Siding First Or Soffit First?
Old 06-10-2011, 10:58 PM   #1
kayn_os's Avatar
Rewards Points: 25
Ok so I have seen it done both ways over the years and from what I have always been able to sort out it is usually because the HO had one done first then the other not both at the same time. My question is, if I am stripping both soffit and siding which should go back up first? I was trained to put up the soffit first and then J to that but I want to know if that is the proper way to do it? Always looking to improve and offer better service to my customers.
Matt
kayn_os is offline
Old 06-10-2011, 11:27 PM   #2
CompleteW&D's Avatar
Trade: Windows, Doors, Siding, Enclosures
Rewards Points: 2,936
Re: Siding First Or Soffit First?
We always do soffit first then side to that.
You don't "J" to your soffit along the eaves do you? You need to on gable ends, but along straight runs up under the eaves, we always finish into a dual undersill trim piece. We like the dual channel over the regular undersill or finish trim because it's a much firmer (and straighter) piece of channel. The end result is a nice clean straight line across the top of the siding.
CompleteW&D is offline
Old 06-11-2011, 07:01 AM   #3
buddy110's Avatar
Trade: Exteriors as a whole
Rewards Points: 530
On a straight run, I run my siding up first than run soffit J over top of it. It looks much cleaner that way. On the gables I don't use soffit J I just bend a return and run my siding J up to the soffit which holds it in place
buddy110 is offline
Old 06-11-2011, 09:50 AM   #4
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 958
I do it both ways just depending on how the top planel will come out . I like siding first if can , looks cleaner IMO. Got a house coming up to reside that was sided first, steel, now will have to just run electric shears along top planel to remove siding then new will just go over top with sill trim on it rather thentear the overhang off. If I have to cut the top lock off to do the top panel then the overhang gets done first.
Randy Bush is online now
Old 06-12-2011, 02:10 PM   #5
Gandalf's Avatar
Trade: siding ,windows
Rewards Points: 25
So,how to install the latest panel without Finish J-Channel ,Snap-lock Punch,clips......?
Gandalf is offline
Old 06-12-2011, 03:08 PM   #6
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
finish j?is there really such a thing?
Tom Struble is offline
Old 06-12-2011, 03:12 PM   #7
Randy Bush's Avatar
Rewards Points: 958
Good one Tom. That extra gap in the J is for caulk right.
The Following User Says Thank You to Randy Bush For This Useful Post:
Tom Struble (06-12-2011)
Old 06-12-2011, 04:46 PM   #8
Trade: siding
Rewards Points: 20
i usually do just an L shape in the gables too,then the siding j will rest directly on the soffit instead of back to back j and the gap you get when you do it
Old 06-12-2011, 05:41 PM   #9
SeanInOnt's Avatar
Trade: Siding windows doors
Rewards Points: 75
Soffit j over vinyl? What do you do over the corners?...L cap and soffit just rests on top? Wouldn't that flap away in the breeze?
SeanInOnt is offline
Old 06-12-2011, 06:29 PM   #10
Trade: siding
Rewards Points: 20
yea the flappin scares the bats away
Old 06-12-2011, 06:41 PM   #11
Construction Connoissuer
CCCo.'s Avatar
Trade: Construction Remodeling - Renovations Repairs
Location: Kirklin, IN "Proudly Serving Central Indiana Area"
Rewards Points: 1,320
Huh, ??
F-channel, no one uses it?
I always have,...I only use J-channel out on the ends of an adjacent overhang to finish it off, and give it a good boxed look.
I seen several replies, and see no mention of F-channel.
You boys baffle me sometimes,..I even fast forwarded to toms reply, thinking tom will surely mention it, nope.
James Crow - Crow Contracting Company, LLC - Central Indiana Remodeling Contractor
Facebook l Youtube l Merchant Circle
Home, Kitchen & Bath Remodeling - ~ - Facility Maintenance & Repair Solutions
Want to contact us? - Call ~ 765.279.8271
CCCo. is offline
Old 06-12-2011, 07:00 PM   #12
Randy Bush's Avatar
Rewards Points: 958
Originally Posted by CCCo. View Post
Huh, ??
Very rarely ever use F channel , have not found that many times when it was really going to be of any advantage to me. J is easier and faster for me and cost almost half of F channel, aluminum, anyhow And that makes a differents on my profit margin and how much stays in my pocket .
Old 06-12-2011, 07:03 PM   #13
Trade: siding
Rewards Points: 20
no i don't use it,i don't use vinyl soffit j if i can't get aluminum soffit chanel in the color i need i bend my own
this ia probably more of a regional thing that a this is better than that thing
Old 06-12-2011, 07:09 PM   #14
SeanInOnt's Avatar
Rewards Points: 75
No f channel here either...with Tom on the aluminum j...only ever used vinyl soffit on a cpl prefab beauts (cough cough)
Old 06-12-2011, 07:15 PM   #15
Trade: siding
Rewards Points: 20
this is in the gable ends Sean the L shape goes on first then the soffit then siding j
Old 06-12-2011, 07:21 PM   #16
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 890
We use a combo f channel with a snap to receive a cornice trim. Certainteed makes it and so does crane and Mastic. It gives a nice look because it is 2.5 inches wide. How does the last row of siding expand and contract if you nail though it with your soffit j or f?
overanalyze is offline
Old 06-12-2011, 07:30 PM   #17
redwood's Avatar
Trade: Carpentry Contractor
Rewards Points: 476
Definately regional, I can only picture those things in my head. Never seen any of them. Well maybe J channel, if that is the same thing as might be put on a exposed sheetrock edge.
Heck, I haven't ever seen a vinyl sided house.
Mark
Pioneer, CA
www.creative-redwood-designs.com
redwood is offline
Old 06-12-2011, 07:40 PM   #18
Trade: siding
Rewards Points: 20
you just blew my mind Mark
Old 06-12-2011, 08:49 PM   #19
Gandalf's Avatar
Rewards Points: 25
Try this in Colorado.6am-30F, 1pm-95F.You can lose your job
Gandalf is offline
Old 06-12-2011, 09:16 PM   #20
Trade: siding
Rewards Points: 20
come on Gandalf he was just kidding there are more ways than 1 to do anything,just need to learn how to get the results you want
soffit and siding trim installation Home Serve Windows, Siding and Doors 54 08-11-2013 10:07 AM
New Siding Question RandyB1986 Windows, Siding and Doors 4 04-22-2010 11:35 AM
ABC Supply Co. Inc. Acquires Chesapeake Siding and Roofing Grumpy Roofing 0 03-03-2009 08:40 AM
siding an old house gtmstang Windows, Siding and Doors 14 12-20-2008 05:21 PM
leveling siding and soffit mattp Windows, Siding and Doors 7 07-08-2006 01:01 PM
