Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Old 01-21-2007, 12:10 PM   #1
Trade: remodeling contractor
siding over asbestos
Do i have to fir it out? I've heard you can nail trough it. Anyone ever done it?
mikec is offline   Reply With Quote
Old 01-21-2007, 04:05 PM   #2
Trade: general contractor
I do it all the time, no problem. You don't have to fir it out, you can nail through it but may bend the occasional nail when hitting the spots where the asbestos is lapped (double).It does break but most of it stays on the wall,may be a few small pieces on the ground to clean up at the end of the job. I am talking vinyl or steel siding with a backer behind it, not sure what kind you are referring to.
house bldr is offline   Reply With Quote
Old 01-22-2007, 08:49 PM   #3
stop botherin' me!
Grumpy's Avatar
Trade: Roofing Siding Gutters Windows
Nail through it no problem. Install a insulation board first to even out the surface. Some tiles may break when nailing so wear proper protection.
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline   Reply With Quote
Old 01-29-2007, 09:11 AM   #4
Trade: vinyl decking railing fenceing siding windows
asbestos
generally around here we remove it. it makes a much nicer look to the end job.i have sided over and they are right use a backer board. however i don't know why it's such a problem to remove as long as its non-frayable ( most is ) check with your local land fill just throw it in the pick up tarp it and take it to the landfill. here in pa its around $56.00 a ton to dump not any more expensive than regular garb. there is a little paperwork to fill out at the landfill but they will give you lots of forms to keep for future jobs. not so bad and besides sounds like these customers are trying to get it done cheap as possible. not the best possible so be careful. so yes you can do it and get away with it but would reccommend tearing old off and also check with your manufacturer about warrenty issues when leaving old siding on! hopes this help later
vinylguy is offline   Reply With Quote
Old 01-31-2007, 04:50 PM   #5
Thanks guys
This is actually a question for my house. I have no idea whats under the asbestos,but something is. The siding is pretty built up, you can see on the window casing. I'm planing on doing it in vinyl,I may strip it.
I know it will look much better in the end. I'll try to post some before and after pics when i get done.
Old 01-31-2007, 07:33 PM   #6
Trade: Siding
This may be a dumb question but dont you have to be licensed to remove asbestos??
ProSide is offline   Reply With Quote
Old 02-01-2007, 12:06 AM   #7
Trade: Home improvement
Normally the HO does not
OddJob is offline   Reply With Quote
Old 02-01-2007, 01:04 PM   #8
All my years of siding I always went over it cause it was fairly flat and was told it was safe for this process. I totally believe any job stripped is neater period, if it were up to me they should make it code like roof layers that it be removed if more than 2 layers ---you can put vinyl on anything thats why it everyone does it. I dont know exactly the procedure for removale but I know it is expensive. I thought you need wear suits, spray it down and specially bag it then ship to and approved landfill. The permit is special and the D.E.P. IS also paid for filing. I dont know for sure about this. It seemed like too much hassle to get involved with.
tom m is offline   Reply With Quote
Old 02-07-2007, 01:51 AM   #9
Grumpy, How thick is the insulation board?
Thanks,
Old 02-07-2007, 06:54 PM   #10
Trade: framing
3/8
framer long is offline   Reply With Quote
Siding & Windows Sales needed - Chicago area - NO SALES EXPERIENCE Grumpy Help Wanted or Looking For Work 4 05-26-2009 02:51 PM
Watertight integrity of viynl siding? mci2980 Windows, Siding and Doors 71 11-24-2007 04:15 PM
Asbestos siding osborn Painting & Finish Work 5 01-05-2007 07:20 AM
asbestos siding bill6078 Windows, Siding and Doors 4 03-05-2006 11:33 AM
