Ring Shank Nails With Fiber Cement Siding?
Old 01-10-2009, 04:15 PM   #1
member
Jer's Avatar
Trade: Siding, windows, Aluminum crown
I recently read that ring shank nails should not be used with fiber cement siding because they can blow out a hole on the inner side of the panel thereby causing nail hold failure.
Has any one else heard this?
Any feedback will be appreciated
Jer is offline
Old 01-10-2009, 04:21 PM   #2
Kaiser's Avatar
Trade: Project Management
Re: Ring Shank Nails With Fiber Cement Siding?
Seems to me that any nail would cause the same blow out.
I'm not sure how ringshanks would cause that.
"Go confidently in the direction of your dreams. Live the life you have imagined."
Henry David Thoreau
Kaiser is offline
Old 01-10-2009, 09:31 PM   #3
Tom Struble's Avatar
Trade: siding
if you overhang a pc of hardi on a bench and shoot a ring shank thru it you will most likely see blowout on the backside.
But with the panel supported as you normally do siding i dont think it does blow out.imo
Tom Struble is offline
Old 01-10-2009, 09:37 PM   #4
Al Smith
A W Smith's Avatar
when you blind nail its not supported.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 01-10-2009, 11:47 PM   #5
Trade: siding
how do you mean Al?
its supported by the wall
Old 01-11-2009, 12:58 PM   #6
Al Smith
A W Smith's Avatar
how do you mean Al?
If you install by blind nailing just above the exposure. There is a space between the hardi and the wall. Not much. but there is a slight space. only the top most edge of the hardi touches the wall and the bottom lays against the previous course.
http://www.ilevel.com/literature/t_jamesHardie.pdf
Al Smith
Old 01-11-2009, 01:15 PM   #7
Trade: siding
yes ,a small space caused by the overlap? i see your point
Old 01-15-2009, 01:50 AM   #8
Danceswithlader's Avatar
Trade: Residential Exteriors...Roofing, Siding, Windows,
Are you using a hitachi coil nailer or maze nails? I've even seen a hardi training tape back in the day using 2" roofing nails.
Personally, Ive used them all and almost prefer the hand nails...no air to run and I love the sound of my stiletto in the morning. the crew on the other hand NEEDS the air guns, or they wont make wages!
Yer doin that wrong!
Danceswithlader is offline
Old 01-15-2009, 02:29 AM   #9
Trade: siding
I use the makita 611 good gun
Old 01-16-2009, 12:54 AM   #10
rojigga's Avatar
Trade: Exterior Finishing
I would love to see an instructional video.
rojigga is offline
Old 01-16-2009, 01:39 AM   #11
I used to think so.......
wallmaxx's Avatar
I attended a lumber yard vendor's breakfast put on by Hardie about a month ago. The rep for the west coast region said that they recommend smooth shank only for their siding products.
It wasn't from back side blow out as much as the ring shanks make the hole bigger and looser than a smooth shank. (I don't know one way or the other...its just what the dude said).
wallmaxx is offline
Old 01-16-2009, 08:41 AM   #12
Trade: siding
ive used a ring shank and i gotta say if i had to remove a piece it was tuff to do.
Old 01-16-2009, 04:18 PM   #13
Al Smith
A W Smith's Avatar
I have a Makita siding nailer i got almost new for a bargain at an automotive swap meet (go figure) I use it mostly for pine soffit or lite sheathing work, Where can i get smooth wire collated plated siding nails? All Ive seen available were ring shank.
never mind,
http://www.bestmaterials.com/detail.aspx?ID=15039
COMMON APPLICATIONS: Fiber Cement Siding, etc.
Al Smith
Last edited by A W Smith; 01-16-2009 at 04:22 PM. Reason: neglected to uncork my Google Fu
Old 01-16-2009, 09:55 PM   #14
member
Jer's Avatar
I have been using the Hitachi coil nailer for all my fibercement and ring shank nails since my hardi rep recommended them way back when fibercement first became popular here in Utah fifteen or so years ago.
In light of what Wallmaxx is saying I wonder if there has been recent studies or problems that have caused hardis reps to discourage ring shank use now.
Jer is offline
Old 01-16-2009, 11:27 PM   #15
dlcj's Avatar
Trade: home builder carpenter Central Alabama
I hope not!
does that go for screw shank too?
I just finnished my first fiber cement siding job. It was the 4x9x3/8 sheets and hand nailed it with 6 penny screw shank siding nails.
dlcj is offline
Old 01-17-2009, 01:57 PM   #16
member
Jer's Avatar
Screw shank nails were not mentioned in what I was reading...very good question though. You probably have nothing to worry about. Were you nailing batts over the 4x9's?
Jer is offline
Old 01-18-2009, 12:58 PM   #17
dlcj's Avatar
nope, not this time. Its up to the painter to get a good coat of paint on there and caulk what needs to be. It'll probably be painted a dark color and the nails wont show to bad anyway.
dlcj is offline
best type of fiber cement siding tvootz Windows, Siding and Doors 25 01-11-2011 08:54 PM
Fiber Cement Siding on sloping lot GregWCIL Construction 10 08-29-2008 01:35 AM
Vinyl vs Cement Fiber Siding Dave Buskirk Carpentry 11 07-05-2007 08:41 PM
fiber cement siding paint pn70 Windows, Siding and Doors 2 01-23-2007 12:10 AM
ss110a shear for fiber cement siding? willbone3 Construction 4 04-05-2006 10:07 PM
