Suggestions On Azek Window And Corner
Old 02-26-2008, 11:56 AM   #1
72chevy4x4's Avatar
I'm looking to put up 5/4" Azek 6" corners and would like to run my Quest DT 5" under the Azek with no J trim and looking for good installation practices. I'm considering wrapping the corner w/ 24" coil stock or Grace I&W (if it's acceptable) , then fastening a 7/8" wood/composite block to build out the corner and provide a nailing surface for the Azek corner. Since I'm 'milling' the block, I considered providing for 1.5" of overlap over the siding.
Since the corners are 5 1/2" wide, I'm considering wrapping the corners w/ 5/8" 5" (4 1/2" wide), thinking the difference in size might be attractive. Can anyone provide input?
when building out a window casing with Azek (or wood and wrapping with Al), what is the best practice for locating the drip cap above the window and carrying the siding above the window (while not using visible J and nearly 100% weatherproof)?
72chevy4x4 is offline
Old 02-26-2008, 04:30 PM   #2
Patrick's Avatar
Re: Suggestions On Azek Window And Corner
Why dont you use the premade corners? They come pre glued and ready for vinyl siding, they also have a nail flange so there are NO face nails. If you make your own, they should be furred out with azek material, NOT wood. If you must use wood, at least make an aluminum J to sit inside the pocket.
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 02-26-2008, 08:23 PM   #3
72chevy4x4's Avatar
sorry for not specifying on the corners, I am going w/ the premade corners. The rabbit joint holding the corner together looks quite strong. what nailing flanges are you referring to? The Azek I saw at the supply house and the Azek product manual do not show it. I was considering making an 'L' for the terminating edge of the vinyl under the corner-not sure there is a need for the third side (making a 'J').
Old 02-26-2008, 08:54 PM   #4
Patrick's Avatar
http://www.advancedtrimwright.com/pr...cornertrim.htm
You can use those clips for ANY application of trim, I think its the ONLY way to go, Face nails will always look bad unless you paint.
Patrick is offline
Old 07-17-2009, 08:31 AM   #5
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
I dug this post up looking for suggestions...........
I want to use azek to wrap a garage door frame instead of coil, and then use a 3" wide azek for trim and form a J pocket. What is the best way to fasten it? I thought of just using galvanized trim nails. I haven't used the stuff yet, but would like some info.
Everyone here has simple J channel and coil on everything. Would like to get away from that.
MJW is offline
Old 07-17-2009, 06:05 PM   #6
KemoSabe
loneframer's Avatar
Here are some examples of Azek used to form an internal receiver. The garage door and the shower door are cased with 5/4 Azek plowed out 1"x3/4", an aluminum L was used to flash the receiver. The window surround is 3/4 sheet goods with a 3/4 faceframe used to form the receiver. 1/2" sheet goods were used to make the applied panels. A vinyl base cap was used to give the panel some dimension. . Everything gets glued with Christy's Red Hot PVC adhesive. I facenail with 16 ga. stainless gun nails. Filling the holes is unsightly unless you are painting because the filler always attracts dirt.
loneframer is offline
The Following User Says Thank You to loneframer For This Useful Post:
MJW (07-17-2009)
Old 07-17-2009, 06:52 PM   #7
Patrick's Avatar
WE buy from a company that makes azek garage door kits for us the jam is welded to the face trim and it has a nail flange. you cut and install your two side jambs and then you put on your head, flash it and your good to go NO face nails
Patrick is offline
Old 07-17-2009, 06:54 PM   #8
MJW's Avatar
Thanks loneframer. I agree filling the holes is unsightly. I don't even fill them on interior trim. Never heard of the glue, but it was a thought I had when thinking about how to apply this stuff.
For cutting, does a regular Diablo blade in a miter saw work well?
MJW is offline
Old 07-17-2009, 06:56 PM   #9
MJW's Avatar
How do you flash it out with the J channel built in like that?
MJW is offline
Old 07-17-2009, 07:03 PM   #10
Patrick's Avatar
we back caulk the trim nail the flanges, and then tape it off with 6" or 9" window flashing tape just like a window
Patrick is offline
Old 07-17-2009, 07:39 PM   #11
KemoSabe
loneframer's Avatar
The only problem with the Diablo is, if it is a new blade, the red paint will stain the end cut and could be unsightly. I prefer a blade with no more than 40 or 60 teeth maximum on a 12" blade to prevent overheating. Too many teeth will distort the cut by thermal expansion. 32 teeth will even give decent results. In any case, a sharp blade is a must for satisfactory results.
Old 07-17-2009, 07:47 PM   #12
KemoSabe
loneframer's Avatar
Herer are a few more. The ovals are cut from 3/8 sheet goods, a 3/4 packer backs it up., ripped 1" narrower. In this case you could take an L-flashing, snip it every 2 inches, step flash it with tabs and give it a liberal dose of Lexel clear to seal 'er up. Same for garage door trims. Columb bases are also 100% Azek.
Old 07-17-2009, 07:57 PM   #13
MJW's Avatar
Thanks for the tips guys!
I have seen a few other brands that are similar to Azek. Are they all really that similar, or have you used them?
Any other pics or suggestions are appreciated. If it goes well, I hope to use this type of moulding more often. Some homeowners don't care for too much white, but I think it looks great!
MJW is offline
Old 07-17-2009, 08:12 PM   #14
KemoSabe
loneframer's Avatar
Certainteeds line is nice and works exactly like Azek. I haven't had the opportunity to bead it or dado it for a beam wrap, but for basic joining it is very nice.
You said you like pics? Oh, boy. Here are some others.
