Suresill Door Pan
Old 02-15-2012, 07:42 PM   #1
mpminter's Avatar
Trade: painting and remodeling
Suresill Door Pan
Anyone ever use the suresill sill pan when installing replacement doors? I'm bidding a job right now where they experience some water infiltration under the front door that went unnoticed for quite some time. When their dishwasher let go and they pulled the floating floor throughout the kitchen and living room, they discovered a good deal of water damage and rot. I have never used a product like the suresill and I've never had a problem, but it looks like a quality unit and I'd like to give it a try. Does anyone have any experience with these things? Thanks
mpminter is offline
Old 02-15-2012, 09:13 PM   #2
4 seasons's Avatar
Trade: Contractor/ Carpenter
Rewards Points: 250
Re: Suresill Door Pan
I use pre made pans if they come with the door, otherwise I make my own out of lead.
4 seasons is offline
Old 02-15-2012, 09:41 PM   #3
TimNJ's Avatar
Rewards Points: 2,222
Better hope there is room in your RO to accomadate the size of that SureSill.
On a side note: The guy peddling SureSill in their video may want to be selling fountain of youth elixir since he claims to have been doing construction "since The Beatles first appeared on the Ed Sullivan show". He looks quite a few years younger than me and I was 5 when the Beatles were on Ed Sullivan.
TimNJ is offline
Old 02-15-2012, 10:25 PM   #4
mpminter's Avatar
That's my biggest concern. I'm not sure exactly how much it's going to add to the bottom of the opening as I've not been able to get my hands on one. We'll see what happens.
mpminter is offline
The Following User Says Thank You to mpminter For This Useful Post:
Tom Struble (02-15-2012)
Old 02-17-2012, 06:16 PM   #5
A.Murrill's Avatar
Rewards Points: 150
I have used the sure sill pans. I install for a big box and we order them on custom doors or when there are water probs. The only thing I don't like is the up bend on the inside shows. So it's pretty hard to add a quarterround or cove mold against threshold. I think it adds about 1/8".
Lead pan? I thought that was illegal?
A.Murrill is offline
Old 02-17-2012, 07:38 PM   #6
GRB's Avatar
Trade: Carpentry Contractor
You can usually get around the height issue by making your pans out of a peel & stick material like Grace Vycor or similar. Just be sure to turn up a leg along the back for a back dam.
Any sill pan is better than no sill pan IMHO.
GRB is offline
The Following User Says Thank You to GRB For This Useful Post:
Cole82 (02-18-2012)
Old 02-18-2012, 07:36 AM   #7
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
iv'e found full depth metal pans to be a potential condensation issue
Tom Struble is offline
GRB (02-18-2012)
Old 02-18-2012, 03:54 PM   #8
carpentershane's Avatar
Rewards Points: 520
Never thought of that before- I usually site bend a metal sill pans and put vycor down prior to the pan- may have to change up my practices.
"Perfection is an unachievable goal, the illusion of perfection is the work of a true craftsman. " LoneFramer
carpentershane is offline
Old 02-19-2012, 12:02 AM   #9
woodWC&R's Avatar
Trade: Windows/Doors/Siding
I have wondered about the condensation with full depth metal pan as well. What if instead of a full depth you two piece the pan with aluminum and use the flashing tape to break conduction? Kind of depends on the detail and the extent of the existing water issue.
woodWC&R is offline
Old 02-19-2012, 11:28 AM   #10
Trade: siding
Rewards Points: 4
you can do that but why not just use tape?or tape all the way to the back and then a small L lapping over the tape then taped to the tape
i see some window pan details that call for a vinyl L like corner bead
and don't think that just because a door may be well under an overhang that flashing the sill is not necessary
even tho it may be thermally broken i have seen sweating under the aluminum thresholds
Old 02-19-2012, 11:39 AM   #11
woodWC&R's Avatar
I usually use dupont flex wrap but have sometimes tried to use like you mentioned a small L bend for a dam and then set the patio door tight to that to give a clean finish on the interior where the door meets the floor material
woodWC&R is offline
Old 02-20-2012, 09:35 PM   #12
onequick's Avatar
Trade: Windows and doors, general contracting
Heres what we do. After removing the door we apply a tar tape to the sill and up 6inches on each leg, making sure atleast one inch folds over onto the exterior face. We then lay beads of caulking and lay a field bent pan that extends out from under the door to what evers on your exterior. Make sure you have proper slope for run off. We then install more caulk and lay the door threshold into it. After installing we use foam insulation spray around the door, Pella tar tape around the door frame then the exterior trim and interior trim. Dont see many leaks from this method
Aaron Smith
K.C Company Pella Windows and Doors
240-375-8279
http://www.kc-pella.com/
onequick is offline
Old 03-05-2012, 11:55 AM   #13
Alfalfamike's Avatar
Trade: Windows and Doors
We use a custom pan that addresses most issues found in door installs. Back dams can be made to accommodate your specific DP rating and are still easily covered by trim. We were installing doors in a sub- division where the framing wasn't always perfect, these pans were made without a front lip so the door could be adjusted within twisted framing. An added plus, they are one piece which eliminates the dependency on sealant to make the pan water tight.
Alfalfamike is offline
