Trade: Exterior refinishing
Problems With Hardiplank Colorplus
My sub has received 3 separate shipments from James Hardie - all had to be returned due to lack of color across the whole board and the beads do not line up. The last shipment was made-to-order and had each board inspected individually. Yet even southeastern Hardie reps & VP, wholesaler, and sub agree that none of the material is usable. We do know that the boards themselves were made in Peru (IL) and painted in Pulaski (VA) - all 3 shipments were manufactured at least a week apart. They said they'd send material painted in Peru but they didn't. We know the Pulaski plant is new but they mostly transferred experienced people into the plant from other James Hardie facilities. We're trying to use the Hardiplank Colorplus Beaded Cedarmill "Light Mist."
Has anyone else had this problem? What (and how) were you able to get good material? By the way, my sub is a preferred Hardiplank Colorplus installer. Job was bid and accepted based on the Colorplus and painting after installing would add significantly to the cost and would probably be unacceptable. thanks |
Expert Roofer
Re: Problems With Hardiplank Colorplus
leave it up to hardiplank to make good,even if it means changing every piece and it will
| Report problems with the new Contractor Talk here | Nathan | General Discussion | 32 | 07-30-2007 07:02 AM |
| Construction Records Problems | PalAl2000 | Commercial Construction | 5 | 05-15-2007 07:56 PM |
| Common Patio Door Problems | adriand | Remodeling | 1 | 01-14-2007 01:27 AM |
| Solving Problems | dayspring | Off Topic (Non Trade) | 13 | 06-15-2006 08:45 PM |
