Picture Framing Windows
Old 07-20-2006, 06:51 PM   #1
Nailbird's Avatar
Trade: Framing
I'm installing Hardiplank on a new house with Marvin windows. The windows are installed with Tamco 6" sealant on tops, sides, and bottoms. I'm using 4" Koma to trim the windows in a picture frame, but it's hard to get the trimboard to lie flat since the Tamco is pretty thick and is sealed up against the window for waterproofing. Any suggestions other than having to shim each piece of trim?
Also, has anyone used corrugated nails to connect the mitre joints on the trimboards? Using corrugated nails has been recommended to me to help keep the corners tight, but this is a waterfront property and if I use them I need galvanized or stainless steel fasteners. I have no clue where to find them.
Thanks in advance for the assist!
Nailbird
Nailbird is offline
Old 08-12-2006, 02:16 PM   #2
go dart's Avatar
Trade: remodeling/specializing in kitchen & baths
Re: Picture Framing Windows
can you assemble the frames into a single piece then install? you'll fight getting them to fit forever. you can use corrugated fastners from the back side. gud luk
go dart is offline
Old 08-12-2006, 05:31 PM   #3
Tom R's Avatar
Nailbird
I'd 'rip-strip' some narrow backers to length rather than playing with individual shims, - - if that's what you're talking about.
You could also 'rabbett' out the backs before installing, - - but I'd prefer the strips because the window trim will look better on the 'proud side' anyway.
I've never tried corrugated nails on trimboards, - - but myself, - - I'd prefer to run screws for more 'lateral' strength and 'drawn-tight' joints. You can use 'coated' deck screws, - - they'll be buried anyway.
Suggested filler for the holes would be urethane-based caulk, - - although I prefer paintable GE silicone caulk myself.
Tom R is online now
Old 08-12-2006, 06:52 PM   #4
Class A Contractor "BLD"
Gordo's Avatar
Trade: Remodeling and home improvements
What Tom said plus caulk/sealant the miters before you hang the trim. Load it up then wipe/clean the excess off before it dries. Make sure you do not 'dam' the cap flashing.
Looks like some pros were here.
Gordo is offline
Scouring Pad for Cleaing Windows WNYcarpenter General Discussion 23 08-05-2009 01:22 PM
Have a unique framing technique? KentWhitten Framing 62 06-25-2007 09:25 AM
Condensation on windows skidmark845 Windows, Siding and Doors 20 02-12-2007 08:59 PM
Casing out picture frame windows icfbunt Finish Carpentry 8 01-17-2007 12:05 PM
