New Construction Windows With Built In J
Old 03-16-2007, 07:19 PM   #1
osborn's Avatar
Trade: Licensed Home Improvement Contractor
Im rehabbing very old houses. Gut rehab. Im installing new construction windows with built in J. The thing is , Im doing Tyvek and fan foam. That doesnt leave room to slide the vinyl siding into the windows J channel.. Next house gets going next week. I think Im going to tack the windows in place. Pull them when we do tyvek and fan foam on that side of the house , then set the windows and tape flash them. Does this sound typical to all the guys who hang vinyl?
osborn is offline
Old 03-16-2007, 07:29 PM   #2
jmic's Avatar
Re: New Construction Windows With Built In J
Os, Just a thought what I would do is rip some strips of plywood to put behind the window flanges to hold them out the same thickness as the fan foam. I think nailing the window to the fan foam would bo to irregular when you go to trim the insides.
Joe
jmic is offline
Old 03-16-2007, 10:40 PM   #3
joasis's Avatar
We space the windows out also with srips cut from 1/4 inch ply...seals great and the window remains flat with the wall...and siding.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is online now
Old 03-17-2007, 12:52 AM   #4
3rd gen,it's in the blood
roofwiz74's Avatar
Trade: roofing
it never ceases to surprise me the questions a "contractor" will ask.are you for real?the norm?yes everybody mounts windows to the fan fold.
check out certainteed.com they have a window installation course available free.it'll get you started on the basics.such as suitable mounting preferances.
You have ONE advantage over me.....you can kiss my butt and I can't!!
roofwiz74 is offline
Old 03-17-2007, 07:11 AM   #5
joasis's Avatar
The siding we install is nearly always "polar wall" from Norandex, and is 1-1/4 inch.....we space our NC windows out to maintain the siding level intot he J channel.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Old 03-17-2007, 08:54 AM   #6
osborn's Avatar
Yes Im real. The thing I like about this forum is the advice I can give and receive. My background isnt in plastic siding or vinyl windows with built in J. So thanks for the help. Now to decide which advice to follow.
osborn is offline
Old 03-20-2007, 06:49 AM   #7
tinner666's Avatar
I like all insulation, foam, etc, behind the flange, with window flush, then after squaring, I install the lower flashing befoe nailing the window bottoms.
http://www.albertsroofing.com/Window%20Flashing.htm
tinner666 is offline
Old 03-20-2007, 08:49 AM   #8
Same Old's Avatar
Trade: Residential General
Your website does not work.
Same Old is offline
Old 03-20-2007, 09:47 AM   #9
Tom M's Avatar
Os---I never use this low grade window but if I did I would consider a few things here. Do these units have built-in extention jambs? I do not like the idea of installing the window over the foam. It sounds like a bad idea. Water can wick through and make these jays pointless as well as creating other issues later. If you must do it, use wood lath as a backer to bring the unit flush with the fan-fold. Its cheap and its 3/8" x 1 1/2" ideal for this.
Tom M is online now
Old 03-20-2007, 02:28 PM   #10
Patrick's Avatar
If the window has a nailing flange how the hell do you keep the window parallel to the wall??? If you nail too tight the windows gonna sink into the foam, to keep from sinking im assuming you nail loose, now you would have a loose window?? If subjected to constant opening and closing could the window potentially work loose? I only use plywood. Lats are ok but they tend to split too easily especially if you are nailing the window every other nail slot. Another option is Crane Board makes an adapter that snaps onto the windows built in J channel that turns it into a 1-1/4" Deep J Pocket for use with their insulated siding.
Patrick is offline
Old 03-20-2007, 03:45 PM   #11
Patrick's Avatar
Patrick is offline
Old 03-20-2007, 04:16 PM   #12
Tom M's Avatar
I didnt know crane made an adapter. Thats good.
Tom M is online now
Old 03-20-2007, 05:13 PM   #13
Dream Maker
Mr. D's Avatar
Trade: residential construction
dont forget to ice & water shield your flanges properly after window is installed
Mr. D is offline
Old 03-20-2007, 06:40 PM   #14
tinner666's Avatar
Thumbs up
Sure isn't! I need to add that at the link, you need to select the Window Details album.
I'm taking a display window and setting it in a piece of wall as a display. I plan on taking pics with water showing how most siding jobs guide the water behind the siding, and how the flashing I install guides the water outside.
I'll post the whole thing on the website later.
Old 03-20-2007, 06:46 PM   #15
tinner666's Avatar
I made a few notes on that page for more info. More will be coming, soon I hope.
Old 03-20-2007, 09:27 PM   #16
osborn's Avatar
I will add this, i am using tyvek then fan foam. I will tape flash them also. My jambs are made with my casing and sill. I picture frame my window trim, including the jambs, in the garage during insulation and drywall phase.
osborn is offline
Old 03-21-2007, 07:28 PM   #17
ProSide's Avatar
Trade: Siding
Just my thoughts but I think the easiest way is just to put J on the windows.....problem solved....As for putting tyvek under the fanfold I would think it would be fine but I wouldnt tape off the fanfold or you might create a moisture barrier.......
ProSide is offline
Old 03-27-2007, 10:21 PM   #18
tinner666's Avatar
OK. I've updated the website and the window detail page. As noted, the display is not wrapped. Don't omit those details.
I want to get in Construction and am looking for advice chompchomp12 Business 21 12-17-2009 10:39 PM
quaker windows truckman Windows, Siding and Doors 9 04-30-2007 07:46 PM
Condensation on windows skidmark845 Windows, Siding and Doors 20 02-12-2007 08:59 PM
22 Undeniable Construction Truths Ed the Roofer General Discussion 0 01-26-2007 06:00 PM
