Century Man
Split Block For Foam Back Siding
We installed foam back siding on a house and have run into a situation that we're unable to resolve. The regular split block for the spigot or hydrant does not allow enough room to get your hand on the wheel. Mid-America doesn't have anything that helps such as an oversize block. Have any of you dealt with this and resolved the problem?
Thanks, CM |
Trade: siding
Re: Split Block For Foam Back Siding
flip the block?
Tom |
Trade: siding
How about a split mini block from master mount?
It's better to die on your feet than to be living on your knees. |
Color matched coil, j, and color matched caulking. I would also put the cap bend into the flashing piece and run it to the sill and j straight down both sides to the sill as well. Leaves no place for water to sit.
KemoSabe
Get a plumber to cut the hose-bib loose, put a proper J-block on then reset the hose-bib.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
Trade: siding
i would have used white j on that window, looks funky with that blue stripe inbetween the white window and white shutter.I always try to match my j color to the trim
Tom Last edited by Tom Struble; 07-17-2009 at 09:33 PM. |
Who the hell makes that block???????? Ive never seen one like that before
The regular mid america split block works fine for us, as long as we put them upside down... WHY IS THAT????? Anytime i got a guy and he installs it with the arrow, the customer calls saying they cant hook up the hose
| The Following 2 Users Say Thank You to Patrick For This Useful Post: | jumbo (07-17-2009), Tom Struble (07-17-2009) |
woodchuck2
"I would also put the cap bend into the flashing piece and run it to the sill and j straight down both sides to the sill as well. Leaves no place for water to sit." I agree, i also agree with the others as far as white J-channel and i would have used a white J-block. Calling a plumber to cut the pipe and extending it would be the quickest and easiest solution.
Siding Windows Doors
Trade: Exteriors
Duraflo has some accessories that have a deeper profile. You could also extend the split ring with coil and attach the reciever trim to it.
#10 | |
Trade: siding
Re: Split Block For Foam Back SidingQuote:
| The Following User Says Thank You to jumbo For This Useful Post: | Tom Struble (07-21-2009) |
| Siding & Windows Sales needed - Chicago area - NO SALES EXPERIENCE | Grumpy | Help Wanted or Looking For Work | 4 | 05-26-2009 03:51 PM |
| window return in concrete block house | bmancanfly | Remodeling | 10 | 05-15-2009 04:30 AM |
| Art block and parging | silvertree | Masonry | 3 | 05-06-2009 09:39 PM |
| What Is The List Of Every Line Item Possible For Siding Jobs From Insurance Cos.? | Ed the Roofer | Windows, Siding and Doors | 0 | 08-27-2008 08:20 PM |
| Installing Hardie Siding over Concrete Block? | Chrome Toaster | Remodeling | 1 | 02-28-2007 12:07 AM |
