Soffit Fascia Help
Old 03-20-2006, 11:25 AM   #1
stagger19's Avatar
Trade: handy man
Soffit Fascia Help
I was wondering if someone could help me out here.
Im building a 16 X 24 garage and the inspector wants me too use 2x8 Rafters 16" OC.
I Would have to use a 2x8 for the Subfascia, and a 1x10 for the fascia board.
Im afraid this wont look good, as it will have a wide trim piece going around the building.
Can I cut and taper the rafter tails after the birdsmouth to a narrower width?
I would like to taper it to a 2x4 for the subfascia, and finish it off with a 1x6 for the fascia. Then install my lookout to box the soffit in
Can I do this? Or is this another way to go with the 2x8 rafters and eliminate a 10" trim piece around the eves overhang?
Thanks in advance....
stagger19 is offline
Old 03-20-2006, 11:31 AM   #2
Master Craftsman
Big Dave's Avatar
Trade: Rustic interior woodwork
Re: Soffit Fascia Help
You can do that or what we used to do is just bob off the bottom point of the rafter to meet the 5 & 1/2 inches for your 1 by 6
Do one thing at a time, do it well, then move on.
http://www.bigdaveswoodworks.com
Big Dave is offline
Old 03-20-2006, 11:33 AM   #3
Master Craftsman
Big Dave's Avatar
I would keep the fascia at a 2 by 6 and not 2 by 4 though
Big Dave is offline
Old 03-20-2006, 11:39 AM   #4
stagger19's Avatar
Trade: handy man
Thanks for the quick reply...
Ok , yeah thats kinda what I meant, was to just take the bottom point off.
So are u saying to just use a 2x6 over the fascia?
I always though u had to use a subfascia 2By material, and then cap that with a 1By, one size larger?
Old 03-20-2006, 11:54 AM   #5
Master Craftsman
Big Dave's Avatar
You can but if you are going to use aluminum soffit and fascia the board behind it doesn't have to be pretty. The 2 by also holds the joist in more of a straight line
Big Dave is offline
Old 03-20-2006, 12:04 PM   #6
vinylguy's Avatar
Trade: vinyl decking railing fenceing siding windows
stagger, how long have you been doing this to ask such a ? not trying to be rude but dang man if youv'e been building for awhile that should be common knowledge.
vinylguy is offline
Old 03-20-2006, 12:12 PM   #7
stagger19's Avatar
Trade: handy man
Thanks for your help guys. I will do a 2x6 subfascia with a 1x8 fascia
I just wanted to make sure this was something others do, and I dont want to go out of code on the rafters.
Might be common knowledge for a Pro carpenter, but as u can see, im not.
Old 03-20-2006, 12:24 PM   #8
vinylguy's Avatar
soon will be if you keep asking the right ? and getting the right answers. came down on you alittle hard i guess but as a smart man once said there are no dumb ?s just dumb answers. keep up the good work and soon in about 20 yrs you'll see someone ask something and just smile and remember when you asked then what is 2nd nature now
vinylguy is offline
Old 03-20-2006, 01:33 PM   #9
FRAME ON!
A+Carpenter's Avatar
Trade: Decks,All phases of remodeling,
I think it would look great and as far as the framing go's I would use 2x6 all the way. A storage shed with thos specs is darn good.
A+Carpenter is offline
soffit and fascia pricing gutrman Windows, Siding and Doors 17 09-06-2009 06:11 PM
Aluminum soffit estimate? K_Tile Windows, Siding and Doors 24 07-25-2008 11:56 AM
soffit and fascia corners Bukemdano Windows, Siding and Doors 11 06-09-2008 03:55 PM
mold on cedar fascia and soffit Grumpy Roofing 2 03-11-2004 08:15 AM
