Sound Control Windows?
Old 03-13-2009, 12:10 AM   #1
UGLi's Avatar
Trade: Custom home theatre / home automation
I install custom home theaters in a railroad town, and I'm looking for "sound control" windows. There are a number of triple pane windows out there, and the manufacturers always stress the additional sound blocking properties of adding an additional pane of glass, but just having three panes of glass doesn't necessarily give a window a higher STC rating. I've only found two manufacturers that actually test and publish the sound transmission capabilities of lines they've designed to block sound. Milgard makes the "Quiet Line" series, and Atrium makes the "Silent Guard" line. Both of these products are tested in different configurations up to an STC of 47.
Anybody have experience with a product that does a great job of blocking sound?
UGLi is offline
Old 03-16-2009, 07:05 AM   #2
Oberon's Avatar
Trade: Glass and windows
Re: Sound Control Windows?
Windows, doors, walls, whatever, are all rated as to their ability to deaden or attenuate sound based on the STC or Sound Transmission Class.
STC is an average of an object’s ability to attenuate sound across a fixed frequency spectrum of approximately 100hz-5000hz. An STC average (what you will be quoted if asking about STC of a specific product) does not provide specific frequency-deadening information which may be what is needed if you want to block a specific type of unwanted noise – for example traffic noise – and while the attenuation characteristics of certain products at particular frequencies do exist, they are often not generally available to the consumer.
Sound Transmission Class is a laboratory rating based on some very specific criteria within a very specific frequency range. STC was designed to test the frequency range where the human voice will be the predominant consideration.
Unfortunately, this does tend to minimize the effectiveness of STC as a tool for helping to block sound outside of that range.
While using STC to compare the sound-blocking ability of different window styles or brands is certainly not a bad idea since, generally speaking, a window with an STC of 40 should outperform a window with an STC of 35 – STC is sort of like mileage ratings on a new car – not always as useful as one might hope and that 40 versus 35 is for an overall rating – it does not say which of those products would perform best at specific frequencies – again blocking traffic noise for an example.
STC is a rating that is independent of the conditions under which the window will be used – meaning that it does not take into account the actual field conditions of the assembly. These conditions might include background noise, window area, even the level of sensitivity to noise of the occupants. Noise reduction requirements are affected by these conditions so that windows with the same STC might have very different NR requirements when used in different situations.
But, at the basic level there are three primary issues to consider when dealing with unwanted "noise" – the frequency, the level, and the duration of said noise.
Sound frequency and sound level are combined into what is called a "dBA" – or A-filtered decibel value – in order to quantify the sound in relation to the human perception or ability to hear it. In other words, we all “hear” (no pun intended – really!) about the specific dB level at a rock concert or at the airport, but we don’t hear “evenly” across the whole sound spectrum. For example, we may hear a sound at a relatively low decibel (or sound pressure) level at one specific frequency and yet be unable to hear an even louder sound at a different frequency - which is why frequency response is weighted.
Sound duration is added into the mix because even a relatively quiet sound can become annoying when it persists for a certain time. Using figures derived from these three descriptors, a sound professional can determine what is required to attenuate (opposite of amplify) the inappropriate sounds.
Sounds like a lot of trouble (again, no pun intended!), right? Well, it actually is and unless you live next to an airport or train crossing it is usually not worth the trouble to go there. But, I pointed it out to give you some idea of how in depth fighting unwanted sound can be.
As humans we are born with the ability to hear from approximately 20 to 20,000 hertz.
Hertz, or Hz, is how sound frequency is measured - like electricity is measured in volts. By the time we are teenagers we have generally lost the ability to hear above about 13,000hz. Since the human voice tends to fall between 500hz and 5000hz, the loss of higher frequency sounds is not usually a big deal.
Generally, low frequencies are much harder to attenuate (opposite of amplify) or block than are higher frequencies - just think how often you hear the bass sounds from the neighborhood kid's car stereo and not the higher pitch tunes when he is coming down the street.
When considering glass sound performance, there are four primary considerations to take into account for maximum possible attenuation – or blocking.
First is laminated glass.
Second is a wider airspace between the lites.
Third is different thickness lites within the IGU or Insulating Glass Unit.
Fourth would be a combination of all three.
