Special Order Siding
Old 04-07-2008, 12:48 PM   #1
72chevy4x4's Avatar
I'm ordering siding in a non-stocked color of J channel and the supply house requires full box orders. Not that big of a deal with needing say 37 pcs and 40 makes a full box, but if I only needed say 10 pcs, 40pcs is a lot of material to throw away. Do some of your suppliers work with you on odd orders such as this?
72chevy4x4 is offline
Old 04-07-2008, 01:31 PM   #2
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
Re: Special Order Siding
I think it's up to the wholesaler your supplier works with. If I only needed 10 I would either ask the supplier to find another wholesaler for your needs or use another supplier for that order. Someone should be able to help you out.
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 04-07-2008, 01:32 PM   #3
Patrick's Avatar
Somebody somewhere, will have it in stock. We pull from 6 different wholesalers. 99% of the time i can get it in stock from someone what color J is it?
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 04-07-2008, 01:46 PM   #4
softtop95ta's Avatar
Trade: residential contractor
The color is (((not in stock))) its actually a very pretty shade of clear
have you tried Delmarva aluminum??
sg williams in dover??
quality roofing??
ABC roofing supply?
the roof center in Salisbury?
To announce that there must be no criticism of the president or that we are to stand by the president right or wrong is not only unpatriotic and servile but is morally treasonable to the American public....... Teddy Roosevelt
softtop95ta is offline
Old 04-07-2008, 05:47 PM   #5
Siding Windows Doors
easy sider's Avatar
Trade: Exteriors
Yes, we have many times over the years bought more material than needed because it was special order. No, we do not keep this stuff. Your talking about chump change. I know a guy who gave away half a trailer full of Heartland high temp Olive vertical siding. He had to buy full trailers of this and ended up with a bunch of this stuff. This is still chump change at $10,000.00 considering the size of the project.
easy sider is offline
Old 04-07-2008, 06:19 PM   #6
odellconstruct's Avatar
Trade: carpenrty, remodeling , residential
are you wrapping the windows in white ? or color . if white you can always use white j , around the windows. sometimes a different color on the corners and j looks awesome , just a suggestion
odellconstruct is offline
Old 04-07-2008, 06:56 PM   #7
72chevy4x4's Avatar
I wish it was white-HO want's Cameo for trim but the J needed is Terra Cotta. I'm a little hesitant about the color combo-put this together with a new roof in Hickory on a tudor style house!
SG's a special order, didn't try Qualtiy since they're in Lewes. I'm getting materials through Lansing Bldg-they're giving me 10%+ off SG's prices, but I've got to get it right when ording the quantity. I'll just throw the extra in the trash-no room to store 'Terra Cotta' for years to come! I figured if I have to drive a distance for the material, the gas and time would defeat the cost savings of the J I'll be tossing.
softtop-how did that warped corner deal workout?
Old 04-07-2008, 08:39 PM   #8
Patrick's Avatar
What color is the window trim? We solved this entire problem by eliminating vinyl J channel all together. It looks like crap anyways
Patrick is offline
Old 04-07-2008, 09:00 PM   #9
72chevy4x4's Avatar
3 1/2" lineal in the color 'cameo'. I've stopped using J around the window openings and build up and wrap or use lineals, not even offering the lesser J install. So far, the HO's have seemed to like the extra attention to detail :-)
Old 04-07-2008, 09:03 PM   #10
Patrick's Avatar
so what do you need the J for?
Patrick is offline
Old 04-07-2008, 09:59 PM   #11
72chevy4x4's Avatar
inside corners
Old 04-07-2008, 10:17 PM   #12
Patrick's Avatar
1 roll of coil $80
Patrick is offline
Old 04-08-2008, 06:47 PM   #13
President
Jake Stevens's Avatar
Trade: Installing windows, siding, roofing, doors, patio rooms, gutters and shutters.
What brand of siding are you using? I used Mastic Terra Cotta on a job last summer and used there inside corners.
Jake Stevens is offline
Siding: Aluminum vs. Vinyl Grumpy Windows, Siding and Doors 21 03-30-2010 08:02 PM
Siding & Windows Sales needed - Chicago area - NO SALES EXPERIENCE Grumpy Help Wanted or Looking For Work 4 05-26-2009 03:51 PM
Watertight integrity of viynl siding? mci2980 Windows, Siding and Doors 71 11-24-2007 04:15 PM
Siding over Masonite fxdfast Windows, Siding and Doors 4 08-24-2007 04:34 PM
asbestos siding bill6078 Windows, Siding and Doors 4 03-05-2006 11:33 AM
