a second layer of DuPont™ TyvekŪ water-resistive barrier, a layer of grade D building paper, felt, rigid foam board or the paper backing of paper-backed lath. The first layer (directly over sheathing or studs) serves as the wall system’s water-resistive barrier .... ( sideways reading between lines here says house/sheathing[if present]/tyvek/foam/something else ... ) So I think the Tyvek docs are suggesting first layer of wrap goes under foam if it is present .. unless perhaps you are using the foam as the sheathing. And also ( and it is buried ): For superior protection against bulk water penetration, DuPont suggests a system combining a quality exterior facade, a good secondary WRB, an exterior sheathing, appropriate flashing materials and details. The secondary WRB is the drain/rainscreen which is both a good idea and likely part of code depending on actual exterior finish. I'm sorry but I don't think you can get this type of holistic envelope protection with just a layer of felt paper and flashing |
| The Following 3 Users Say Thank You to kansas-builder For This Useful Post: |
#57 |
Thanks for the interesting stone/stucco/tyvek info, KBuilder. I don't know squat about masonry applications and no doubt the products keep getting tweaked as technology marches on. I'll have to rethink my ways when we start seeing 50-year old Tyvek applications that are still holding up.
Steve |
#58 | |
Trade: siding
Tom Last edited by Tom Struble; 06-17-2009 at 09:41 AM. |
#59 |
Trade: Exteriors
Get rid of spruce for building and go back to fir......
the crap starts rotting at such a low moisture content ... OSB at 17% .... works great in wet climates ![]() I think the tyvek verses paper debate will go on and on... Myself I have used paper for 18 years and never had a problem with it and will use it over tyvek anyday of the week just my 2 cents. |
#60 |
Trade: siding
ive used tyvek since it came out and ive never had a problem with that either so...
Tom |
| New Tyvek over old Tyvek? | Jer | Windows, Siding and Doors | 36 | 08-27-2009 10:11 PM |
| siding an old house | gtmstang | Windows, Siding and Doors | 14 | 12-20-2008 06:21 PM |
| Siding and Insulation | Jaketoo | Carpentry | 12 | 12-10-2008 03:36 PM |
| OSB with rigid foam board factory attached | im4snow | Framing | 1 | 10-29-2008 09:22 PM |
| log cabin vinyl siding | Home Serve | Windows, Siding and Doors | 6 | 04-28-2008 08:16 AM |
