Scaffolding Options For Install Vinyl In Narrow Space
I have to install vinyl siding on 3 sides of a house. 1 Side has about 21 inches of space between the 2 houses.
Im 99% my AlumApole wont fit through the space. What are my options? |
Trade: Siding and renovation contractor
Re: Scaffolding Options For Install Vinyl In Narrow Space
I would guess if your careful 22" should be enough to set up your scafofding. you might have to remove your ladder stand though.
Bah Humbug!
Pump jacks? Not sure how wide they are, but you might be able to rent a set that fits.
I hope you bid it real real real high for the PIA factor. |
I've seen guys lean extension ladders against the neighbor's building and use ladder jacks in that case. I know, it's darned near standing straight up, but it seems to work out for some. It's not like your ladder's going to slip.
i'll try my ladder jacks tomorrow
any other options? i havent tried the ladder jacks yet.
Sophisticated Siding Guy.
Trade: Siding and Trim Specialist
A rope and harness?
Pump jacks are designed to carry as much as a 24" wide plank extended so if it were closed its got operable for 21". Remove the back bench.
How long is the side of the house ? If you could set up your pump jacks on the outside corners and get a long Alum. Scaffolding Walk Plank, I think I've seen them up to 28' long.
Trade: Commercial and Residential siding
If you take the ladder rack portion off the pump jack, you will have better access and maneuverability. Pump jacks are the most efficient even if it takes a little extra time to take the jack apart, I believe it is only two bolts.
#11 | |
Professional Remodeler
"A" frame ladders? You didn't say how high you have to go. Maybe build some A-frame style supports to fit between the houses. What about using extension ladders sideways and achoring them to the house somehow, one ladder at each end to support the pick running right through the rungs?
-Mike- Falcon Contracting Residential - Commercial
| Siding: Aluminum vs. Vinyl | Grumpy | Windows, Siding and Doors | 21 | 03-30-2010 08:02 PM |
| Fiber Cement almost same cost as Vinyl? | MKECONTRACTOR | Windows, Siding and Doors | 17 | 12-20-2008 06:34 PM |
| Scalloped Vinyl | Shamrock | Windows, Siding and Doors | 1 | 09-18-2006 04:20 PM |
| vinyl decking with hot tub | nriddock | Decks & Fencing | 2 | 06-16-2006 02:10 PM |
| Vinyl on vinyl? | reveivl | Flooring | 13 | 12-16-2005 07:00 PM |
