PVC Or Painted Coil?
Old 07-13-2009, 04:50 PM   #1
CharlesD's Avatar
Trade: Remodeling/building
What's everyone's opinion about PVC or Vinyl Coated Aluminum Coil Stock.
Seems everywhere I look now only painted coil is being used. Did PVC fall out of favors?
IMO the painted coil looks better but the PVC coated holds up and doesn't scratch like the painted coil.
Price never was much of a factor.
CharlesD is offline
Old 07-13-2009, 05:04 PM   #2
KemoSabe
loneframer's Avatar
Re: PVC Or Painted Coil?
I prefer the appearance of PVC coil, but the painted coil bends cleaner for a sharper appearance. I like vinyl coil for Z-flashings on decks although that may not be much of a factor with the new treatment process.
loneframer is offline
Old 07-13-2009, 06:25 PM   #3
Tom Struble's Avatar
Trade: siding
i use both but i find the grain on the PVC distracting sometimes,i wish they had a brushed finish
Tom Struble is online now
Old 07-13-2009, 07:19 PM   #4
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
I like painted for hems just because it doesn't break like PVC does. Otherwise I prefer the PVC, mainly because it is wood grain finish.
MJW is online now
Old 07-13-2009, 11:09 PM   #5
Dan_Watson's Avatar
They still make painted? I have only used vinyl coated.
The vinyl coated breaks doing hems? I have never had a problem..are you talking the actual vinyl coil, not aluminum?
Dan_Watson is offline
Old 07-14-2009, 07:10 AM   #6
JSB's Avatar
Trade: Window Replacement Specialist
We have been using vinyl almost exclusively for the last 10 years or more. Some exceptions due to color (black and dark brown) and sometimes for the budget. We just did a student housing building at Case Western Reserve University and the $10+ difference per roll came into play. While aluminum is a tad easier to work with, the benefits of the vinyl more than make up for it in my opinion.
JSB is offline
Old 07-14-2009, 08:10 AM   #7
MJW's Avatar
The PVC coating itself breaks sometimes, not the aluminum, but yes this is using PVC coated aluminum.
I haven't ever seen vinyl coil before.
MJW is online now
Old 07-14-2009, 08:47 PM   #8
user38755's Avatar
We use both, not on the same jobs. Painted for most new low-end construction and PVC on existing or high-end homes. The painted does tend to scratch much more easily but it can almost always be cleaned up again with a little WD-40. It also takes paint well and is often painted when used to wrap windows in the foundation. The only time the PVC has ever had the cracking on the hem issue is when it is very cold, as long as the metal is kept warm just before use this is not a problem. I use only smooth painted when make a 4x4 post a column(series of 3/4" z bends and wrap around post, staple in the over-lap seam, paint staples).
user38755 is offline
Old 07-18-2009, 10:52 AM   #9
Siding Windows Doors
easy sider's Avatar
Trade: Exteriors
I don't like textured coil from the day it appeared. It feels thinner and has problems with delamination. Textured coil is just another way for the manufacturer to make something for less and sell it for more. Alcoa and Napco smooth coil has always been my favorites.
easy sider is offline
Old 08-23-2009, 08:37 PM   #10
Vinyls final
Dave Ruc's Avatar
Trade: siding, window, doors, trim
I personally prefer the pvc coated. I feel it is better looking, more durable, and far more scratch resistant.
Dave Ruc is offline
improving adhesion of mud on painted walls d's Drywall 18 04-22-2009 08:38 AM
indoor coil on the return side. flashheatingand HVAC 6 02-09-2009 10:04 PM
Cleanning an evaporator Coil Dr Heat HVAC 3 01-25-2009 06:54 PM
Evaporator coil leaks baileysair HVAC 3 11-14-2008 09:30 AM
Steel/vinyl coil stock. What to look for.. GiantScale Roofing 2 04-13-2006 07:38 PM
