Progressive Foam Vs Foam Clad Siding - Windows, Siding and Doors - Contractor Talk
Old 10-03-2012, 11:47 PM   #1
contractorjay's Avatar
Trade: Roofing Siding Gutters Windows
Rewards Points: 250
Progressive foam currently makes all the foam for the foam clad or foam backed siding.
My question is, is there a huge structure difference between the loose progressive foam vs factory clad foam Siding? Besides the price.
contractorjay is offline
Old 10-04-2012, 04:08 PM   #2
Rewards Points: 250
Re: Progressive Foam Vs Foam Clad Siding
bump!
Old 10-13-2012, 11:29 AM   #3
windowsonwashington.net
WindowsonWash's Avatar
Trade: Exterior Construction
Rewards Points: 1,178
No real difference in structure.
Windows on Washington
WindowsonWash is offline
Old 10-13-2012, 11:36 AM   #4
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
the thing i have about foam backed siding is you take the one great thing about vinyl siding,it's great ability to self drain using its open back ''rainscreen'' and then fill that drainage space with foam
i know some have contoured backs on the foam but thats not really the same thing
Tom Struble is offline
Old 10-13-2012, 12:37 PM   #5
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,062
Hey Tom,
I have been looking at Cranes foam backed. I think I have a new house to use it on. When I did comps between it, regular vinyl, and fc, I think it has some pros. I am slowly going away from fc due to the cracking and shrinking from multiple brands I have used. Any other reason you don't like foam backed vinyl?
overanalyze is online now
Old 10-13-2012, 01:38 PM   #6
Trade: siding
Rewards Points: 20
no,not really..it was just more of an observation than anything else
Old 10-13-2012, 01:43 PM   #7
Trade: siding
Rewards Points: 20
ive installed mastic structure and crane but ive always wanted to give this one a shot but haven't sold one yet
http://www.royalbuildingproducts.com...ura-plank.aspx
Old 10-13-2012, 01:57 PM   #8
Always Learning
Royal bought out Crane this year...wanted Cranes patents. Cranes the best according to my supplier and he can sell both...
Tom Struble (10-13-2012)
Old 10-13-2012, 02:00 PM   #9
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
The insulated crane board is as good as any I have used.
ohiohomedoctor is offline
Old 10-15-2012, 05:11 PM   #10
RandyB1986's Avatar
Trade: Roofing, Siding and Custom Carpentry
Rewards Points: 396
Is drop in material cheaper then attached? What kind of drop in do you guys use?
Thanks
RandyB1986 is offline
Old 10-15-2012, 08:47 PM   #11
Always Learning
Thanks
Never priced the drop in...don't like the idea of f-in with that on a windy day. Plus one of the pros of the attached is lower expansion.
Tom Struble (10-15-2012)
Old 10-15-2012, 08:57 PM   #12
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,926
It is all just vinyl siding hung on a wall that MUST be allowed to move and will admit moisture. It is definitely a moisture barrier, but will shed rains with no wind.
Dick
concretemasonry is offline
Old 10-15-2012, 09:51 PM   #13
Always Learning
You just have giving the definition of all claddings!!!
Old 10-16-2012, 10:30 PM   #14
RandyB1986's Avatar
Rewards Points: 396
I got a big insulated job I am about to order for. I plan to use Prodigy.....but it is $185 a 1 Sq box, no returns, and I am not sold on how it locks together. I priced Charter Oak today with drop in foam, it was a little less expensive, and I can return xtra foam. I talked to some guys who said drop in is easy to use.....and I think it can be used with any 4 1/2" siding.
Just wondering if it really matters which I use.
Thanks!
Old 10-24-2012, 08:11 PM   #15
I do like the Craneboard but the Prodigy is probably the next nicest one in my opinion.
Old 10-25-2012, 08:03 AM   #16
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 1,116
I saw Prodigy once on a HFH house I was doing soffit on . Was not impressed at all, it was the red , but it had bubbles in it and just did not look that great, I am a steel man so it is a little hard to compare vinyl to it specially when steel is about the same price . ( Alside)
I use a drop in foam most all the time either a 3/8 flat or tappered foam.
Randy Bush is offline
Need siding identification help CharlieM Windows, Siding and Doors 9 06-22-2012 05:40 PM
Werzali siding amazing product badsun79 Windows, Siding and Doors 3 06-21-2012 07:09 AM
exterior foam board to existing home... condensation? pork_laser Framing 5 01-10-2012 08:53 PM
Need advice for Siding Jerdog44 Windows, Siding and Doors 5 06-04-2009 04:03 PM
Siding and Insulation Jaketoo Carpentry 12 12-10-2008 02:36 PM
