Painting Aluminum
Old 12-28-2007, 02:28 PM   #1
personalt's Avatar
Trade: GC/Developer
Painting Aluminum
Is it possible to paint an aluminum drip cap? I have a strange color window that I cant really get coil to match at all close...
I would think you could with metal paint but I have never tried this before, I normally just get matching coil and bend what I need.
personalt is offline
Old 12-28-2007, 03:02 PM   #2
dkillianjr's Avatar
Re: Painting Aluminum
I don't see why not. I would scuff it up and then just spray it. I know my supplier sells paint to match popular window and coil colors.
dkillianjr is online now
Old 12-28-2007, 03:12 PM   #3
Bah Humbug!
Grumpy's Avatar
I see it done all the time, all aluminum siding painted. I'm not paitner but I would definetly think you'd want some metal paint. My guess would be a light sanding of the surface, then perhaps a metal primer and finally at least one coat of the paint. If it were for my house probably 2 coats.
You can just spray paint it with some $3 off the shelf crap but I don't think that'd stick too long without a good prep.
Grumpy is offline
Old 12-28-2007, 07:40 PM   #4
Cut the check
JCpresto's Avatar
Trade: Painter-residential
Sure you can paint it. Make sure its clean, and break the surface with some 180 grit. Ben Moore soft gloss bonds very nicely to it. Kinda pricey but it lasts.
JCpresto is offline
Old 12-28-2007, 08:02 PM   #5
Tin Man
painter jeff's Avatar
Trade: painter/owner
Survey says........J.C. you have the right answer......Good for the little under dog.........You seem to be getting beat up lately......
" Life is pain! anyone says differently, is selling something,"..." Life is like chess" by Ben Franklin
painter jeff is offline
Old 12-31-2007, 02:58 PM   #6
MrRSBMHandyman's Avatar
Trade: Fencing, Decks, Genaral Home Repair
Location: Amidst 1000 acers of crawfish ponds under an old oak grove
Send a message via AIM to MrRSBMHandyman
I have a good friend that owns an automotive rim repair business, and he uses an etching primer on all the aluminum wheels before painting the open pockets or hole in the rims. You can buy a spray can of etching primer at almost any auto parts store
MrRSBMHandyman is offline
Old 01-26-2008, 05:50 PM   #7
windows & siding
HomeSealed's Avatar
Trade: Home Performance: windows and exterior remodeling
Etching primer is just for bare metal. I'm guessing that it would be changing color in which case I usually just scuff and spray.
HomeSealed is offline
Old 02-01-2008, 01:44 PM   #8
tool junkie's Avatar
Trade: GC - Jobsite superintendent - General tool collector
Aluminum takes paint well. Just make sure its clean and sanded and that you use an oil based primer. You can use latex finish at that point but I would go oil base all the way.
-----oo00oo-----
If i understood the source of my addiction I would get help,
meanwhile I'll just buy another tool today.
-----oo00oo-----
tool junkie is offline
Painting Aluminum theartisan Painting & Finish Work 9 05-23-2007 02:37 PM
Painting Aluminum Siding Larman Painting & Finish Work 18 04-28-2007 12:05 AM
Another aluminum wiring question ron schenker Electrical 18 03-08-2007 06:54 PM
Painting Aluminum Clad Windows jeffkaprelian Painting & Finish Work 1 06-08-2006 12:17 PM
Painting as part of your estimate Mike Finley Remodeling 20 05-21-2006 11:25 PM
