Soffit
I have an area approx 24 x 36 that I need to enclose. It is the underside of a canopy. Currently there is plywood nailed up and painted. I was think of using soffit, with 3 J-channel joints running so it would be 3 sections of 12' soffit. Any better ideas?
Re: Soffit
Replace the plywood with textured soffit board?
Re: Soffit
Textured soffit board? Do you have a link or a manufacturer or something I can look at?
Siding Windows Doors
Trade: Exteriors
Re: Soffit
Use T chanel instead of j chanel.
Burgeoning Businessman
Trade: Siding & Trim, Windows, Roofing, etc.
Re: Soffit
i've never heard of t channel.... H channel looks great in this type of situation. i'd chalk a bunch of lines though, otherwise if the ceiling isn't dead on square your final reveal will not be even.
Trade: general contractor
Re: Soffit
It would be a lot more work but if you really want to set it off you could miter in from your corners(basically look like a flat hip roof)
Trade: Exteriors
Re: Soffit
We call 3.5 inch and 5 inch double j chanel lineals T chanel for short. Two inch H bar is called H chanel for short.
Re: Soffit
Im entertaining the idea of beaded vinyl..anyone ever use it?
President
Trade: Installing windows, siding, roofing, doors, patio rooms, gutters and shutters.
Re: Soffit
I would use a 8" Pro-Bead panel with a 5/8 T-Channel and around the outside I would use a Pro-Bead J-Channel to dress it up. These are all Mastic.
Re: Soffit
A real man, (such as myself) Would make the H channel on the brake, in one piece. I do it whenever I can, Its a pride thing, and I like to show off with the coil
Re: Soffit
How would you do that..if you wouldnt mind explaining so us kiddies can follow along at home!
Re: Soffit
Ill take a picture tomorrow. I gotta think every time i go to make one, but once i do the first one, i can bang them out real quick. I use them for soffit miters cause I can make them actually 5/8" and they don't look goofy because they lay nice and flat unlike a premade vinyl one. ALSO, if you are doing colored soffit they are a lifesaver, cause sometimes you cant easily get colored H channel, and when you can its usually special order
Re: Soffit
Just an H shape, one side longer to put nails through with hems on the bottom side that recieves the soffit?
#14 | |
Re: SoffitQuote:
I drew you a picture of how I bend it. I want all you kids to make 5 a piece for homework. Make sure your hems are tight!
Re: Soffit
Nice..it will be alot less obtrusive.
Re: Soffit
Yea, you can even make the nice and wide, like a 2" pocket so a 4" face, then it looks like its meant to be there, rather than being there because vinyl only comes in short lengths.
Re: Soffit
Exactly. I can make it match the perimeter also. It will give it some visual depth instead of just being needed, its now a detail.
#18 |
Re: Soffit
I also do this one too gives even more character
#19 |
Trade: Exteriors
Re: Soffit
These brake made trims are not for a novice and can only be made to be the length of the brake. If your not very experienced bending and hanging coil you could spend a lot of time wasting coil. In a situation where you need more than one piece the job made pieces are hard to butt together unless perfectly made.
Lineals come in lengths up to 20 ft. H bar in 12 ft lengths. A 3 inch flat piece of coil cut the length of the soffit run and crimped for aluminum sill trim and with aluminum sill trim on the edges looks nice to cover a long soffit seam. |
#20 | |
President
Re: SoffitQuote:
On returns runing soffits we made our own H channels all the time, but on a large ceiling you know the old saying. White, White and White are three different colors. Thats when we would use a T-Channel and J's to match the soffit we are using for the ceiling. On large H-Channels made with the coil the color wouldn't match like the T-Channel. |
| Aluminum soffit estimate? | K_Tile | Windows, Siding and Doors | 24 | 07-25-2008 11:56 AM |
| MA Code, and vented Soffit | Patrick | General Discussion | 14 | 04-30-2008 10:44 PM |
| Hardy soffit material - anyone used it? | MHMConstruction | Windows, Siding and Doors | 10 | 11-21-2007 09:55 PM |
| soffit pricing | MHMConstruction | Construction | 4 | 10-16-2007 10:43 PM |
| roof or soffit vent? | ch0mpie | Remodeling | 4 | 10-02-2006 05:41 PM |