Airport windows, as an example, often will have laminated glass on both sides of an IGU in an aluminum frame and with a maximum airspace between the lites. In an airport the primary concern is sound attenuation and energy efficiency is secondary. I mention this because the width of the airspace and the choice of window framing material affects both sound and energy efficiency.
As you noted, some folks will suggest triple pane glass for its sound deadening ability, and while triple pane may be a slight improvement over standard double pane at certain frequencies due to the additional density of the extra lite, overall there is no major difference in STC rating between triple and double pane provided that the overall airspace between the panes is constant between the two constructions.
In other words, a triple pane with two 1/4" airspaces and a dual pane with a 1/2" airspace – both using 1/8" glass – will have the same overall STC assuming that windows are otherwise the same.
Using one thicker and one thinner - different thickness - lites in an IG construction may also help deaden sound because each lite is transparent to a different frequency and each lite will then attenuate the frequency that passed thru the other lite.
As a very general rule, different thickness lites in an IG configuration (for example 1/8” and 3/16”) contributes more to lower frequency noise attenuation than it does to higher frequency attenuation, yet oddly, using different thickness lites does not contribute significantly to overall STC performance as well as the other options – such as using a wider airspace or laminated glass in the IG unit - and the wider the airspace between the lites, the more potential for limiting unwanted sound thru that space.
Unfortunately, for significant sound attenuation, it may be necessary to have an air space approaching two inches or more – although lesser width airspace can make a difference as well – possibly depending on the frequency and amplitude of the unwanted sounds.
Minimizing unwanted sound thru any material is determined by three things – mass, stiffness, and damping of the material. Increasing the mass of a window by using thicker glass will increase sound attenuation and the change from a single pane window to dual pane or triple pane IGU to a window will add glazing mass and thus improve sound performance thru the window; but often not as much as might seem obvious based on the given criteria.
So why do folks with new dual pane windows, after living with single pane, often comment on the improvement in blocking unwanted outside noise with their new windows?
Often, this is due to the replacement window being tighter than the previous older window, but also the addition of the airspace between the lites of a dual pane – rather than to the effect of the additional lite, unless as mentioned the lites are different thicknesses – can have an effect on sound propagation.
So in that sense, the additional lite in a standard dual pane window improves performance over a single pane by the formation of the airspace. But this doesn’t always apply when adding triple pane due to the decrease in the airspace between the lites overriding the potential advantage of the additional lite (as mentioned earlier in this really long post...)
And, going back to mass, stiffness and damping; since increasing the stiffness of glass isn't really practical, what about damping?
Inherently, glass has very little damping ability, but when putting a layer of a more viscous material between two of lites of glass we substantially increase the unit’s ability to dampen sound – thus the advantage of laminated glass which just so happens to be a product that has a layer of more viscous material between two lites of glass – cool how that works right into the explanation!
A single pane of 1/4" laminated glass consisting of two 1/8" lites with the plastic interlayer actually has just about as much sound blocking ability as a 1/2" lite of monolithic glass. The monolithic glass tends to do better at mid to higher frequencies while at the lower frequencies the performance of Ό” laminated and ½” monolithic tend to be about the same as well as the overall STC rating.
A fixed, versus an operating, window is usually going to give you much better sound attenuation. However, having a house-full of windows that can't be opened is not very appealing to most people, so again we come back to the earlier comment that the window MUST be tight when closed.
Oberon is offline
The Following User Says Thank You to Oberon For This Useful Post:
MasonS (11-22-2011)
Old 03-16-2009, 07:29 AM   #3
Bill Z's Avatar
Trade: sun rooms and room additions
Have you checked Southwall Technologies?
Bill Z is offline
Old 03-17-2009, 05:45 PM   #4
Century Man
Century Man's Avatar
Trade: interior and exterior remodeling
Send a message via Skype™ to Century Man
Oberon- that was the absolute best explanation I have ever read rergarding STC and windows.
UGLi- I hope you appreciate what Oberon just gave you. I certainly do.
Century Man is offline
Old 03-30-2009, 09:06 PM   #5
UGLi's Avatar
I love online forums, and I find it gratifying every time a generous, knowledgeable individual takes the time to share their wisdom. I truly respect and appreciate the time Oberon must spend replying to posts here. As a newcomer to this forum, I hope I did not ask a question that was out of bounds here. I was merely looking for product suggestions.
