Trade: siding windows soffit fascia
Replacing Metal Windows
Looked at a job today that we don't have much experience on, that is replacing a casement style metal window with a new vinyl window. The metal fin protudes into the window space about 1" all the way around. It would be a mess to cut the metal out to make it flush with the opening.
I was thinking to take a 2x6 (a full 2" board would be better but not sure how available) and use a router on the back of the board to accomodate the fin. Mount this 2x6 all the way around the opening, install window, and then wrap the outside and trim the inside of the 2x6. Easier way? This seems pretty labor intensive. ![]() Thanks, dave
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors |
Trade: siding
Re: Replacing Metal Windows
the 2x is on the outside? how would you flash this?
some guys leave the old steel sash installed cutting away any hinges etc then push the new unit from the inside against the old sash then cap over the old sash on the outside don't ask me how,i always pull the whole old unit there are special tool to collapse the old steel units in the opening i think Patrick uses one
Tom |
#3 | |
Re: Replacing Metal WindowsQuote:
dave
Trade: siding
in wood frame/stucco openings sometimes leaving the old frame is the recommended procedure,as it leaves the wrb intact
Tom Last edited by Tom Struble; 09-09-2009 at 10:04 PM. |
Trade: windows-siding
kind of like some basement windows ? rip out the metal windows,buck frame,caulk,insulate and cap...
Trade: Student
If it has a fin embedded into masonary and is a steel window that sounds like a good idea, just bring the jamb in to clear the steel frame and trim accordingly.
Some of those steel casements do not have an integral nail fin, they will have screws under the glazing/morter that holds the glass in. Or some will have a nail fin screwed onto the window frame. Either of these styles can turn what looks really ugly into an easier job .
| The Following User Says Thank You to W-Tinc For This Useful Post: | Tom Struble (09-10-2009) |
| estimating guide for windows? | Grumpy | Windows, Siding and Doors | 20 | 11-26-2010 08:18 PM |
| Windows XP Mode in Windows 7! | gideond | Technology | 9 | 05-15-2009 12:34 AM |
| replacing windows in masonry | shingler | Windows, Siding and Doors | 8 | 03-24-2009 11:48 PM |
| replacing short windows | Home Serve | Windows, Siding and Doors | 5 | 12-20-2008 12:51 PM |
