Tyvek And Tyvek Taping Around Windows (new Construction)
Old 05-19-2011, 02:25 PM   #1
zconstruction's Avatar
Trade: Contracting/Carpenter
Yes I'm building new home here getting here ready install the housewrap. wondering if anyone knows. What is the tyvek recommened way of cutting around window opening in rough framing stage? The the taping of the sill or not?, and taping of window flange, just the sides then top?
zconstruction is offline
Old 05-19-2011, 02:29 PM   #2
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
Re: Tyvek And Tyvek Taping Around Windows (new Construction)
http://imgs.ebuild.com/xCat/ebuildWe...riant=Original
festerized is offline
Old 05-19-2011, 02:31 PM   #3
David Festa
festerized's Avatar
opps wrong 1
Old 05-19-2011, 04:12 PM   #4
Anti-wingnut's Avatar
Rewards Points: 3,310
Start here, and google the rest yourself
http://www2.dupont.com/Tyvek_Weather...ation_4_08.doc
Anti-wingnut is online now
Old 05-19-2011, 07:57 PM   #5
rock16's Avatar
Trade: Commercial Exteriors & Multi Family Remodel
Rewards Points: 274
One school of thought
rock16 is offline
The Following User Says Thank You to rock16 For This Useful Post:
Tom Struble (05-20-2011)
Old 05-19-2011, 08:12 PM   #6
kubie's Avatar
Trade: general contractor
Rewards Points: 278
just had a tyvek class last year
u cut the tyvek along window opening
then tyvek tape the tyvek around right and left sides(tape tyvek....around the sheeting to the framing( so if you foam your windows, the foam insulates to the window and not get behind the tyvek)
then use the sill tape on bottom of opening, pushing tape into the corners
then cut like a 2" diagonal cut on top inside corners of tyvek to make a flap like this \________/
install window
flash tape right/left side over flange to tyvek
flash tape top flange(folding up tyvek so u can flash tape to sheeting)
last fold down tyvek and tyvek tape tyvek to flashing tape and tape over the diagonal slits so that your cuts are covered
no flashing or tyvek tape on the bottom, if water ever gets behind your flashing, water has a chance to get out
hope that made sense, hard to explain with pics......sry
kubie is offline
The Following User Says Thank You to kubie For This Useful Post:
Old 05-19-2011, 08:42 PM   #7
BrotherBunyan
KMR's Avatar
Trade: Construction Management, student, laborer
Rewards Points: 75
Yeah what kubie said
I also had a class that covered proper wrApping. And with the windows he explained to cut the opening like an hour glass a v at the top and an upsidedown v at the bottom being connected by a straight line cut. Then the tape on the sides first and finally across the top. Of course after the window is installed too.
Just think like water.
Sent from my iPod touch using CT Forum
I do not fear that i will be a failure, but successful at that which does not matter.
KMR is offline
Old 05-19-2011, 08:54 PM   #8
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
i dont use tyvek tape to seal windows. ill slash the tyvek as most do folding it in and stapling it down to the sil then the sides.
