Safety Glass...
Old 08-10-2009, 06:01 PM   #1
carpentershane's Avatar
Trade: general carpenter
Safety Glass...
I am ordering windows for a customer, I have 14 in all, but I am a little unsure of myself on one point.
2 of the windows being replaced, a 8'0"x 6'0" and a 6'0"x 6'0" have are being replaced with 2 smaller windows each (basically 2- 4'0"x6'0" SH minus 2 1/4" a piece, and 2- 3'0"x6'0" SH minus 2 1/4" a piece. 3 2x4's for a mullion in between the windows.)
The windows are both within 18" of the floor so they will need to be tempered glass. Now for the kicker, does the whole window have to be tempered or just the active?? The 4'0"x6'0" SH will have a pane that is greater than 9 sq. ft so I would assume that these windows will need to be all tempered whereas the 3'0"x 6'0" once you account for the vinyl frame will only need the actives tempered. Am I right or wrong??
carpentershane is offline
Old 08-10-2009, 06:05 PM   #2
Patrick's Avatar
Re: Safety Glass...
Depends on where your located and the inspector.
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 08-10-2009, 06:17 PM   #3
Re: Safety Glass...
I am on the olympic Peninsula, WA state and because it is an r and r in the county a permit, and therefore an inspection is not necessary. I am asking this question purely based off the IRC.
Old 08-10-2009, 06:23 PM   #4
Patrick's Avatar
Re: Safety Glass...
again its a gray area All glass within 18" of the floor must be tempered. Its up to an inspector to make that determination. Some window manufactures you will find you have to beg them to put two different kinds of glass in the window mainly because its so easy for them to screw it up
Patrick is offline
Old 08-10-2009, 07:29 PM   #5
Re: Safety Glass...
I am installing Milgard StyleLines, you can order w/ 2 types of glass, we'll see if they can keep it straight. I think I will call the county in the morning and see what they say.
Old 08-11-2009, 06:51 PM   #6
slave driver
glassman's Avatar
Trade: project manager commercial contract glazier
Send a message via Yahoo to glassman
Re: Safety Glass...
For the piece of mind of safety the cost of tempered safety glass is cheap compared to a law suit or worse any serious injury to someone.
glassman is offline
Old 08-12-2009, 01:07 AM   #7
Re: Safety Glass...
I talked to the county this morning. They said that all that was need was to have the actives tempered, the fixed pane is high enough that it was not an issue.
Old 08-12-2009, 04:29 PM   #8
fenestrationman's Avatar
Trade: Engineering Windows and Doors
Re: Safety Glass...
Another note. Are any of the window within 24" of a door jamb. If so, they will need tempered.
fenestrationman is offline
Old 08-12-2009, 07:04 PM   #9
Re: Safety Glass...
Nope, no windows within 2' of the arch of the door. Only safety glazing concern is 2 low windows. This house was built in the 70's has 92" ceilings and some big windows in the living room.
Old 08-12-2009, 10:56 PM   #10
Tru_Blue's Avatar
Trade: Windows, Doors, Glass
Re: Safety Glass...
Glad to hear the question is answered.
For what it's worth, the dimension you mentioned (within 18" of the floor) is not a universal building code. It can vary from state to state. In my neck of the woods it can be much less than 18" off the floor and still not be tempered. Anything real close to the floor I would normally still order as tempered, but it's not a requirement.
Bottom line: it's best to check local and state codes. That can easily be done online these days if one knows where to look.
Tru_Blue is offline
Old 08-13-2009, 08:52 PM   #11
72chevy4x4's Avatar
Re: Safety Glass...
can you order a window with one sash tempered the other not? I don't recall it being an option on order forms in the past w/ Simonton-maybe with other suppliers though. The cost difference would be small at that point-the weight savings on the other hand would be great!
72chevy4x4 is offline
Old 08-15-2009, 09:00 PM   #12
Oberon's Avatar
Trade: Glass and windows
Re: Safety Glass...
There is no weight difference between tempered and untempered glass.
Are you thinking of laminated possibly?
Oberon is offline
Old 08-16-2009, 02:33 AM   #13
Re: Safety Glass...
The windows I am installing are Milgards and one can order one sash with tempered and the other standard glass. I am ordering them w/ tempered actives (SH).
Old 09-02-2009, 08:33 PM   #14
ssgtcarroll's Avatar
Trade: Glass/Doors
Re: Safety Glass...
At the minumal upcost of tempered just go tempered...
ssgtcarroll is offline
New OSHA standard OsNap Health & Safety 8 01-08-2010 09:19 PM
Frameless glass shower build, ideas please rotarex General Discussion 23 12-29-2008 09:57 AM
Safety Coordinators - KY Safety Guy Help Wanted or Looking For Work 0 11-17-2008 08:32 AM
Powerhouse Safety Coordinators - DuQuoin, IL Safety Guy Help Wanted or Looking For Work 0 10-15-2008 09:08 AM
Construction Safety - Dalton, GA Safety Guy Help Wanted or Looking For Work 0 08-19-2008 10:57 AM
