Siding Question
Old 06-25-2015, 05:22 PM   #1
Joemack1's Avatar
Rewards Points: 382
Siding Question
If you had to pick from either hardie cement siding, LP smart siding or cedar to side your house what would you choose. Plus has hardie change their formula for siding since 2009?
Joemack1 is offline
Old 06-25-2015, 05:46 PM   #2
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
Re: Siding Question
hardi, pre finished and maintenance free w/ all composite trim..
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
Old 06-25-2015, 06:12 PM   #3
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 502
Re: Siding Question
Low maintenance would be the more proper term. Different types of siding work better in different parts of the country. Never been over inpressed with Hardi.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
CompleteW&D (06-29-2015)
Old 06-25-2015, 07:01 PM   #4
I'm The BOSS
jaydee's Avatar
Re: Siding Question
good point, "less maintenance required"
I'm not a fan of the smart siding by lp
Facebook
jaydee is offline
Old 06-25-2015, 07:15 PM   #5
Randy Bush's Avatar
Rewards Points: 502
Re: Siding Question
Me neither. But then I am pretty much steel only when it come to siding.
Old 06-25-2015, 08:00 PM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Re: Siding Question
Hardie siding & trim....
Pretty much bullet proof around here.
griz is offline
Old 06-25-2015, 08:05 PM   #7
Thread Reading Aficionado
Builders Inc.'s Avatar
Trade: Building Contractor
Rewards Points: 1,380
Re: Siding Question
Hardi, installed correctly, please don't get caulk happy.
Builders Inc. is offline
Old 06-25-2015, 09:33 PM   #8
kingcarpenter's Avatar
Trade: G.C./carpenter
Rewards Points: 544
Re: Siding Question
Hardi siding and trim. Nothing is maintenance free.
kingcarpenter is offline
Old 06-25-2015, 09:34 PM   #9
Talking Head
EthanB's Avatar
Rewards Points: 14
Re: Siding Question
Hardi for me too. Unless I have to install it, then I'd go cedar. I hate installing hardi.
Planer.....
EthanB is offline
Old 06-25-2015, 09:50 PM   #10
#MAGA
EricBrancard's Avatar
Trade: Builder/Renovator
Re: Siding Question
Cedar with PVC trim. Nothing looks better than cedar.
EricBrancard is offline
The Following 2 Users Say Thank You to EricBrancard For This Useful Post:
Golden view (06-26-2015), superseal (07-17-2015)
Old 06-25-2015, 10:05 PM   #11
Jimbo2015's Avatar
Trade: solar
Rewards Points: 178
Re: Siding Question
agree
Jimbo2015 is offline
Old 06-26-2015, 02:00 AM   #12
Walraven's Avatar
Trade: carpenter/joiner
Rewards Points: 368
Re: Siding Question
Second using cedar last two jobs its what we have used looks awesome.
Walraven is offline
Old 06-29-2015, 06:27 PM   #13
windows & siding
HomeSealed's Avatar
Trade: windows and exterior remodeling
Rewards Points: 612
Re: Siding Question
LP over hardie all day... In fact I replace a lot of older Hardie jobs with LP... Here is a big one that we just finished
HomeSealed is offline
Old 06-29-2015, 09:10 PM   #14
larry228's Avatar
Trade: residential remodeling
Rewards Points: 115
Re: Siding Question
Can you elaborate on this? I have not installed Smart Side, have only done a small amount of Hardie. I was impressed by what I have seen of smart side from the sales reps and I am seriously considering using it on the next house
It comes in longer lengths, works with conventional tools, closer clearances to wet areas.
Can you tell me the negatives so I go back and look at Hardie again? I have a bit of distrust after the crap siding that LP sold 20 years ago as "inner seal" but the smart side product seems to have answered these concerns
larry228 is offline
Old 07-17-2015, 07:17 PM   #15
rojigga's Avatar
Trade: Exterior Finishing
Rewards Points: 152
Re: Siding Question
Hardie siding over any other fibre cement siding, and Smartside Trim over Hardie Trim. If you like Hardie Trim, you don't install the trim yourself. It's way too heavy and flakes when mitred. Also only comes in 12' pieces, which makes waste factor ridiculous around here.
rojigga is offline
Old 07-17-2015, 09:56 PM   #16
FrankSmith's Avatar
Rewards Points: 4,154
Re: Siding Question
Cedar for me with aluminum on the overhangs and window and door trim. If you buy it pre painted form the factory, paint your cut ends and install it with air flow behind it, the maintenance issue is minimal. It can easily make it 15 to 20 years with out needing to be repainted. In my opinion a paint job every decade or two is a good thing just to keep the house looking fresh. Why install a product trying to imitate wood when you could just have wood?
FrankSmith is offline
Old 07-17-2015, 10:08 PM   #17
Renaissance Man
superseal's Avatar
Rewards Points: 4,950
Re: Siding Question
Dang bloody woodpeckers we have around these parts are enough to make you think twice sometimes.
I prefer brick or stone, but that's another thread
supersealconstruction.com
superseal is online now
The Following 2 Users Say Thank You to superseal For This Useful Post:
FrankSmith (07-17-2015), HomeSealed (07-21-2015)
Old 07-18-2015, 09:47 AM   #18
CompleteW&D's Avatar
Trade: Windows, Doors, Siding, Enclosures
Rewards Points: 2,936
Re: Siding Question
You should consider using EVERLAST. It's made from crushed stone and PVC resins. The color goes al the way through and has a lifetime warranty including a lifetime fade warranty.
No special tools needed, it's light weight and a dream to install. The only drawback is it's very expensive. We generally install it with a wood grain PVC trim.
- John Williams
Complete Window and Door
Originally Posted by TNTSERVICES View Post
As accomplishments go, getting me to talk is an easy one.
CompleteW&D is offline
Old 07-18-2015, 11:04 PM   #19
hammer689's Avatar
Rewards Points: 38
Re: Siding Question
Cedar is good and looks great but bang for your buck it would have to be Hardie plank in my opinion
hammer689 is offline
Old 07-19-2015, 08:40 AM   #20
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
Re: Siding Question
wrc shakes,aside from masonry or stone it's just about bullet proof when done right..
Tom Struble is offline
hdavis (07-20-2015)
fiber cement siding issues. chapstick Windows, Siding and Doors 36 08-30-2012 09:14 PM
siding question jhcontracting Remodeling 40 11-22-2011 11:41 PM
Question for Vinyl Siding Guys premierpainter General Discussion 12 02-10-2009 02:16 PM
quick siding Question timrev8 Carpentry 4 09-15-2008 11:33 PM
Vinyl Siding install question davinci Windows, Siding and Doors 14 09-13-2008 10:28 PM
