Opinions On Finger Red Cedar Claps
Old 09-01-2009, 09:19 PM   #1
oldfrt's Avatar
Anyone with time tested experience using finger-joint primed red cedar claps?
Does it hold up to the elements?
This will be used on the south sides of appartment buildings that aren't always maintained well.They haven't been painted in over 15 years and all the siding is loose,curled,cracked,with paint pealing off in large strips.
Other problems were no underlayment at all,another was the use of the wrong nails.
Any help greatly appreciated.
Thanks,John
oldfrt is offline
Old 09-02-2009, 06:51 PM   #2
oldfrt's Avatar
Re: Opinions On Finger Red Cedar Claps
BUMP
Writing up the estimate Tonight,anybody seen this siding fail?
oldfrt is offline
Old 09-02-2009, 07:15 PM   #3
Jeff
jkfox624's Avatar
Trade: master turd burglar
I can help you in 5+ years, just installed 5 square today. One thing i was a little sketchy on after seeing it was the fact that it was like 2 inch strips glued to make up the 9 1/4 height. I figured it would just be finger jointed pieces on the length. Working with it it never felt like failure was imminent so we'll see.
The pics kinda blow, was just snapping a few quick ones before painters work their magic.
jkfox624 is online now
Old 09-02-2009, 07:41 PM   #4
oldfrt's Avatar
Thanks JK,
I've used it before,and all the pieces seemed straight,so application was a breeze.
I am just trying to give the client something that will fit his needs and budget.
There's five appartment buildings in this bid,just the south walls for now,but could be more down the line if I do him good.
With everyone going to vinyl and composit,I guess there would only be a handful of guys that still do the wood,just hoping one was online.
BTW,
How did you end up addressing that post,trim wise?
oldfrt is offline
Old 09-02-2009, 07:58 PM   #5
Jeff
jkfox624's Avatar
Still havent decided, gave her some options and well that was probably a mistake. So as you can see i stuck a couple pieces of straping on the post to line up my downspout so i have room to do whatever when she decides. If it holds up it was def the way to go, like you said every piece was straight and easy to work with and im pretty sure it was about 1/3 less or more in cost.
Old 09-02-2009, 08:45 PM   #6
oldfrt's Avatar
Got the local prices today:
Clear is running 1.19ln/ft
Finger joint primed was .93ln/ft.
Just the fact it's primed both sides is a bonus.
oldfrt is offline
Old 09-03-2009, 12:03 PM   #7
jumbo's Avatar
Trade: siding
Thanks,John
We still do a fair amount of wood siding. Have never used the finger jointed though. I'm just wondering why on earth they would be considering wood again, given the fact they dont do proper maitenance?
It's better to die on your feet than to be living on your knees.
jumbo is offline
Old 09-03-2009, 01:40 PM   #8
Smart phone? Scan me!
nEighter's Avatar
Trade: Painting/Framing/Drywall
good point jumbo. There are composites that will outlast wood anyday. Hardie or smart would be better IMO.
nEighter is offline
Old 09-03-2009, 07:35 PM   #9
oldfrt's Avatar
That was my first ? for the owners.
They have recently purchased the appartments and the lack of maintainence was the previous owners fault.
Since they are trying to get them in proper order at a limited cost,they figure,staying with wood and repainting is cheaper for now because the other sides aren't that bad yet.
It's been a tough sell,because he wants to try and save some of the existing weather beaten siding,some which is questionably repaintable,especially after I try and renail it or" tuck in" new pieces.
Some areas will get complete replacement,others patched.
It's a tough bid because his expectations for saving pieces are higher than mine.
I'd like to help the guy out,I could use the work,but I may have to walk away from this one.I'm going to have to insist on full replacement just cause my name's going to be on it,so we'll see whay happens.
oldfrt is offline
Old 09-03-2009, 07:39 PM   #10
jumbo's Avatar
Trade: siding
Until last year I would have walked away myself. Now I'm not too sure. Do what's right for you. Good luck.
jumbo is offline
Old 09-03-2009, 08:15 PM   #11
Jeff
jkfox624's Avatar
Eh saving siding is always a lost cause. The stuff on the original part of the barn we salvaged where the addition wrapped around the end so it would all match. Its prolly 15 year old siding we got the pieces off ok but once it got off the building it went all to hell on us. We peeled off close to 2 sq maybe and just barely had enough to piece in the triangle to the right of the hay loft door in the pic. One of the longest days of my life running that siding.
Old 09-03-2009, 08:21 PM   #12
oldfrt's Avatar
The worst part of this project is there in no paper between the siding and the plywood and the nails holes are enlarged because the wrong nails were used.
oldfrt is offline
Old 09-03-2009, 08:50 PM   #13
Jeff
jkfox624's Avatar
Sounds similar, they had typar behind our siding but none of the end joints had a lap flashing they just smeared some caulk in the joints that had long since dried out and stopped working. So the 3 inches above the top of the bottom piece and below the upper piece the water was getting in and behind it all. Pretty sure thats why it cupped so bad when we took it off, finally had a chance to dry out.
Old 09-03-2009, 08:50 PM   #14
Aframe's Avatar
Trade: Carpenter/GC
Oldfrt, I've done a fair amount FJP 6" clap. Was by a house recently, we did the garage three years ago so here is my report. I was not there for any work related stuff so I just took some mental notes of how everything was holding up.
Painted Dark red color, the finger joints were visible. It was the south side by coincidence. I did not check other walls so not sure if it was only that wall.
I have come across different grades of FJP, some stuff I saw at a box store was 12' of 6" pieces. Not something I would want to put my name on. Others have been larger random pieces and a better primer application.
Over time any paint problems will take their toll on the finger joints. I would only patch if it were a piece here and there.
Hardie is 1/2 the cost. I would push him to have you do at least one section w/hardie or similar. That way he will see how the two hold up side by side
Aframe is offline
The Following User Says Thank You to Aframe For This Useful Post:
oldfrt (09-03-2009)
Very old claps cjw818 Painting & Finish Work 7 07-05-2009 10:10 PM
What would you quote to build this cedar greenhouse (ballpark) photogoat Green Building 39 06-23-2009 02:45 AM
staining new cedar white world llc Painting & Finish Work 2 02-12-2009 07:58 AM
Vinyl Window with built in J Channel Cedar Siding cimhof Windows, Siding and Doors 9 12-25-2008 02:40 AM
joist centers using 3/4" cedar Old Sawdust Decks & Fencing 32 12-02-2008 09:52 PM
