Security Door Vs. Burglar
What are some approaches you guys use to make ordinary solid wood core doors (or any door for that matter) stronger against break ins?
some things i do are: - Add one 3" screw at each hinge to frame, and hinge to door - Add 2" screws at strike (when possible) - Door Jamb pins - 4 1/2" hinges (step up for residential) - If hinges are exposed I use NRP hinges ......these are just some things i do on residential doors. If im working on industrial applications the list goes on. Ussually on Industrial we use Simplex 1000 or 5000 along with some heavy duty S&G slide bolts or S&G 8400's or on and on. |
Trade: windows-siding
Re: Security Door Vs. Burglar
how bout a 20 guage steel door....
Where do you guys live that you have to reinforce doors on houses like this?
well obviously i could just use a 10" thick steel door!! i guess i just want to know what kind of hardware or tricks you use on doors that a customer doesnt want to replace!!! an existing wood door or if the 20 ga steel door is existing what can you do to make it stronger via hinges or other products on the market ? or even better your own inventions you have made for your installations???
Ever see Maxwell Smart opening up his apartment door?
TRC
Trade: Windows and Doors
Sounds like you're pretty much wasting your time. Just went on two estimates this week with kicked in doors and the jambs held up fine. In both cases the door broke where the bolts are. If your house is targeted....YOUR SCREWED!
#7 | |
Re: Security Door Vs. BurglarQuote:
Well thats the idea of the thread, your response isnt very informative !!. OK, so you went and looked at some jobs.... how you gonna fix the problem of the bolts busting out ?? What are you gonna bid to fix the doors and make the customer happy. Now were getting somewhere, your learning..... |
#8 | |
Capra aegagrus
Short of a 4' bar slipped into hooks at each side of the doorway, there's only so much you can do to deter a determined intruder. The only thing I haven't seen mentioned so far is the U-shaped metal plate you can put on the slab to contain the lockset and surrounding wood. Also, many doors have a metal plate on the "outside" of the jamb (between the jamb and the rough framing) for the deadbolt to engage. With both of those in place, it would be easier to kick in the hinge side than the bolt side. Meanwhile, that window just 6' away from the door would be REALLY easy to just toss a brick through... Please update your profile to indicate your location. |
#9 | |
TRC
#10 | |
Its informative when you answer my question. So what do YOU do to make a door stronger. And you dont have enough info to know how strong my doors are...... i take 1 3/4" strap 2' long and 1/4" thick w/ staggered screws, route out my frame on the strike side (with strike and deadbolt holes routed out), so my bolts aint goin nowhere... So once again I ask you "TRC" what do you do when your customers doors are kicked down to make them stronger ? |
Trade: home improvements and renovations
All your ideas sound good, but like said beef up the door and the glass window next to it is used. Now we need bars on the windows?
Maybe a good alarm system would help. I like a 150 lb. dog snarling at the the door or maybe the sound of a pump action to make the door solid. |
#12 | |
TRC
Trade: Custom Home Builder & Additions
I have always reinforced connections with screws- hinges and strike plate.
That being said, if someone is willing to kick in a door they would certainly bust a window. The way I see it is that for the most part locks keep out the honest (and maybe half-assed honest) people. As an aside I am always surprised how any entry locksets are improperly installed- such that the locking pin is not held in and drops into the strike plate hole. |
#14 | |
Thanks TRC, i know if someone wants to get in they will !!, i just try to make it harder for them. If i am installing a door for a family in a bad neighborhood and they have kids, than i just try to make what they have as good as i can. Most of these ppl dont have a lot of money, so if a few extra longer screws and minor materials makes the burglar have to kick the door twice instead of once it helps ! |
#15 | |
TRC
| The Following User Says Thank You to TRC For This Useful Post: | HOOT (03-15-2009) |
| Security wire code?? | Jason Whipple | Low Voltage | 24 | 03-19-2009 09:02 PM |
| "Breaking In" to the security field | gury | Low Voltage | 13 | 02-10-2009 04:13 AM |
| security warning | genecarp | General Discussion | 0 | 10-03-2008 04:18 PM |
| removing Norton security | olzo55 | Technology | 5 | 09-28-2008 06:48 PM |
