Sheathing Gap At Corners
Old 06-10-2009, 10:08 AM   #1
LetItBeLEED's Avatar
Trade: green building
My current siding job includes installation of factory-made Certainteed PVC corner trim. The walls are sheathed with 1by boards, and the sheathing does not extend past the framing for any wall.... in other words, when I hold a scrap of pvc corner board in place, there's a vertical gap under the corner trim running up its entire length, and the gap is 3/4" square in cross section because the 1by sheathing boards are not butted up one against the other.
Whaddya'll think? Should I do anything to fill that gap before applying housewrap? I'm thinking of at least adding a small bit of PVC scrap to fill the gap at least at the bottom to help keep out vermin and backsplash, since the sill is only 6" above grade.
Thanks for your thoughts; I used to offer pennies, but hey - there's a recession on.
Steve
LetItBeLEED is offline
Old 06-10-2009, 07:23 PM   #2
Tom Struble's Avatar
Trade: siding
Re: Sheathing Gap At Corners
i usually do an aluminum wrap [6x6] over the tyvek on all my corners and i wrap a ''bug shield'' along the bottom at the starter line under the wrb to close off the sheathing from the foundation
Tom Struble is online now
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
Burns-Built (01-11-2010), DavidC (03-24-2010)
Old 01-10-2010, 04:30 PM   #3
Custom Builder
Chris@Sunrise's Avatar
Exterior sheething never overlaps each other that ive ever seen or heard of. Is this your first siding job weird question dont worry about that gap wrap it, tape it, side it
Chris@Sunrise is offline
Old 01-11-2010, 10:48 PM   #4
Burns-Built's Avatar
Trade: Residential Construction & Masonry
Just seal the bottom of the corner if there is a small gap. Tom's got a great idea though with wrapping the corner as a bug/insect barrier. Throw that over your Tyvek, tape and side away!!
What kind of siding? Vinyl??
There will always be a market for quality.
Burns-Built is offline
Old 03-23-2010, 04:41 PM   #5
caybound's Avatar
Trade: Remoldeling, Maintence & GC
We do something similar here due to termite issues, but in the framing stage. Use vycor or felt under the sill then staple it up over the sheathing to protect the edge (then Tyvek over). Cut it flush on the interior - cram some diatomaceous earth in when we have it (it's like shards of glass to anything with an exo-skeleton). What do you use for your bug guard?
caybound is offline
Old 03-24-2010, 07:28 AM   #6
Trade: siding
i just use aluminum but i like the sound of yours better
Rigid Foam Board under sheathing milfordtom General Discussion 12 05-13-2009 12:12 AM
sheathing/ opinions wanted agboett Framing 39 03-04-2009 11:57 AM
Frost on underside of roof sheathing ApexCS Remodeling 5 01-15-2009 01:55 PM
TimberTech Composite (Earthwood) Installation - picture frame corners and HFS jackem Decks & Fencing 6 11-06-2008 04:05 PM
Question about inside corners Lone Wrencher Drywall 36 12-08-2005 07:37 PM
