Trapping Moisture With House Wraps And Vinyl.
After doing a bit of research about different house wraps, Im a bit concerned with my plans and my 70's existing wall system. I have poly under my drywall. And when I install typar or tyvek before my vinyl, Will I trap moist Iowa air inside my wall?
I do plan on installing a rain screen of some sort (home slicker or vertical furring strips) to keep the vinyl off the house about 1/4". But Im tempted to omit the house wrap since my old T-111 is painted. Any advice? Last edited by GiantScale; 09-10-2005 at 07:36 PM. |
Trade: Residential remodel
Re: Trapping Moisture With House Wraps And Vinyl.
House wrap is designed to allow moisture out...dont think that would be a problem.
R |
After talking to a local inspector it turns out poly on the inside warm side is still required by code here in iowa.
Looks like tyvek has the highest perm rate. I think I might try plastic mesh used by E.I.F.S. installers on first. Then tyvek, furring then vinyl siding and hope that the wall can breath enough. Last edited by GiantScale; 09-12-2005 at 01:01 PM. |
Bah Humbug!
House wrap is designed to be a one way vapor barrier. If you were to make a bowl of the house wrap and fill it with water, one way it would allow very little water to pass though. Turn it over and the water will freely flow through. DOn't ask me how the genuises though it up but it works.
Compare it to your own skin. It keeps the water out but allows perspiration to exit. I always compare features of the house to the human body because so many people just can't understand building concepts but do understand their own bodies. |
#5 | |
Re: Trapping Moisture With House Wraps And Vinyl.Quote:
keep your hands in water and watch them wrinkle up from moisture absorbtion But your point was understood |
[QUOTE=GiantScale]After talking to a local inspector it turns out poly on the inside warm side is still required by code here in iowa.
If you have a lot of strong southern or southwestern exposure that would kill the paint. I have T&G cedar on my house and the clerestory area with southern exposure gets KILLED by the sun. I use Benjamin-Moore stain and it still can't take it. All the other walls exposure...no problem. |
#7 | |
T-111 is plywood used for siding. it has vertical grooves cut in it. 747, your siders went through a lot of extra work to strip off the old siding, but you answered your own question, because you say your house looks better than your neighbors siding job. :Thumbs:
I never, ever leave the window casings in deeper than the 'plane' of the siding, - - it doesn't take but a few minutes to fur out the casings, - - and leaving the window casings 'inset' not only looks cheap as hell, - - it creates an unwanted 'water-catch'.
http://www.tr-built.com |
#10 | |
#11 | |
#12 | |
Trade: Home Improvement
well said I totally agree
"All you need in this life is ignorance and confidence, and then success is sure". -Mark Twain |
Trade: architect
The underlayment (Tyvek or building paper) should go directly over the sheathing (T1-11 in this case), then install either mesh or vertical strapping (but not both). The mesh or the strapping will create a "drainage plane" so that any moisture that penetrates the siding can drop and exit the wall at the bottom. I'm not sure the drainage plane is really necessary with vinyl siding (like it is with wood siding) but it can't hurt. You might consider Dupont's StuccoWrap because it is essentially wrinkled Tyvek and acts as an underlayment and as a drainage plane.
The underlayments mentioned above are vapor permeable and will not act as vapor barriers. |
