#21 | |
KemoSabe
Re: So-called "professional" Siders.Quote:
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
| The Following User Says Thank You to loneframer For This Useful Post: | Tom Struble (04-26-2009) |
#22 |
Ha, one of the lines our instructor for VSI used was "just because your grand daddy showed your father to do it this way doesnt mean thats the right way to do it"
| The Following User Says Thank You to Patrick For This Useful Post: | Tom Struble (05-01-2009) |
#23 |
Trade: General Contractor, Roofing, siding, windows
There are hacks and there are cheap un-educated homeowners. Who is to blame?? Most of the time we don't know.
Sometimes even educated homeowners still just care about when it gets done, how fast, and how cheap....after all it's just siding or just shingles.. |
#24 |
Trade: Exterior Finishing
Siding should be 80% sealing the building and 20% Cosmetics.
With that 20% the house should still look as damn good as any other house done right. I still see siding guys and rock guys who don't have any idea about keeping that positive lap throughout, whether it be paper or flashing. That's the first thing my new guys have to learn, and they won't do a damn thing else until they do. By far the most important thing for sealing a house. |
#25 |
Trade: siding
FINALLY someone who gets it. You can't keep water out with a little caulking. Paper is what keeps the moisture out.
#26 | |
Trade: siding
#27 |
Trade: Framing, Remodeling
BEST RULE OF THUMB TO TELL HO...
I can do it fast, cheap and good. You can now pick 2 out of 3 |
#28 | |
KemoSabe
| The Following User Says Thank You to loneframer For This Useful Post: | Tom Struble (05-09-2009) |
#29 |
Lack Of All Trades
Trade: Professional handyman services
Darn you loneframer! You pulled perfectly good siding off to expose OSB without feltpaper...
![]() WHY??? |
#30 |
Trade: siding
funny thing is that ive pull down vinyl with nothing behind it and the sheathing looked brand new
#31 |
Re: So-called "professional" Siders. |
#32 | |
KemoSabe
#33 |
Trade: siding
#34 | |
KemoSabe
#35 |
KemoSabe
There was not much water damage to the sheathing in this case either, but it didn't prevent the water from rolling out of the gas fireplace. Of coarse, it only happened when it rained.
__________________________________ "Walking the fine line between production and perfection" __________________________________ Last edited by loneframer; 08-15-2009 at 06:55 AM. |
#36 |
If you have OSB, you have moisture no matter what. Problem is, that the water is not on the wall....it is in the wall. OSB doesn't breathe and doesn't dry from the inside out.
#37 |
Trade: siding
with all the layers of waterproof glue in plywood id question its ability to ''breathe'' also. Maybe the reason with alot the osb problems [besides the crummy nail holding] are because of the shoddy workmanship seen in this thread.Which most likely are the result of a hurry up and get it done mindset
In those pic of Loneframers i think most of the problem was caused by a poor chimney cap,which really is the fireplace guys detail. Around here they use a galvanized sheet metal that rustout in a few years |
#38 | |
KemoSabe
#39 | |
KemoSabe
Just a framing CARPENTERS view on the matter.
#40 |
Trade: siding
oh i definitely agree,theres a way that it should have been done and it wasnt,simple as that,you never know when your work is going to be removed by someone,and it dosnt really matter why, but if what you did wasnt right you look like the hack.Which i guess you are if you do work like that
| What is called a productive day on your site? | Graham J | Framing | 26 | 04-01-2009 01:33 AM |
| What's it called? | 747 | Plumbing | 13 | 03-31-2009 02:31 AM |
| Looking for exp. framers and siders, sheetrockers Bozeman MT | BattleRidge | Help Wanted or Looking For Work | 12 | 01-26-2009 02:17 AM |
| The tool repair called me after 2 years | nywoodwizard | Tools & Equipment | 3 | 05-21-2007 03:37 AM |
