Replacement Windows For Aluminum Windows
Old 05-16-2008, 07:07 PM   #21
GGrant's Avatar
Trade: CARPENTER
Re: Replacement Windows For Aluminum Windows
Originally Posted by Patrick View Post
I flush fin would not require wrapping It just back caulks to the aluminum frame. I think more wholesalers need to start pushing AAMA certification to their contractors. we so many installs where we are just left saying "why on earth would someone do it like this?"
Patrick, I am going to estimate on a rancher BRICK REPLACEMENT, 7 aluminum windows, replacing with vinyl, need to know going rate per window, 3 jointed in one opening and two jointed in two openings, for customer that is living in the home. Live in Texas!
GGrant is offline
Old 05-16-2008, 07:30 PM   #22
I'd quote about $50 per window.
Unless they don't want the
premium ones.
You'll do better if you don't waste
so much time on research.
Increase your profit margin that way.
neolitic is offline
Old 05-16-2008, 08:07 PM   #23
Home Serve's Avatar
Trade: siding windows soffit fascia
Patrick, GGrant here is after you again. This time he is looking for a "professional" opinion. Got a brick rancher in Texas to deal with, and get this: the customer is living in the home!
Give him the lowdown would you?
Thanks
Dave C
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors
Home Serve is offline
Old 05-16-2008, 08:12 PM   #24
Patrick's Avatar
Thanks
Dave C
Brick rancher? Since when do they herd masonry materials? I always did wonder where bricks came from
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 05-17-2008, 03:59 PM   #25
72chevy4x4's Avatar
boy this is too funny-Ggrant is everywhere...and he blames his wife for typing errors. That's ok, the flashing on a door was messed up, water leaked down the basement wall onto the electrical panel and burned the house down...but my wife messed up the flashing
Back to my original question in this post, believe it or not, my suppliers don't have a window for replacement in aluminum frames. I even spoke to the regional Simonton rep who was strolling through and he thought it might be an option but wasn't sure at that! I ended up quoting out a new construction window with built in 'J'-a nice little touch would make the dated siding job look nice.
Interesting tidbit, the Simonton rep said they will be having a new construction window out (either all ready or coming out soon) that has built in 3.5" lineals as an option for about $50 more-sounds like a bargin compared to messing w/ the 20' lineals. Anyone sold/used these windows yet?
72chevy4x4 is offline
Old 05-20-2008, 10:03 PM   #26
Siding Windows Doors
easy sider's Avatar
Trade: Exteriors
Usually with a flush fin you would measure the inside window opening minus 1/4 inch on the net width and height. You would also remove the aluminum frame before installing the new window. The new window will slide into the opening and the flush fin will cover the edges of the siding. Most all major window manufacturers make a flush fin.
On window frames that can not be extracted such as some steel framed windows a flush fin usually works the same way as above except you take a net measurement off the inside of the steel window frame and qt round trim the inside opening.
easy sider is offline
Replacement Vinyl windows Project53 Windows, Siding and Doors 61 03-23-2011 09:02 PM
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Replacement Windows thom Remodeling 10 08-04-2007 09:38 AM
sq.ft. price on vinyl replacement windows ch0mpie Windows, Siding and Doors 10 08-16-2006 11:22 PM
Thermalgard replacement windows? ELM Windows, Siding and Doors 0 11-26-2005 07:45 PM
