Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Specialty Trades > Windows, Siding and Doors
Old 02-19-2009, 10:53 AM   #1
Trade: Doors and Windows
New Double door fiberglass install.
I recently installed this unit and it's nicely caulked with no holes. It'a already painted and I see no signs where water could infiltrate the stucco.
I have found two leaking spots in the corners of the threshold. I filled them up with caulk. Today after heavy rain and heavy wind the customer called to say it's leaking again. This time in the middle too.
Is this typical and what can I do to prevent the leaks. I do not think any of it is coming from within the bucking and jamb.
akimity is offline   Reply With Quote
Old 02-19-2009, 10:58 AM   #2
Trade: General Contractor, Remodeler
Had the same happen once. Mfgr sent a rep, and it turned out to be a faulty door. Mfgr replaced it at no charge.
now i am scared for my future
i've got all ten
smashed a lot of them stupidly before
-john5mt
Forry is offline   Reply With Quote
Old 02-19-2009, 12:22 PM   #3
JonM's Avatar
Same here...the door leaked where the window contacted the door...they sent a guy from Virgina to Connecticut to fix it......I told them just send me a new door and I would just swap them...nope, they insisted on sending a guy.
JonM is offline   Reply With Quote
Old 02-21-2009, 05:56 PM   #4
TRC
TRC
Trade: Windows and Doors
I also had a similar problem once but it was a very small leak. Manufacturer replaced the door.
I I would use clear silicone to seal all gaps between door sill and threshold and jamb legs (not much and very neat). Some manufacturers will have you do that as part of the install. I'm talking about the joints where the unit is assembled, not anything to do with your installation. Also, could be where you installed plate for bottom slide bolt. You are supposed to caulk any holes you made there as well.
good luck.
TRC is offline   Reply With Quote
Old 02-22-2009, 05:07 PM   #5
Did you install the corner jamb seal pads?
Also not sure what brand you got but Pella double doors are notorious for having the weatherstrip in the astragal too short. I always ask for spare piece of weatherstrip when I order Pella double doors.
TimNJ is offline   Reply With Quote
Old 02-25-2009, 02:08 PM   #6
I've caulked the crap out of the unit. I think I'll give it a little more. There is no leaks from around the jamb it's sealed up great with caulk and paint. I took a cup of water and poured it into the corner with the adjustable part of the jamb meets the weather stripping and water did work it's way into the house. Knowing that was happening and not having caulk the customer said he would caulk the corners up. I did the initial caulking of the edges but later raised the sill opening a small hole.
Just had a rep in and he pretty much told me that on a 8' inswing and a heavy rain a little leakage should be expected. We are talking about a thimble of water that makes it in.
Old 02-26-2009, 08:35 PM   #7
TRC
TRC
Originally Posted by akimity View Post
i've caulked the crap out of the unit. I think i'll give it a little more. There is no leaks from around the jamb it's sealed up great with caulk and paint. I took a cup of water and poured it into the corner with the adjustable part of the jamb meets the weather stripping and water did work it's way into the house. Knowing that was happening and not having caulk the customer said he would caulk the corners up. I did the initial caulking of the edges but later raised the sill opening a small hole.
i don't know too many ho's that would accept that answer. What do you mean by 8' in-swing?
Old 02-26-2009, 09:15 PM   #8
Yeah, 8'? Six foot double door with 2 12" sidelights? I can't imagine 2 four foot door slabs in a residential house.
Old 02-28-2009, 08:19 AM   #9
TRC
TRC
Originally Posted by timnj View Post
yeah, 8'? Six foot double door with 2 12" sidelights? I can't imagine 2 four foot door slabs in a residential house.
unless he's talking about 8' high door.
Window Install Questions Brickie Windows, Siding and Doors 9 02-21-2009 06:34 PM
Pond Water-Leveling Pipe Install Trencher Excavation & Site Work 7 12-26-2008 12:28 AM
Single pole vs. double pole thermostat dforeid Electrical 2 10-23-2008 09:42 PM
Septic tank install help metzade Plumbing 6 09-26-2008 08:47 PM
Replacing double window w slider 1st time dvlscapes Carpentry 5 09-03-2008 01:26 PM