The STC rating system is far from perfect, but commonly used in the United States. Unfortunately, many manufacturers don't even think about sound transmission when designing a window or door. For a manufacturer to bother having their products tested against an accepted, standardized rating system tells me that they at least care about blocking noise. As for my stated need of a window that can block train noise, typical train horns blast over 110 decibels in short bursts right in the middle of the STC test frequencies, making the rating system ideal for judging a product that may help me.
Bill Z, the Southwall "Super Windows" look like they provide amazing insulating properties (U-Values as low as 0.08!) but aren't designed for blocking noise. Thanks for the suggestion.
UGLi is offline
Old 03-31-2009, 03:44 PM   #6
Patrick's Avatar
Harvey Industries makes one, however it is simply a vinyl window, with a triple track storm permanently attached to the outside
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 03-31-2009, 08:34 PM   #7
Oberon's Avatar
UGLi,
I certainly didn't see your question as out of line - but it really is something of a "fringe" question since few folks really deal much with sound control windows.
There are a few sites that deal specifically with sound control issues - including building sound studios - and maybe one of those would get you more ideas.
I can think of a few manufacturers besides the ones that were mentioned who have sound control products, but the selection is somewhat limited as you have found.
Are you looking exclusively for a sound control window or are you open to ideas that can make a more conventional window perform better?
Oberon is offline
Old 04-02-2009, 05:40 PM   #8
windows & siding
HomeSealed's Avatar
Trade: Home Performance: windows and exterior remodeling
Weathershield makes a window with a lamininated inner pane. Laminated glass is what all of the higher end automobile manufacturers have gone to for the side and back glass to control sound.
HomeSealed is offline
Old 04-16-2009, 06:49 PM   #9
slave driver
glassman's Avatar
Trade: project manager commercial contract glazier
Send a message via Yahoo to glassman
those manufactures mentioned are a good source,also, by having the laminated unit angled down or up,as in most airports,usually zipper wall applications,deflect the noise/sound waves away at an angle,reducing noise transference through the glass,many window manufactures now offer windows made to dade county spec for impact resistance,using laminated glass.
glassman is offline
Old 05-12-2009, 07:03 PM   #10
gouache's Avatar
Trade: woodworking
OBERON!
I've been following your posts about sound & windows all over the web. I'm trying to figure out what the heck to do about my sound problem.
I puchased my first place -- a 2nd floor condo -- about 3 years ago. Unfortunately, about a year ago a bar/restaurant moved in below me. Lucky me!!! I'll make a long story short ... we have crowd noise problems with the patio below in the summer months. I can literally hear people's conversations, and bar hours mean that people get louder & drunker until about, oh, 2AM. The building's windows were put in when the building was redone, but unfortunately I think 1) the window selection was really bad, and 2) the installation was bad. The openings are HUGE - 46" wide by 11' tall, and there are 2 of them. The windows have a small fixed pane at the top, and a huge double-hung below. There's all kinds of air leaking through the double-hung that is, I'm sure, causing the noise problem.
We are investigating three options:
1. Installing some kind of interior window (a la soundproofwindows.com)
2. Installing an exterior storm window - I found a contractor in my area that supposedly installs these w/ laminated glass
3. Replacing the dang thing with a large fixed pane and small awning window at the bottom, all in laminated glass
It is NOT EASY finding someone who can help me with a solution for such big windows. Does anyone have recommendations? Oberon???
Thanks - Elizabeth
gouache is offline
Old 05-12-2009, 07:42 PM   #11
katoman's Avatar
Trade: carpenter
Originally Posted by gouache View Post
OBERON!
Thanks - Elizabeth
I watched a tv program a while back where a company sold an electronic unit that exactly duplicated the exterior noise, and thereby eliminated all exterior noise. It was amazing, but unfortunately I have no idea who that company was, or where to even to begin looking for them, sorry.
katoman is offline
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Windows - Blind Inside? MHMConstruction Windows, Siding and Doors 12 02-20-2010 01:50 PM
Finishing windows before installation??? nwksremodeler Windows, Siding and Doors 9 03-11-2009 08:32 PM
Labor Est. for swapping vinyl rep. windows to wood clad rep. windows? Tallguy1 Windows, Siding and Doors 6 02-10-2009 12:58 AM
sound control dnconstruction Construction 9 09-24-2008 07:13 PM
