Tearing Off EIFS (stucco)
Old 03-17-2009, 12:53 PM   #1
Johnny Cash's Avatar
Trade: home exteriors
So I have to remove about 3 sq of stucco on my next project. I did a search and couldn't find any quick tips on tear off. SO I am wide open to suggestions on the easiest way to tear off? Thanks
Johnny Cash is offline
Old 03-17-2009, 10:54 PM   #2
ctscontractor's Avatar
Trade: exterior, stucco
Re: Tearing Off EIFS (stucco)
what do you mean by removing 3 sq of stucco? do you mean 3 inch efis stucco? Depends what's under the foam. If you find plywood, it should be all screwed in to it. If cement blocks its glued to the wall. In that I would use hammer and take it down from the sides. Later just rotary hammer to take down the remains of cement that was glued in to the wall. Hope it helps
ctscontractor is offline
Old 03-17-2009, 11:16 PM   #3
KemoSabe
loneframer's Avatar
If it's foam over plywood you likely will be replacing the plywood too. I've seen many jobs doing dryvit repair, all of them required replacement of sheathing and in some cases, structural framing repairs. These were in a coastal area which may have worsened the problem. What's the deal with your job?
loneframer is offline
Old 03-18-2009, 05:45 PM   #4
It is over plywood. I am worried about the cond. of the plywood and the structural framing, which I warned the HO about. 3 sq. means 3 square. I peeled alittle off today and found it held on with screws as stated above. Thanks for the input.
Old 09-26-2009, 08:50 PM   #5
Javelin350's Avatar
Trade: James Hardie Hardiplank siding Gold contractor
circular saw with concrete blade cut it in to 3 by 3 feet squares and pry it off.
Javelin350 is offline
Old 09-26-2009, 09:24 PM   #6
concretemasonry's Avatar
Trade: Masonry consultant
Don't be surprised if you hit mold behind the plywood if it is stucco.
Take a long proble moisture meter (not a cheap surface reader) to check around the and under the windows and below any second floor openings. Most windows are not installed properly and the Dryvit can hold in all the moisture that gets inside.
Dick
concretemasonry is offline
1 coat vs. 3 coat stucco finishing janrickey General Discussion 12 07-17-2011 11:22 AM
New stucco meeting up with old MichaelNY Masonry 3 11-13-2008 07:25 AM
eifs vs traditional stucco genecarp Masonry 11 10-27-2008 02:14 PM
Anyone here in EIFS / stucco? Mr. Corporate Construction 1 01-18-2008 04:00 PM
Stucco patch, how much to do EIFS patches? sniperninjafox Painting & Finish Work 7 09-26-2007 08:41 PM
