Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Old 10-15-2008, 05:37 PM   #1
Trade: siding windows soffit fascia
speaker install in aluminum soffit
Hey guys we have 4 speakers to install in some aluminum soffit on a new home. I'm trying to think of an easy way to cut the circular holes that they will go into. Don't really want to spend $$$ on a new tool but open to suggestions. If nothing else I figure to score around a pattern with a sharp razor knife and "peel" it open.
Ideas?
Thanks,
Dave C
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors
Home Serve is offline   Reply With Quote
Old 10-15-2008, 05:41 PM   #2
mickeyco's Avatar
Trade: Squirrel Handler
mickeyco is offline   Reply With Quote
Old 10-15-2008, 05:43 PM   #3
Handle It!
MALCO.New.York's Avatar
And whos name is on that???????????
Ultimate Wisdom---------
http://www.youtube.com/watch?v=_k1Ug...ture=rec-HM-r2
MALCO.New.York is offline   Reply With Quote
Old 10-18-2008, 12:38 AM   #4
grob62's Avatar
Trade: Windows and Doors
Nice tool, but a regular drill bit to start a hole and some aviation snips would be cheaper.
grob62 is offline   Reply With Quote
Old 12-22-2008, 11:40 AM   #5
tomstruble's Avatar
Trade: siding
probebly better off remove in the panels where the speakers are going the provide the support you need to hold the wieght of the speaker making sure it face ends up where you need it to maybe have the homeowner use a waterproof surface mount unit and attach it to the wall
tomstruble is offline   Reply With Quote
Old 12-23-2008, 12:30 AM   #6
Trade: carpenter, builder
I've used a rotozip with a circle cutting attachment, but when you get it mostly cut out, the center of the circle wants to move around. Snips are fastest, like said above, if your cut will be hidden.
Ten Fingers is offline   Reply With Quote
Vinyl soffit span... what backing OC? bobaganoosh Windows, Siding and Doors 11 12-24-2008 12:41 AM
cutting holes in aluminum soffit for can lights buckeyeso2 Windows, Siding and Doors 18 08-26-2008 12:59 AM
Aluminum soffit estimate? K_Tile Windows, Siding and Doors 24 07-25-2008 10:56 AM
Estimating Aluminum Soffit and Fascia DaNortWoods Roofing 7 07-14-2008 09:41 AM
aluminum soffit boo General Discussion 2 08-24-2006 09:08 PM
