Trade: Homebuilder / renovator
Shingle Shingle Siding
Does anyone know the man hours per sqare including paper These are 18 inch with an 8 inch reveal? Using an air stapler .Many windows , These should be inclued in the square footage calculation , shoul d they not?
Re: Shingle Shingle Siding
Some thing like this?
Re: Shingle Shingle Siding |
We spent about 45 minutes per sq of siding, 3 men. All the trim was custom bent with built in J channel. This is prefinished concrete also. And HO was a architect watching closely that we did not install damaged panels.
Sophisticated Siding Guy.
Trade: Siding and Trim Specialist
Is that white j-channel around those windows?
Shingles look good but man it needed some more jazz. Window wraps at the least. I think 45mins a square is low. It really depends on your setup. Manlift I'd say 45 mins is about right. Ladder or pump jacks 1.5 or so. |
All metal was custom bent to HO's desired look. Bent in J around windows with look of brick mould. All corners are custom bent with J built in also. Took at least ten different sample designs before HO settled on one.
Yeah, lift and bucket truck were used. We was delivering pizzas the week before this, thought we'd give it a try. You can learn alot from a Builder Bob video.
Nice work MB!! Who makes that siding?
President
Trade: Installing windows, siding, roofing, doors, patio rooms, gutters and shutters.
I would like wider trim aroung the windows and I don't like the nails showing under the windows. With a wider trim you could cover those nails.
James Hardie Staggerd Shakes. I'd like wider trim too,(and different colors) but I'm not the HO. Had to be surface nailed under windows, nails were painted.
President
If your going to use a metal trim aroung the windows, on the bottom you could do it in a two piece, Pat does all of his two piece, with a receiver and cover your nails that way.
| ABC Supply Co. Inc. Acquires Chesapeake Siding and Roofing | Grumpy | Roofing | 0 | 03-03-2009 09:40 AM |
| 100+ y/o siding repair. to run or not to run. | VALCOR | Windows, Siding and Doors | 19 | 02-25-2009 06:22 PM |
| siding an old house | gtmstang | Windows, Siding and Doors | 14 | 12-20-2008 06:21 PM |
| Selling removed cedar shingle siding? | TigerFan | Windows, Siding and Doors | 5 | 06-20-2008 06:12 PM |
| log cabin vinyl siding | Home Serve | Windows, Siding and Doors | 6 | 04-28-2008 08:16 AM |
