New Construction Windows Flashing
Old 09-10-2009, 12:38 PM   #1
sponge racing's Avatar
Trade: carpenter
What do most of you guys do? Ive always wrapped the house using felt then put the windows. Flashing the windows on top of the house wrap. Also saw guys put the windows and window flashing right to the plywood then put the house wrap on around the windows. I like doing it before so I can wrap the house wrap into the jambs of the windows.
sponge racing is offline
Old 09-10-2009, 02:17 PM   #2
General Contractor
MacRoadie's Avatar
Trade: General Building Contractor
Re: New Construction Windows Flashing
For aluminum or vinyl windows, the industry standard for window installation is AAMA 2400-02 "Standard Practice for Installation of Windows with a Mounting Flange in Stud Frame Construction"
http://pro.milgard.com/_doc/products...ma-2400-02.pdf
Out here in production housing, the windows are set by the framer so from a sequencing standpoint, the widows are set and flashed first then the building wrap is installed by the stucco sub. You don't see too much Tyvek or other "house wraps" out here, it's still building paper. Regardless of sequence, you still need to make sure the lapping is done in a weatherboard fashion to insure any moisture is directed to the exterior of the wall rather than the wall cavity. The problem with pre-wrapping the wall is that you don't get your building paper/wrap over the head and jamb flashing like the AAMA standard requires (Figure 6 in the pdf).
MacRoadie is offline
The Following User Says Thank You to MacRoadie For This Useful Post:
Tom Struble (09-10-2009)
Old 09-13-2009, 08:58 PM   #3
Trade: carpenter
Thanks for the info. I usually cut the felt at the top on a angle then tape it up out of the way. Then flash the top and then fold the paper back down and tape the angle cut in the felt..
estimating guide for windows? Grumpy Windows, Siding and Doors 20 11-26-2010 08:18 PM
Did you know Microsoft has Financial and Operational Software for Construction bdupper Accounting Software & Discussion 0 06-12-2009 09:25 AM
Labor Est. for swapping vinyl rep. windows to wood clad rep. windows? Tallguy1 Windows, Siding and Doors 6 02-10-2009 12:58 AM
Reed Construction Data Launches SmartLead Grumpy General Discussion 0 12-18-2008 09:40 AM
Caulking Replacement Windows Bettercarpentry Windows, Siding and Doors 10 11-08-2008 04:34 PM