from there i use 6" vycor and do a sil pan, the peice is cut about 6" longer than the r.o. i set it to the sil about 3" in from the edge and then up the side, from there i cut a slash 1" up from the sil then fold it out and around to the outside which creates a trough effect. then the window gets set into a bead of caulking at the sides and top then i tape the sides and top nailing flange with 4" vycor. now if vinyl is going on i cut the tyvek along hte top of the nailing flange so the vycor can tuck up under neath, if its getting wood siding i simply vycor over the rain screen furring, after teh wood trim goes on the metal cap flashing gets installed which get s tucked up under the tyvek
woodworkbykirk is offline
Old 05-20-2011, 06:47 AM   #9
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
tyvek also has their own flashing tape Kirk,it may be what was meant
''think like a drop of water'' i've heard this a long time ago,but i think it's the wrong way to think
differences in air and wind pressure,capillary action and water adhesion can make water do things it never thought it could
maybe we should strive to be just a little smarter than a drop of water
Tom Struble is offline
The Following 3 Users Say Thank You to Tom Struble For This Useful Post:
ccappaul (05-21-2011), Chris@Sunrise (05-22-2011), nEighter (05-23-2011)
Old 05-20-2011, 08:41 PM   #10
kubie's Avatar
Rewards Points: 278
yeah this is the flashing tape and the sill flashing
http://www2.dupont.com/Tyvek_Weather...g_systems.html
this is the tyvek tape
http://www2.dupont.com/Tyvek_Weather...seam_tape.html
kubie is offline
Old 05-21-2011, 07:40 AM   #11
Thanks to all for the help. I'm gonna cut top to be a flap then. One thought I got though. If you have the housewrap folded in covering the entire sill. (Not 45 in from corner). Does a guy just need a peice of
Old 05-21-2011, 07:44 AM   #12
Sorry hit send by accident. Piece of tyvek sill tape 12" long only in the bottom corner 6" up and 6" on sill?
Old 05-21-2011, 03:12 PM   #13
buddy110's Avatar
Trade: Exteriors as a whole
Rewards Points: 530
http://www.youtube.com/watch?v=ywjHRcwOFbM
buddy110 is offline
Old 05-22-2011, 07:24 AM   #14
[QUOTE="kubie"]just had a tyvek class last year
u cut the tyvek along window .....
Your video buddy puts kubie explaination in pitures. One thing though I've never seen those sill pans around here like in video. What those cost ea.? My thinking is if tyvek wouldn't be damage and not wear out on the rough opening sill. IMO which I don't think would. Would you just need the sill tape to protect the bottom corners. You get a 10' window opening that's like $20 of sill tape.
Old 05-22-2011, 09:30 AM   #15
Custom Builder
Chris@Sunrise's Avatar
Rewards Points: 502
Here is what tyvek wants to see. They also cover labor if you use button caps to apply the wrap. We use the tyvek sealent on top and side flanges set the window then use 4" Dupont flashing on sides and across the head. Tyvek is saying there 4" flashing is plenty if you follow the rest of there guidlines
tyvek and tyvek taping around windows (new construction)-forumrunner_20110522_073009.jpg   tyvek and tyvek taping around windows (new construction)-forumrunner_20110522_073023.jpg
Chris@Sunrise is offline
Old 05-22-2011, 06:35 PM   #16
Trade: siding
Rewards Points: 20
[QUOTE=construction;1209341]
Your video buddy puts kubie explanation in pictures. One thing though I've never seen those sill pans around here like in video. What those cost ea.? My thinking is if tyvek wouldn't be damage and not wear out on the rough opening sill. IMO which I don't think would. Would you just need the sill tape to protect the bottom corners. You get a 10' window opening that's like $20 of sill tape.
tyvek is water resistant not waterproof,on horizontal areas it's even probably less so,sill flashing is the most important sidewall flashing component and it's not wise to skimp here
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
Old 05-22-2011, 06:56 PM   #17
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,342
This is all of their install directions.
http://www2.dupont.com/Tyvek_Weather...o/install.html
-Dennis
WarriorWithWood is offline
Old 05-23-2011, 06:32 AM   #18
topsail's trimcat
Rewards Points: 384
the tyvek flashing tape is available here but its about 3x the price of a roll of 6" vycor so hardly anyone uses it here. just saying
Old 05-23-2011, 06:41 AM   #19
So does tyvek void their the warrenty? By not using their tape?
Old 05-23-2011, 01:28 PM   #20
Trade: siding
Rewards Points: 20
tyvek won't void your warranty as long as it's compatible [they will find a way to do that long before they get to the flashing tape]
you don't need to use flex wrap,you can use the straight wrap using butterflies or i think vycor may have preformed corners
point is your going to spend depending on the unit at least 1000 bucks on that hole in the wall,50 dollars in material to protect it isn't a lot
