Tempered Glass Question
Old 07-16-2010, 10:31 PM   #1
davinci's Avatar
Trade: roofing
it is required if the glass is less than 18 inches from the ground.. then it states its not required if it is less than 3 square feet.
so,if its less then 18 inches from the ground but less than three square feet,its not required? any help would be appreciated.
davinci is offline
Old 07-16-2010, 10:58 PM   #2
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 238
Send a message via Skype™ to jlhaslip
Re: Tempered Glass Question
where are you located?
jlhaslip is online now
Old 07-17-2010, 08:11 AM   #3
davinci's Avatar
Trade: roofing
i think its 9 sq feet. s if the glass itself is less than 18" above the ground we need tempered but what if (at the same time)the glass area is lless than 9 sq feet?
davinci is offline
Old 07-17-2010, 08:45 AM   #4
Framer53's Avatar
Trade: Handyman
Rewards Points: 242
Less than 18" always use the tempered. Not worth the bother to argue with the inspector.
Framer53 is offline
Old 07-17-2010, 08:50 AM   #5
welterweight's Avatar
Trade: sales
ok,here's the deal with tempered. if the glass area is less than 18" from the ground you need it. however,if at the same time the glass area is less than 9 square feet then you don't need it. its very vague at this point and its sometimes open to interpretation. situations like this warrant a call to the local building inspector.
now,if someone has a window inside their shower or bath area,it obviously needs to be tempered. you could also get it frosted athough you may upset the local "peeping tom".
within 24" of a door you need it..it may actually be 36" but i will check.
welterweight is offline
Old 07-17-2010, 08:54 AM   #6
Trade: sales
it is 24" also the 18" part of it; gotta check if its the glass or the actual sill/stool.
Old 07-18-2010, 12:12 PM   #7
jlhaslip's Avatar
Rewards Points: 238
You will need to chec k with your local Building Inspector. Codes vary by location.
Here, we need tempered glass within 3 foot of an exterior door for security in addition to low mounted windows.
Old 07-18-2010, 01:12 PM   #8
Tom M's Avatar
Rewards Points: 3,602
It wouldnt need to be tempered.
The code says in #7 of Hazardlous location conditions that safety glass be used when all all situations are met----1 through whatever.......lower edge 18 or less, upper edge greater than 36, 9sqft or greater...bla....bla...bla
Then the very 1st exception says unless a 3" sphere cant pass. So under IRC If a 3" sphere cant pass than reguardless the location its good.
Your local state may have removed that exception so really its best to get that info.
Tom M is online now
Old 07-22-2010, 08:37 PM   #9
slave driver
glassman's Avatar
Trade: project manager commercial contract glazier
Rewards Points: 75
Send a message via Yahoo to glassman
Some local codes use the National standard and then adjust theirs to be a bit more restrictive, requiring safety glass ( tempered or laminated ) where National code may say it's not required. Fairfax county VA. requires safety glass in almost every application.
Just for what it's worth, the price of tempered safety glass costs about another dollar per square foot, cheap insurance.
glassman is offline
Window pricing question contractorjay Windows, Siding and Doors 12 07-02-2010 02:02 PM
Code Question on Lamp wiring question ABLE1 NEC Discussion 8 06-16-2010 08:48 AM
Security Glass eager2start Windows, Siding and Doors 7 01-05-2007 08:32 AM
Broken Sliding glass door sprinklerguy Windows, Siding and Doors 10 01-04-2006 04:58 PM
