Smartside Questions
Old 10-10-2014, 10:53 PM   #1
Windwash
Windwash's Avatar
Rewards Points: 148
Smartside Questions
I have only done 3 Smartside lap siding jobs and have a couple questions for those with more experience.
My first two times were for other contractors (small jobs) and we installed to LP's instructions and were gone before siding was caulked or painted. We are now almost 1/3 of the way through a whole house install for my company and I'm wondering what will happen in these locations in the next few months.
1. Siding meets trim(corners, windows, etc.) : We have been caulking the 3/16" gap as we install around the house. Will this caulk be squeezed out as the siding is supposed to expand?
2. Walls with short boards at the end: Row of siding ends with a 3' piece after a 16' piece. Does the 16' piece expand to fill most of the 3/16" gap between them or should this gap be made smaller?
3. Short pieces: How short of a piece doesn't require the gapping and can be sprung into place? Currently we are not gapping anything under about 5'.
Windwash is offline
Old 10-11-2014, 09:56 AM   #2
Rewards Points: 746
Re: Smartside Questions
We've been using SS for the last few years. Always gap the 3/16" or 1/4" at butt joints, especially if the siding is very dry. We've found that sometimes it is obvious it's been exposed at the lumber yard and then it doesn't expand as much.
We gap every piece but if we are under 5', we just go 1/8" on each end. Never go tight on anything.
Timuhler is offline
Old 10-13-2014, 05:31 PM   #3
Windwash
Windwash's Avatar
Rewards Points: 148
Thanks Tim. We had only done a few sections that were "tight" and they were under 30". We are now gapping everything. Any idea on how long before expansion takes place? I'm sure it depends on moisture but is it days, weeks, months?
Windwash is offline
Old 10-13-2014, 05:53 PM   #4
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 878
The guys around here that install the stuff( I don't) are using joint covers for butt joints and clauk the rest while siding or right after it is sided.
Randy Bush is online now
Old 10-13-2014, 06:09 PM   #5
Windwash
Windwash's Avatar
Rewards Points: 148
Thanks Randy. I had ordered a roll of color matched coil stock for drip caps and we made up some splines for the joints in the field and have been caulking other joints as we go.
Windwash is offline
Old 10-13-2014, 06:16 PM   #6
Randy Bush's Avatar
Rewards Points: 878
Again here they buy the color matched premade ones . Have not even seen anyone do drip caps with Smartside or Hardi here, just caulk it all.
Some guys use base and cap covers , others trim board covers and caulk.
Old 10-13-2014, 08:58 PM   #7
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
i'm a big believer in well flashed pocketed trims
Tom Struble is offline
Old 10-13-2014, 09:29 PM   #8
Randy Bush's Avatar
Rewards Points: 878
Good thing it is not wetter here or guys would have all kinds of rot they way flash or should I say don't flash here.
Old 10-13-2014, 09:50 PM   #9
Windwash
Windwash's Avatar
Rewards Points: 148
Do you have a favorite(s)? I've looked at the Stealth (I think thats the name) corners but am concerned that they may be too brittle when its cold here, especially around doors or areas with a lot of traffic. Are you priming cut ends before installing in the pocket?
Windwash is offline
Old 10-13-2014, 09:59 PM   #10
Trade: siding
Rewards Points: 20
yes,treat the ends,i typically fab may own pocket or use a pack out and overlay with 1x trim
the head needs a metal pocket,or at that point you can close the top off with a drip
Old 10-14-2014, 12:11 AM   #11
Windwash
Windwash's Avatar
Rewards Points: 148
Thanks. I like the pack out and overlay idea. No caulk and the cuts don't have to be perfectly 3/16" short. I'm only so-so with my brake so bending up a bunch of stuff would probably be too time consuming for me.
Windwash is offline
NC/SC/GA/AL/KY Qualifying Agent Questions Evolution2013 Contractor Licensing 4 03-20-2016 04:00 PM
New guy with Some questions wdm55 Sandblasting 1 09-04-2014 08:02 AM
LP 4x8 Siding Panels - Smartside vs 'Redwood' motaro Carpentry 14 07-09-2012 07:48 AM
First time using Ditra, questions.... ApgarNJ Tiling 22 10-31-2010 09:26 PM
Direct mail questions answered dave3717 Marketing & Sales 9 11-20-2008 12:43 PM
